mam taki problem instaluje normalnie Dooma 3 a gdy chce uruchomic w konsoli wyskakuje mi;
“ERROR: Aktualna kombinacja karty grafiki / sterownika nie obsługuje niezbędnych opcji.”
A Dokadny wpis z konsoli wygląa tak:
DOOM 1.0.1282 win-x86 Sep 16 2004 16:45:51
2194 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
1024 MB System Memory
256 MB Video Memory
Winsock Initialized
Hostname: marek-74d0dff06
IP: 192.168.50.1
IP: 83.5.83.75
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Gry\Doom III\base\game00.pk4 with checksum 0x7dafc4d4
Loaded pk4 C:\Gry\Doom III\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Gry\Doom III\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Gry\Doom III\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Gry\Doom III\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Gry\Doom III\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Gry\Doom III\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Gry\Doom III\base\zpak001.pk4 with checksum 0x441b6af2
Current search path:
C:\Gry\Doom III/base
C:\Gry\Doom III\base\zpak001.pk4 (1448 files)
C:\Gry\Doom III\base\pak005.pk4 (63 files)
C:\Gry\Doom III\base\pak004.pk4 (5137 files)
C:\Gry\Doom III\base\pak003.pk4 (4676 files)
C:\Gry\Doom III\base\pak002.pk4 (6120 files)
C:\Gry\Doom III\base\pak001.pk4 (8972 files)
C:\Gry\Doom III\base\pak000.pk4 (2698 files)
C:\Gry\Doom III\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5151 strings read from strings/english.lang
Couldn’t open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn’t exec autoexec.cfg
5151 strings read from strings/polish.lang
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
…registered window class
…registered fake window class
…initializing QGL
…calling LoadLibrary( ‘opengl32’ ): succeeded
Couldn’t find proc address for: wglGetExtensionsStringARB
Couldn’t find proc address for: wglSwapIntervalEXT
Couldn’t find proc address for: wglGetPixelFormatAttribivARB
Couldn’t find proc address for: wglGetPixelFormatAttribfvARB
Couldn’t find proc address for: wglChoosePixelFormatARB
Couldn’t find proc address for: wglCreatePbufferARB
Couldn’t find proc address for: wglGetPbufferDCARB
Couldn’t find proc address for: wglReleasePbufferDCARB
Couldn’t find proc address for: wglDestroyPbufferARB
Couldn’t find proc address for: wglQueryPbufferARB
Couldn’t find proc address for: wglBindTexImageARB
Couldn’t find proc address for: wglReleaseTexImageARB
Couldn’t find proc address for: wglSetPbufferAttribARB
…calling CDS: ok
…created window @ 0,0 (640x480)
Initializing OpenGL driver
…getting DC: succeeded
…PIXELFORMAT 7 selected
…creating GL context: succeeded
…making context current: succeeded
------- Input Initialization -------
Initializing DirectInput…
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X…GL_ARB_multitexture not found
X…GL_ARB_texture_env_combine not found
X…GL_ARB_texture_cube_map not found
X…GL_ARB_texture_env_dot3 not found
X…GL_ARB_texture_env_add not found
X…GL_ARB_texture_non_power_of_two not found
X…GL_ARB_texture_compression not found
X…GL_EXT_texture_filter_anisotropic not found
X…GL_EXT_texture_lod not found
X…GL_1.4_texture_lod_bias not found
X…GL_EXT_shared_texture_palette not found
X…GL_EXT_texture3D not found
X…GL_EXT_stencil_wrap not found
X…GL_NV_register_combiners not found
X…GL_EXT_stencil_two_side not found
X…GL_ATI_separate_stencil not found
X…GL_ATI_fragment_shader not found
X…GL_ARB_vertex_buffer_object not found
X…GL_ARB_vertex_program not found
X…GL_ARB_fragment_program not found
Error during initialization
Shutting down OpenGL subsystem
…wglMakeCurrent( NULL, NULL ): success
…deleting GL context: success
…releasing DC: success
…destroying window
…resetting display
…shutting down QGL
…unloading OpenGL
Bardzo Prosze O Pomoc,Stara giera ale podobno wymiata,Pozdro
