Ness
(Gnessdiablo)
2 Marzec 2010 19:23
#1
Witam mam problem z wyzej wymienionymi procesami, sciagnalem OTL i malwarebytes i zrobilem skanowanie i usunalem to co wyskoczylo, uruchomilem kompa ponowanie, niemoge teraz wejsc na zaden dysk bo wyskakuje mi zeby go otworzyc wiebrz program z listy.
Oto logi: http://wklej.org/id/289175/
prosze o pomoc
deFco247
(deFco247)
2 Marzec 2010 20:46
#2
Wyłącz i włącz Przywracanie Systemu na wszystkich dyskach. Instrukcja XP .
W białe dolne okno Custom Scans/Fixes w OTL wklej:
:Processes Explorer.EXE :OTL O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - C:\autorun.inf – [NTFS] O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - E:\autorun.inf – [NTFS] O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - G:\autorun.inf – [NTFS] O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - H:\autorun.inf – [NTFS] O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - I:\autorun.inf – [NTFS] O32 - AutoRun File - [2010-03-02 20:13:49 | 000,000,053 | RHS- | M] () - J:\autorun.inf – [NTFS] :Reg [-HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced] “SuperHidden”=dword:00000001 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced] “Hidden”=dword:00000001 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced] “ShowSuperHidden”=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL] “CheckedValue”=dword:00000001 [-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\SuperHidden\Policy\DontShowSuperHidden] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\SuperHidden\Policy\DontShowSuperHidden] @="" :Files C:\s1.exe E:\s1.exe G:\s1.exe H:\s1.exe I:\s1.exe J:\s1.exe :Commands [emptytemp] [start explorer]
Run Fix . Restart, jeśli będzie potrzebny.
Potem log z usuwania (raport, który wyskoczy po usuwaniu OTL-em) oraz nowy log robiony opcją Run Scan .
Usuń infekcje z pendrive lub kart pamięci za pomocą Flash Disinfector lub Panda USB Vaccine .
Lub format.
Ness
(Gnessdiablo)
2 Marzec 2010 21:07
#3
Wkleiłem to ci napisales i tutaj jest log z tego:
http://wklej.org/id/289269/
a tutaj nowy log ze skana:
http://wklej.org/id/289273/
pobralem i uruchomilem ten program Flash Disinfector tak jak było w instrukcji
wlaczyc juz przywracanie systemu? powiedziałbys mi jakim cudem tyle miejsca na dysku C sie nagle zrobilo?
tak btw, wielkie dzieki za pomoc
deFco247
(deFco247)
2 Marzec 2010 21:10
#4
Tak. Zwolniło się miejsce, bo wyłaczyłeś przywracanie, które tyle zajmowało miejsca.
W logu już nic nie widać.
W OTL kliknij CleanUp .
Wykonaj pełny skan Malwarebytes’ Anti-Malware - znalezione obiekty usuń.
Gdy będą wirusy pokaż raport po usuwaniu.
Wyczyść rejestr i dysk CCleaner oraz wyłącz nim zbędniki z autostartu (Narzędzia -> Autostart).
Ness
(Gnessdiablo)
2 Marzec 2010 21:15
#5
mam jeszcze jedno pytanko takie szybkie, zrobie to jutro bo juz wychodza jezeli mam system tylko na jednym dysku to nie musze miec przywracania systemu zeby monitorowalo wszystkie dyski prawda?
deFco247
(deFco247)
2 Marzec 2010 21:17
#6
Nie rozumiem o co CI chodzi.
Pisz jasniej.
Ness
(Gnessdiablo)
2 Marzec 2010 21:24
#7
Widziałem w tej opcji (przywracanie systemu) ze jest tam napisane ( jak jest wlaczona) ze monitoruje wszystkie dyski, czy da sie zrobic tak ( albo czy mozna ) zeby monitorowalo tylko dysk C ( tam mam jeden system reszta to muly ) i czy wtedy bedzie wiecej wolnego miejsca na dysku C?
deFco247
(deFco247)
2 Marzec 2010 21:28
#8
Wystarczy zaznaczyć partycję w tej liście, kliknąć Ustawienia i masz opcje dotyczące ilości dysku przeznaczonego na przywracanie. Ustawienie na 0% powoduje całkowite wyłączenie przywracania dla tej partycji.
Ness
(Gnessdiablo)
3 Marzec 2010 12:39
#9
Oto log ze skana malware:
http://wklej.org/id/289452/
a to po usunieciu:
http://wklej.org/id/289453/
Czy jeszcze cos mam zrobic? Jakiego antyvira bys mi polecil?
deFco247
(deFco247)
3 Marzec 2010 13:23
#10
Antywirusa ze swojej strony raczej nie polecę, gdyż sam nie używam takiego oprogramowania.
Przeszukaj forum, tematów z tego typu pytaniem było już kilka…
Ness
(Gnessdiablo)
3 Marzec 2010 13:25
#11
ostatnie pytanie i zamykam temat, skad moglbym taka wiedze nabyc jak ty, zebym mogl sam naprawiac bledy w systemie?
