CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.1.0
Monitoring
Mainboard Model SAMSUNG_NP1234567890 (0x00000528 - 0xE8C92AD2)
LPCIO
Hardware Monitors
Hardware monitor ACPI
Temperature 0 54°C (129°F) [0xCC8] (TZ00)
Temperature 1 54°C (129°F) [0xCC8] (TZ01)
Hardware monitor Battery
Voltage 0 12.43 Volts [0x308A] (Current Voltage)
Capacity 0 57720 mWh [0xE178] (Designed Capacity)
Capacity 1 57720 mWh [0xE178] (Full Charge Capacity)
Capacity 2 56566 mWh [0xDCF6] (Current Capacity)
Level 0 n.a. [0x64] (Wear Level)
Level 1 98 pc [0x62] (Charge Level)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.89 Volts [0x377] (VIN0)
Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
– Core 0
– Thread 0 0
– Thread 1 1
– Core 1
– Thread 0 2
– Thread 1 3
– Core 2
– Thread 0 4
– Thread 1 5
– Core 3
– Thread 0 6
– Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.241 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 3610QM
Codename Ivy Bridge
Specification Intel® Core i7-3610QM CPU @ 2.30GHz
Package (platform ID) Socket 988B rPGA (0x4)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 45 Watts
Core Speed 1198.2 MHz
Multiplier x FSB 12.0 x 99.8 MHz
Stock frequency 2300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 23x
Max turbo ratio 33x
Max efficiency ratio 12x
Min Power 36 Watts
O/C bins none
Ratio 1 core 33x
Ratio 2 cores 32x
Ratio 3 cores 31x
Ratio 4 cores 31x
TSC 2296.5 MHz
APERF 3090.6 MHz
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020101h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
Display name \.\DISPLAY1
Name Intel® HD Graphics 4000
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x144D)
Model ID 0x0166 (0xC0D1)
Display adapter 1
Name NVIDIA GeForce GT 650M
Revision A2
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x144D)
Model ID 0x0FD1 (0xC0D1)
