Bluescreen reset kompa problem z minidump
witam mam probem , dzisiaj komputer zaczal sie resetowac i pokazywac bluescreena. odczytalem plik minidump ktory sie zapisal ale nic z tego nie rozumiem. pomoze ktos? wklejam to co sie wyswietlilo:
Microsoft ® Windows Debugger Version 6.11.0001.404 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Tue May 10 13:21:14.609 2011 (GMT+2)
System Uptime: 0 days 2:48:21.338
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {0, 2, 1, 80522704}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+4b704 )
Followup: MachineOwner
Spróbuj odczytać plik minidmp tym programem http://forum.dobreprogramy.pl/szukanie-przyczyny-bsod-pomoca-bluescreenview-t376739.html i podaj typ oraz kod błędu.
Zrobilem tym programem i wyszlo takie cos: http://imageshack.us/photo/my-images/705/dmpd.png/
Cytat zaczerpnięty z tego forum: http://forum.dobreprogramy.pl/ekran-smierci-tzw-blue-screen-t445558.html#p2821905 Tak ogólnie o tym, ale jako takie rozwiązania masz podane…
komp dziala normalnie a nic nie robilem… nie wiem juz o co tu chodzi, no coz dzieki, na razie jest ok.
Dodane 13.05.2011 (Pt) 13:43
problem dzisiaj zaczal sie powtarzac. jak mam sprawdzic ta pamiec, albo czy mam wadliwy sterownik?
