Pełny BS Debug View log: http://www.wklejto.pl/174153
Ustawienia zasilania i uśpienia/hibernacji:
Plany preferowane: Zrównoważony aktywny (zalecane) Wyłącz ekran 10 min./ Przełącz w tryb uśpienia 15 min.
Wyłącz HDD : 20 min.
Zezwalaj na tryb uśpienia hybrydowego: Włącz - 15 min.
Zezwalaj na wznawianie pracy wg. czasomierza: włącz.
ntoskrnl.exe
ntoskrnl.exe 0000000002C54000 00000000
0323A000 0x005e6000 126 0 Application NT Kernel System 6.1.7601.18229 Microsoft Corporation Microsoft® Windows® Operating System 2013-08-02 04:23:53 2013-09-14 16:20:58 C:\Windows\system32\ntoskrnl.exe A
My Event Viewer:
Zainstalowałem poprawkę: KB947821 – Windows6.0-KB947821-v29-x86.msu – http://support.microsoft.com/kb/947821
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.18229.amd64fre.win7sp1_gdr.130801-1533
Machine Name:
Kernel base = 0xfffff800`02c66000 PsLoadedModuleList = 0xfffff800`02ea96d0
Debug session time: Mon Sep 16 14:37:47.222 2013 (UTC - 4:00)
System Uptime: 0 days 5:41:56.924
* Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time (usually 10 minutes).
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8009a2b060, Physical Device Object of the stack
Arg3: fffff80000b9c518, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa80094c6560, The blocked IRP
Debugging Details:
***Either you specified an unqualified symbol, or your debugger***
***doesn't have full symbol information. Unqualified symbol***
***resolution is turned off by default. Please either specify a***
***fully qualified symbol module!symbolname, or enable resolution***
***of unqualified symbols by typing ".symopt- 100". Note that***
***enabling unqualified symbol resolution with network symbol***
***server shares in the symbol path may cause the debugger to***
***appear to hang for long periods of time when an incorrect***
***symbol name is typed or the network symbol server is down.***
***For some commands to work properly, your symbol path***
***must point to .pdb files that have full type information.***
***Certain .pdb files (such as the public OS symbols) do not***
***contain the required information. Contact the group that***
***provided you with these symbols if you need this command to***
***work.***
*** Type r
verifier /querysettings
Microsoft Windows [Wersja 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone.
C:\Users\ verifier /query
2013-09-17, 02:27:00
Żadne sterowniki nie są obecnie weryfikowane.
C:\Users\
C:\Users\ verifier /querysettings
Pula specjalna: Włączony
Śledzenie puli: Włączony
Wymuszanie sprawdzania IRQL: Włączony
Weryfikacja We/Wy: Włączony
Wykrywanie zakleszczenia: Włączony
Sprawdzanie DMA: Wyłączone
Testy zabezpieczeń: Włączony
Wymuś oczekujące żądania We/Wy: Wyłączone
Symulacja niedoboru zasobów: Wyłączone
Rejestrowanie pakietów IRP: Włączony
Testy różne: Włączony
Zweryfikowane sterowniki:
cscrysec.sys
kl1.sys
jraid.sys
scsiport.sys
iastorv.sys
amdxata.sys
a2dix64.sys
mwlpsdfilter.sys
klif.sys
klflt.sys
kltdi.sys
klim6.sys
ndis.sys
mwlpsdvdisk.sys
mwlpsdnserv.sys
kneps.sys
csvirtualdiskdrv.sys
a2util64.sys
a2ddax64.sys
atikmpag.sys
atipmdag.sys
hecix64.sys
e1k62x64.sys
ubhelper.sys
ntidrvr.sys
atihdmi.sys
rtkvhd64.sys
dump_iastor.sys
dump_dumpfve.sys
rtl8192su.sys
klmouflt.sys
klkbdflt.sys
turbob.sys
secdrv.sys
cleanhlp64.sys
a2accx64.sys
C:\Users\
Restart i … nie skończyło się fajnie jak widać poniżej:
Nazwa dziennika:Microsoft-Windows-Kernel-EventTracing/Admin
Źródło: Microsoft-Windows-Kernel-EventTracing
Data: 2013-09-15 03:16:16
Identyfikator zdarzenia:3
Kategoria zadania:Sesja
Poziom: Błędy
Słowa kluczowe:Sesja
Użytkownik: SYSTEM
Komputer: -Komputer
Opis:
Sesja „{c9600c52-0948-4f81-aa44-39b5d8912371}” została zatrzymana z powodu następującego błędu: 0xC0000188
Kod XML zdarzenia:
3
0
2
2
14
0x8000000000000010
12
Robert-Komputer
C:\Windows\AppCompat\Programs\Install\INSTALL_0_{2bf282e8-674b-4fd8-8c41-9ee424790c1a}.etl
3221225864
5
Data: 2013-09-14 17:48:58
Poziom: Błędy
Użytkownik: SYSTEM
Komputer: Komputer
Opis:
Sesja „{1dc941ad-8867-4baa-b1cd-2b2411eed3cf}” została zatrzymana z powodu następującego błędu: 0xC0000188
Kod XML zdarzenia:
3
0
2
2
14
0x8000000000000010
8
Robert-Komputer
C:\Windows\AppCompat\Programs\Install\INSTALL_0_{88d6f507-3e03-4551-8ba4-0918117026c6}.etl
3221225864
5
