Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary: ===============================
=> Windows is installed in the MBR of /dev/sda.
sda1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
File system: ntfs
Operating System: Windows 7
Boot files: /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files: /BOOTMGR /BOOT/BCD
sda4: __________________________________________________________________________
File system: Extended Partition
Boot sector type: Grub2 (v1.99)
Boot sector info: Grub2 (v1.99) is installed in the boot sector of sda4
and looks at sector 475698720 of the same hard drive
for core.img. core.img is at this location and looks
in partition 132 for .
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda6: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda7: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Debian GNU/Linux stretch/sid
Boot files: /grub/grub.cfg /boot/grub/grub.cfg /etc/fstab
sda8: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 15.04
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 298.1 GiB, 320072933376 bytes, 625142448 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 2,048 3,074,047 3,072,000 27 Hidden NTFS (Recovery Environment)
/dev/sda2 3,082,240 451,389,439 448,307,200 7 NTFS / exFAT / HPFS
/dev/sda3 604,020,736 625,141,759 21,121,024 17 Hidden NTFS / HPFS
/dev/sda4 451,391,486 596,432,895 145,041,410 f W95 Extended (LBA)
/dev/sda5 451,391,488 455,604,377 4,212,890 82 Linux swap / Solaris
/dev/sda6 497,549,312 596,428,799 98,879,488 83 Linux
/dev/sda7 476,579,840 497,547,263 20,967,424 83 Linux
/dev/sda8 455,608,320 476,579,023 20,970,704 83 Linux
“blkid” output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/loop1 DM_snapshot_cow
/dev/loop2 squashfs
/dev/loop3 24375583-5faa-4172-8345-5dff1a0e89e5 ext4 _Fedora-Live-Des
/dev/loop4 DM_snapshot_cow
/dev/mapper/live-base 24375583-5faa-4172-8345-5dff1a0e89e5 ext4 _Fedora-Live-Des
/dev/mapper/live-osimg-min 24375583-5faa-4172-8345-5dff1a0e89e5 ext4 _Fedora-Live-Des
/dev/mapper/live-rw 24375583-5faa-4172-8345-5dff1a0e89e5 ext4 _Fedora-Live-Des
/dev/sda1 6A5A5F7A5A5F424D ntfs System
/dev/sda2 3864851F6484E14C ntfs TI105828W0G
/dev/sda3 581EAA991EAA6FA4 ntfs HDDRECOVERY
/dev/sda5 05cd90a8-0b39-4e06-8a3b-afe47efda158 swap
/dev/sda6 0e58dde8-53ac-45f7-9e1f-8b5eb9d6b535 ext4
/dev/sda7 716482b3-6caa-4c04-8df1-7b53804036fb ext4 debian
/dev/sda8 c78bda1d-4aa3-4fa9-b84b-2cba367058b1 ext4
/dev/sr0 2013-12-12-00-56-55-00 iso9660 Fedora-Live-Desktop-x86_64-20-1
========================= “ls -R /dev/mapper/” output: =========================
/dev/mapper:
control
live-base
live-osimg-min
live-rw
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/mapper/live-rw / ext4 (rw,noatime,seclabel,data=ordered)
/dev/sr0 /run/initramfs/live iso9660 (ro,relatime)
============================= sda7/grub/grub.cfg: ==============================
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [-s $prefix/grubenv]; then
set have_grubenv=true
load_env
fi
if ["${next_entry}"] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [x"${feature_menuentry_id}" = xy]; then
menuentry_id_option="–id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if ["${prev_saved_entry}"]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [-z “${boot_once}”]; then
saved_entry="${chosen}"
fi
function load_video {
if [x$feature_all_video_module = xy]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [x$feature_default_font_path = xy] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos7’
if [x$feature_platform_search_hint = xy]; then
search --no-floppy --fs-uuid --set=root 716482b3-6caa-4c04-8df1-7b53804036fb
else
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if ["${recordfail}" = 1] ; then
set timeout=30
else
if [x$feature_timeout_style = xy] ; then
set timeout_style=menu
set timeout=5
Fallback normal timeout code in case the timeout_style feature is
unavailable.
else
set timeout=5
fi
fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [-f ${config_directory}/custom.cfg]; then
source ${config_directory}/custom.cfg
elif [-z “${config_directory}” -a -f $prefix/custom.cfg]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
=========================== sda7/boot/grub/grub.cfg: ===========================
load_env
fi
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
else
fi
set boot_once=true
fi
fi
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd2,msdos7’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos7 --hint-efi=hd0,msdos7 --hint-baremetal=ahci0,msdos7 --hint=‘hd2,msdos7’ 716482b3-6caa-4c04-8df1-7b53804036fb
else
fi
fi
set gfxmode=auto
load_video
insmod gfxterm
set lang=pl_PL
insmod gettext
fi
set timeout=30
else
set timeout=5
unavailable.
else
set timeout=5
fi
fi
function gfxmode {
set linux_gfx_mode=
menuentry ‘Debian GNU/Linux’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-simple-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
if [x$grub_platform = xxen]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
echo 'Wczytywanie systemu Linux 4.0.0-2-686-pae…'
linux /boot/vmlinuz-4.0.0-2-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet
echo 'Wczytywanie początkowego dysku RAM…'
initrd /boot/initrd.img-4.0.0-2-686-pae
submenu ‘Opcje zaawansowane dla systemu Debian GNU/Linux’ $menuentry_id_option ‘gnulinux-advanced-716482b3-6caa-4c04-8df1-7b53804036fb’ {
menuentry ‘Debian GNU/Linux, za pomocą systemu Linux 4.0.0-2-686-pae’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.0.0-2-686-pae-advanced-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 4.0.0-2-686-pae (sysvinit)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.0.0-2-686-pae-init-sysvinit-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.0.0-2-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet init=/lib/sysvinit/init
menuentry ‘Debian GNU/Linux, with Linux 4.0.0-2-686-pae (recovery mode)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.0.0-2-686-pae-recovery-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.0.0-2-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro single
menuentry ‘Debian GNU/Linux, za pomocą systemu Linux 3.16.0-4-686-pae’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.16.0-4-686-pae-advanced-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Wczytywanie systemu Linux 3.16.0-4-686-pae…'
linux /boot/vmlinuz-3.16.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet
initrd /boot/initrd.img-3.16.0-4-686-pae
menuentry ‘Debian GNU/Linux, with Linux 3.16.0-4-686-pae (sysvinit)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.16.0-4-686-pae-init-sysvinit-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet init=/lib/sysvinit/init
menuentry ‘Debian GNU/Linux, with Linux 3.16.0-4-686-pae (recovery mode)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.16.0-4-686-pae-recovery-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro single
menuentry ‘Debian GNU/Linux, za pomocą systemu Linux 3.2.0-4-686-pae’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.2.0-4-686-pae-advanced-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Wczytywanie systemu Linux 3.2.0-4-686-pae…'
linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet
initrd /boot/initrd.img-3.2.0-4-686-pae
menuentry ‘Debian GNU/Linux, with Linux 3.2.0-4-686-pae (sysvinit)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.2.0-4-686-pae-init-sysvinit-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro quiet init=/lib/sysvinit/init
menuentry ‘Debian GNU/Linux, with Linux 3.2.0-4-686-pae (recovery mode)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.2.0-4-686-pae-recovery-716482b3-6caa-4c04-8df1-7b53804036fb’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro single
menuentry ‘Windows 7 (loader) (na /dev/sda1)’ --class windows --class os $menuentry_id_option ‘osprober-chain-6A5A5F7A5A5F424D’ {
insmod part_msdos
insmod ntfs
set root='hd2,msdos1’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 --hint=‘hd2,msdos1’ 6A5A5F7A5A5F424D
else
search --no-floppy --fs-uuid --set=root 6A5A5F7A5A5F424D
fi
parttool ${root} hidden-
chainloader +1
menuentry ‘Windows 7 (loader) (na /dev/sda2)’ --class windows --class os $menuentry_id_option ‘osprober-chain-3864851F6484E14C’ {
insmod part_msdos
insmod ntfs
set root='hd2,msdos2’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 --hint=‘hd2,msdos2’ 3864851F6484E14C
else
search --no-floppy --fs-uuid --set=root 3864851F6484E14C
fi
chainloader +1
menuentry ‘Windows Recovery Environment (loader) (na /dev/sda3)’ --class windows --class os $menuentry_id_option ‘osprober-chain-581EAA991EAA6FA4’ {
insmod part_msdos
insmod ntfs
set root='hd2,msdos3’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3 --hint=‘hd2,msdos3’ 581EAA991EAA6FA4
else
search --no-floppy --fs-uuid --set=root 581EAA991EAA6FA4
fi
drivemap -s (hd0) ${root}
chainloader +1
menuentry ‘Ubuntu 15.04 (15.04) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
insmod part_msdos
insmod ext2
set root='hd2,msdos8’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos8 --hint-efi=hd0,msdos8 --hint-baremetal=ahci0,msdos8 --hint=‘hd2,msdos8’ c78bda1d-4aa3-4fa9-b84b-2cba367058b1
else
search --no-floppy --fs-uuid --set=root c78bda1d-4aa3-4fa9-b84b-2cba367058b1
fi
linux /boot/vmlinuz-3.19.0-15-generic root=UUID=c78bda1d-4aa3-4fa9-b84b-2cba367058b1 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.19.0-15-generic
submenu ‘Opcje zaawansowane dla systemu Ubuntu 15.04 (15.04) (na /dev/sda8)’ $menuentry_id_option ‘osprober-gnulinux-advanced-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
menuentry ‘Ubuntu (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.19.0-15-generic–c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Ubuntu, za pomocą systemu Linux 3.19.0-15-generic (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.19.0-15-generic–c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Ubuntu, with Linux 3.19.0-15-generic (recovery mode) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.19.0-15-generic-root=UUID=c78bda1d-4aa3-4fa9-b84b-2cba367058b1 ro recovery nomodeset-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.19.0-15-generic root=UUID=c78bda1d-4aa3-4fa9-b84b-2cba367058b1 ro recovery nomodeset
fi
=============================== sda7/etc/fstab: ================================
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sdc10 during installation
UUID=716482b3-6caa-4c04-8df1-7b53804036fb / ext4 errors=remount-ro 0 1
/home was on /dev/sdc7 during installation
UUID=0e58dde8-53ac-45f7-9e1f-8b5eb9d6b535 /home ext4 defaults 0 2
swap was on /dev/sdc5 during installation
UUID=05cd90a8-0b39-4e06-8a3b-afe47efda158 none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/sda1 /media/usb0 auto rw,user,noauto 0 0
/dev/sdb1 /media/usb1 auto rw,user,noauto 0 0
=================== sda7: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
============================= sda8/grub/grub.cfg: ==============================
load_env
fi
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
else
fi
set boot_once=true
fi
fi
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
font=unicode
else
insmod part_msdos
insmod ext2
else
fi
fi
set gfxmode=auto
load_video
insmod gfxterm
set lang=en_US
insmod gettext
fi
set timeout=30
else
set timeout=5
unavailable.
else
set timeout=5
fi
fi
function gfxmode {
set linux_gfx_mode=
fi
=========================== sda8/boot/grub/grub.cfg: ===========================
load_env
fi
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
else
fi
set boot_once=true
fi
fi
function recordfail {
set recordfail=1
if [-n “${have_grubenv}”]; then if [-z “${boot_once}”]; then save_env recordfail; fi; fi
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos9’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos9 --hint-efi=hd0,msdos9 --hint-baremetal=ahci0,msdos9 c78bda1d-4aa3-4fa9-b84b-2cba367058b1
else
fi
fi
set gfxmode=auto
load_video
insmod gfxterm
set lang=pl_PL
insmod gettext
fi
set timeout=-1
else
set timeout=10
unavailable.
else
set timeout=10
fi
fi
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
#set_background_image “images/tile.png”;
if background_color 0,0,0; then
clear
fi
function gfxmode {
set gfxpayload="${1}“
if [”${1}" = “keep”]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if ["${recordfail}" != 1]; then
if [-e ${prefix}/gfxblacklist.txt]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [${match} = 0]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
menuentry ‘Ubuntu’ --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-simple-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
else
fi
submenu ‘Opcje zaawansowane dla systemu Ubuntu’ $menuentry_id_option ‘gnulinux-advanced-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
menuentry ‘Ubuntu, za pomocą systemu Linux 3.19.0-15-generic’ --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.19.0-15-generic-advanced-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Wczytywanie systemu Linux 3.19.0-15-generic…'
menuentry ‘Ubuntu, with Linux 3.19.0-15-generic (recovery mode)’ --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.19.0-15-generic-recovery-c78bda1d-4aa3-4fa9-b84b-2cba367058b1’ {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
BEGIN /etc/grub.d/20_memtest86+
menuentry ‘Memory test (memtest86+)’ {
insmod part_msdos
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry ‘Memory test (memtest86+, serial console 115200)’ {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
insmod part_msdos
insmod ntfs
set root='hd0,msdos1’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 6A5A5F7A5A5F424D
else
fi
chainloader +1
menuentry ‘Arch (na /dev/sda10)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55’ {
insmod part_msdos
insmod ext2
set root='hd0,msdos10’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos10 --hint-efi=hd0,msdos10 --hint-baremetal=ahci0,msdos10 892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55
else
search --no-floppy --fs-uuid --set=root 892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55
fi
linux /boot/vmlinuz-linux root=UUID=892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55 rw quiet
initrd /boot/initramfs-linux.img
submenu ‘Opcje zaawansowane dla systemu Arch (na /dev/sda10)’ $menuentry_id_option ‘osprober-gnulinux-advanced-892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55’ {
menuentry ‘Arch Linux (na /dev/sda10)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-linux–892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Arch Linux, with Linux linux (na /dev/sda10)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-linux–892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Arch Linux, with Linux linux (fallback initramfs) (na /dev/sda10)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-linux–892d1c9f-5ddf-4dfb-ad2b-fb1e8ca9cb55’ {
insmod part_msdos
insmod ext2
else
fi
initrd /boot/initramfs-linux-fallback.img
insmod part_msdos
insmod ntfs
set root='hd0,msdos2’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 3864851F6484E14C
else
fi
chainloader +1
insmod part_msdos
insmod ntfs
set root='hd0,msdos3’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3 581EAA991EAA6FA4
else
fi
chainloader +1
menuentry ‘Ubuntu 14.10 (14.10) (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos7 --hint-efi=hd0,msdos7 --hint-baremetal=ahci0,msdos7 b9fac91b-ed15-4e09-881b-b4cfe3390b1a
else
search --no-floppy --fs-uuid --set=root b9fac91b-ed15-4e09-881b-b4cfe3390b1a
fi
linux /boot/vmlinuz-3.16.0-28-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.16.0-28-generic
submenu ‘Opcje zaawansowane dla systemu Ubuntu 14.10 (14.10) (na /dev/sda7)’ $menuentry_id_option ‘osprober-gnulinux-advanced-b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
menuentry ‘Ubuntu (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-28-generic–b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Ubuntu, za pomocą systemu Linux 3.16.0-28-generic (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-28-generic–b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Ubuntu, with Linux 3.16.0-28-generic (recovery mode) (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-28-generic-root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset-b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-28-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset
menuentry ‘Ubuntu, za pomocą systemu Linux 3.16.0-24-generic (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-24-generic–b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-24-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.16.0-24-generic
menuentry ‘Ubuntu, with Linux 3.16.0-24-generic (recovery mode) (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-24-generic-root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset-b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-24-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset
menuentry ‘Ubuntu, za pomocą systemu Linux 3.16.0-23-generic (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-23-generic–b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-23-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.16.0-23-generic
menuentry ‘Ubuntu, with Linux 3.16.0-23-generic (recovery mode) (na /dev/sda7)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-23-generic-root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset-b9fac91b-ed15-4e09-881b-b4cfe3390b1a’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.16.0-23-generic root=UUID=b9fac91b-ed15-4e09-881b-b4cfe3390b1a ro recovery nomodeset
menuentry ‘Debian GNU/Linux (8.0) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
set root='hd0,msdos8’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos8 --hint-efi=hd0,msdos8 --hint-baremetal=ahci0,msdos8 716482b3-6caa-4c04-8df1-7b53804036fb
else
fi
submenu ‘Opcje zaawansowane dla systemu Debian GNU/Linux (8.0) (na /dev/sda8)’ $menuentry_id_option ‘osprober-gnulinux-advanced-716482b3-6caa-4c04-8df1-7b53804036fb’ {
menuentry ‘Debian GNU/Linux (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-4-686-pae–716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, za pomocą systemu Linux 3.16.0-4-686-pae (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-4-686-pae–716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 3.16.0-4-686-pae (sysvinit) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-4-686-pae–716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 3.16.0-4-686-pae (recovery mode) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.16.0-4-686-pae-root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro single-716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, za pomocą systemu Linux 3.2.0-4-686-pae (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae–716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 3.2.0-4-686-pae (sysvinit) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae–716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 3.2.0-4-686-pae (recovery mode) (na /dev/sda8)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae-root=UUID=716482b3-6caa-4c04-8df1-7b53804036fb ro single-716482b3-6caa-4c04-8df1-7b53804036fb’ {
insmod part_msdos
insmod ext2
else
fi
if ["${timeout}" = 0]; then
set timeout=10
fi
fi
=============================== sda8/etc/fstab: ================================
/ was on /dev/sda9 during installation
UUID=c78bda1d-4aa3-4fa9-b84b-2cba367058b1 / ext4 errors=remount-ro 0 1
/home was on /dev/sda6 during installation
swap was on /dev/sda5 during installation
=================== sda8: Location of files loaded by Grub: ====================
=============================== StdErr Messages: ===============================
cat: /tmp/BootInfo-0Qet81vB/Tmp_Log: No such file or directory
No volume groups found
mdadm: No arrays found in config file or automatically
