Kontroler wideo i problem z grafiką
(Karasplock) #1
Proszę o rade.
w menadżerze urządzeń przy kontrolerze wideo zgodny z VGA mam znak zapytania.
Poza tym ekran mi faluje co mam zrobić.
Chyba za duzo skopiowałem ale lepiej więcej niż za mało
Aha, i jeszcze problem z dxwiękiem przy grach
CzTime of this report: 4/13/2009, 20:33:31
       Machine name: B-4135B33DC5104
   Operating System: Windows XP Professional (5.1, Build 2600) Dodatek Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
           Language: Polish (Regional Setting: Polish)
System Manufacturer: GBT___
       System Model: NVDAACPI
               BIOS: Award Modular BIOS v6.00PG
          Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, MMX, 3DNow (2 CPUs), ~2.7GHz
             Memory: 2048MB RAM
          Page File: 272MB used, 3667MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
        Card name:
     Manufacturer:
        Chip type:
         DAC type:
       Device Key: Enum\
   Display Memory: n/a
     Current Mode: 1280 x 1024 (32 bit) (1Hz)
          Monitor:
  Monitor Max Res:
      Driver Name: vga.dll
   Driver Version: 5.01.2600.0000 (Polish)
      DDI Version: unknown
Driver Attributes: Final Retail
 Driver Date/Size: 10/26/2001 18:29:20, 9344 bytes
      WHQL Logo'd: n/a
  WHQL Date Stamp: n/a
              VDD: n/d
         Mini VDD: vga.sys
    Mini VDD Date: 8/3/2004 23:07:08, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
        Vendor ID: 0x0000
        Device ID: 0x0000
        SubSys ID: 0x00000000
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel:
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Not Available
       D3D Status: Not Available
       AGP Status: Not Available
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: Realtek HD Audio output
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458E601&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RtkHDAud.sys
         Driver Version: 5.10.0000.5319 (English)
            WHQL Logo'd: n/a
          Date and Size: 11/2/2006 19:32:30, 4394496 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Full
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
            Description: Realtek HD Audio Input
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Realtek HD Digital input
  Default Sound Capture: No
  Default Voice Capture: No
              Cap Flags: 0x0
           Format Flags: 0x0
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  Mapowanie MIDI [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Syntezator SW Microsoft GS Wave [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Mysz
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Klawiatura
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0603, 0x00F2
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ G| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/17/2001 23:03:00, 4736 bytes
+-+ Urz| | Vendor/Product ID: 0x09DA, 0x000A
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 23:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 23:08:18, 24960 bytes
| | Driver: hid.dll, 8/4/2004 00:54:52, 20992 bytes
| | Driver: hidusb.sys, 8/17/2001 23:02:20, 9600 bytes
| +-+ Mysz zgodna z HID
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/4/2004 00:54:52, 23296 bytes
| | | Driver: mouhid.sys, 10/26/2001 17:57:56, 12160 bytes
Gameport Devices
PS/2 Devices
+ Urz| Vendor/Product ID: 0x0603, 0x00F2
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:38:02, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 00:38:00, 24960 bytes
+ Sterownik klawiatury serwera terminali
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:44:40, 40840 bytes
+ Sterownik myszy serwera terminali
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Po
DirectPlay Voice Codecs
Voxware VR12 1,4 kilobitów/s
Voxware SC06 6,4 kilobitów/s
Voxware SC03 3,2 kilobitów/s
MS-PCM 64 kilobitów/s
MS-ADPCM 32.8 kilobitów/s
Microsoft GSM 6.10 13 kilobitów/s
TrueSpeech(TM) 8.6 kilobitów/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 1.8 GB
Total Space: 5.0 GB
File System: NTFS
      Model: ST3250410AS
      Drive: D:
 Free Space: 105.1 GB
Total Space: 115.0 GB
File System: NTFS
      Model: ST3250410AS
      Drive: E:
 Free Space: 108.9 GB
Total Space: 118.5 GB
File System: NTFS
      Model: ST3250410AS
      Drive: F:
      Model: HL-DT-ST DVDRAM GH20LS15
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Polish), 8/3/2004 22:59:54, 49536 bytes
System Devices
     Name: Kontroler wideo (zgodny z VGA)
Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_34821458&REV_A1\4&154B9167&0&0078
   Driver: n/a
     Name: NVIDIA nForce 590/570/550 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_B0021458&REV_A3\3&2411E6FE&0&2A
   Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 17:52:28, 100736 bytes
   Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
   Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
   Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 14:01:20, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_B0021458&REV_A3\3&2411E6FE&0&29
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_B0021458&REV_A3\3&2411E6FE&0&28
     Name: Mostek (bridge) standardu PCI do PCI-do-PCI
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A3\3&2411E6FE&0&78
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (Polish), 8/4/2004 00:34:12, 68608 bytes
     Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_E0001458&REV_A3\3&2411E6FE&0&40
   Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0002.5521 (English), 3/22/2006 14:24:02, 18944 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 5.00.0005.5521 (English), 3/22/2006 14:23:40, 1068800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 5.00.0001.5521 (English), 3/22/2006 14:23:18, 261120 bytes
   Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 3/22/2006 14:21:44, 10240 bytes
   Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 3/22/2006 14:21:44, 10240 bytes
   Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 3/14/2006 21:45:22, 35840 bytes
     Name: Sterownik magistrali Microsoft UAA dla High Definition Audio
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_A0021458&REV_A2\3&2411E6FE&0&31
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 18:07:18, 138752 bytes
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&30
     Name: Standardowy podwójny kontroler PCI IDE
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_50021458&REV_A1\3&2411E6FE&0&20
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Polish), 8/3/2004 22:59:42, 25088 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Polish), 10/26/2001 17:56:42, 3456 bytes
     Name: Standardowy rozszerzony kontroler hosta PCI to USB
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_50041458&REV_A2\3&2411E6FE&0&11
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Polish), 8/4/2004 02:44:14, 77312 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:44:00, 7168 bytes
     Name: Standardowy kontroler OpenHCD hosta USB
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_50041458&REV_A1\3&2411E6FE&0&10
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 17024 bytes
     Name: Standardowy kontroler RAM PCI
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_50011458&REV_A2\3&2411E6FE&0&00
   Driver: n/a
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_0C111458&REV_A3\3&2411E6FE&0&09
   Driver: n/a
     Name: Mostek (bridge) standardu PCI do ISA
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A3\3&2411E6FE&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Polish), 10/26/2001 17:47:26, 36224 bytes
     Name: Kontroler hosta Texas Instruments IEEE 1394 zgodny z OHCI
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_10001458&REV_00\4&2BE4B97F&0&5030
   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:10, 61056 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 53248 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:54:52, 61824 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:54:52, 60800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 23:46:40, 6400 bytes
     Name: Mostek (bridge) standardu PCI do CPU hosta
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
   Driver: n/a
DirectX Components
   ddraw.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/17/2001 22:53:20 10496 bytes
    d3d8.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:27:36 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 34816 bytes
   dplay.dll: 5.00.2134.0001 Polish Final Retail 10/26/2001 18:29:28 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 229888 bytes
dpmodemx.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 24064 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 10/26/2001 18:29:28 42768 bytes
dpwsockx.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:44:20 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:44:20 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:42:44 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:42:44 3584 bytes
 dpvoice.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 212992 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:44:20 83456 bytes
  dpvvox.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 116736 bytes
  dpvacm.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 60928 bytes
dpserial.dll: 5.00.2134.0001 Polish Final Retail 10/26/2001 18:29:28 54032 bytes
  dinput.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 163328 bytes
 dinput8.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 185856 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 44032 bytes
diactfrm.dll: 5.01.2600.0000 Polish Final Retail 10/26/2001 18:29:28 394752 bytes
     joy.cpl: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:44:30 69120 bytes
   gcdef.dll: 5.01.2600.0000 Polish Final Retail 10/26/2001 18:29:30 77312 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:54:52 35328 bytes
  dsound.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:58 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:58 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 72704 bytes
  dmusic.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:56 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:56 82432 bytes
   dx7vb.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:58 619008 bytes
   dx8vb.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:58 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:43:58 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 10/26/2001 18:29:34 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:44:02 1028096 bytes
 wsock32.dll: 5.01.2600.2180 Polish Final Retail 8/4/2004 00:44:16 24064 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:43:54 70656 bytes
 devenum.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:43:56 59904 bytes
  dxmasf.dll: 6.04.0009.1125 Polish Final Retail 8/4/2004 00:43:58 499229 bytes
mciqtz32.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:02 35328 bytes
 mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:44:30 148992 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:44:04 14336 bytes
  encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:43:58 20480 bytes
    qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 02:45:04 221184 bytes
    qcap.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:10 192512 bytes
     qdv.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:10 279040 bytes
    qdvd.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:10 386048 bytes
   qedit.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:10 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:43:16 733696 bytes
  quartz.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:10 1291264 bytes
 strmdll.dll: 4.01.0000.3928 Polish Final Retail 8/4/2004 00:44:14 246302 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:44:30 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:44:30 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:44:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:44:02 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:44:02 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:44:02 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:44:02 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:44:30 154624 bytes
mswebdvd.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:06 204288 bytes
      ks.sys: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:15:22 140928 bytes
  ksproxy.ax: 5.03.2600.2180 Polish Final Retail 8/4/2004 01:44:30 130048 bytes
  ksuser.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 01:44:02 4096 bytes
  stream.sys: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:58:40 5376 bytes
   mspqm.sys: 5.01.2600.2180 Polish Final Retail 8/3/2004 23:58:42 4992 bytes
 mskssrv.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:58:42 7552 bytes
  swenum.sys: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:54:52 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:44:30 118272 bytes
msvidctl.dll: 6.05.2600.2180 Polish Final Retail 8/4/2004 00:44:06 1431552 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:44:30 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:54:52 17408 bytes
wstdecod.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:44:16 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.11.0003.0007
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
PP MPEG-1 Splitter,0x00200000,1,2,ppM1Splter.ax,2.02.0000.3710
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.11.0003.0007
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.11.0003.0007
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.11.0003.0007
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.11.0003.0007
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,CLEdtKrn.dll,3.00.0000.1508
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0004.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.3909
CyberLink AudioCD Filter (PDVD7),0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.2329
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.00.0000.1705
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder (PDVD7),0x00601000,1,1,CLAud.ax,6.01.0000.4227
PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.0000.3313
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
CyberLink Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.0905
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00400000,1,1,NeResize.ax,4.11.0003.0007
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
CyberLink Audio Effect (PDVD7),0x00200000,1,1,CLAudFx.ax,6.00.0000.4111
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
PP Dump Dispatch Filter,0x00200000,1,0,PPDumpDispatch.ax,1.02.0001.2412
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
MPEG-2 PSI Reader Filter,0x00200000,0,0,Mpeg2PsiReader.ax,1.00.0000.0004
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.11.0003.0007
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0007
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
PP Dump Filter,0x00200000,1,0,ppDump.ax,3.00.0000.3322
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.11.0003.0007
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.11.0003.0007
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.11.0003.0007
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.11.0003.0007
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.11.0003.0007
CyberLink Video/SP Decoder(PDVD7 HomeNetwork),0x00200000,2,3,CLVSD.ax,6.00.0000.3313
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.11.0003.0007
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.11.0003.0007
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.11.0003.0007
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.11.0003.0007
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.11.0003.0007
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,1,2,NeVideoHD.ax,4.11.0003.0007
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.11.0003.0007
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.11.0003.0007
PP TL MPEG Splitter,0x00200000,1,2,ppTLMSplter.ax,3.01.0000.1704
CyberLink Demux (PDVD7),0x00602000,1,0,CLDemuxer.ax,1.00.0000.4528
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3022
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.11.0003.0007
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.2910
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.11.0003.0007
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CyberLink Line21 Decoder (PDVD7),0x00200000,0,2,CLLine21.ax,4.00.0000.7602
PP DV Reader Filter,0x00200000,0,1,ppDVMRd.ax,1.02.0009.0021
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.3516
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0004.0000
MPEG-2 Stream Reader Filter,0x00200000,0,0,Mpeg2StreamReader.ax,1.04.0000.0000
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.0907
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.11.0003.0007
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.11.0003.0007
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.2820
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.11.0003.0007
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,2.00.0000.0616
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,14,NeDVD.ax,4.11.0003.0007
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.11.0003.0007
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
CyberLink Push-Mode CLStream (PDVD7),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1627
CyberLink Audio Decoder (PDVD7 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3816
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.11.0003.0007
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0007
CyberLink Audio Spectrum Analyzer (PDVD7),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.11.0003.0007
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.11.0003.0007
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
CyberLink Demultiplexer,0x00200000,1,0,ppDemuxer.ax,1.00.0000.3322
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.11.0003.0007
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0007
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
Nero FLV Splitter,0x00600000,1,1,NeFLVSplitter.ax,4.11.0003.0007
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVsd.ax,8.00.0000.1918
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.11.0003.0007
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.11.0003.0007
PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.00.0000.1223
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
PP Audio Decoder,0x00200000,1,1,claud.ax,6.00.0000.3403
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink DVD Navigator (PDVD7),0x00600000,0,3,CLNavX.ax,7.00.0000.3112
CyberLink TimeStretch Filter (PDVD7),0x00200000,1,1,clauts.ax,1.00.0000.5423
PP MPEG-2 Splitter,0x00200000,1,2,ppM2Splter.ax,2.02.0000.3710
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Cyberlink SubTitle Importor (PDVD7),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.11.0003.0007
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1415
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.11.0003.0007
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.11.0003.0007
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
CyberLink MPEG-4 Splitter (PDVD7),0x00600000,1,2,clm4splt.ax,1.00.0000.3229
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.11.0003.0007
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,4.11.0003.0007
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.11.0003.0007
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.11.0003.0007
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.11.0003.0007
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.11.0003.0007
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.0000.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.3328
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.0000
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.1905
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.11.0003.0007
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.11.0003.0007
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.11.0003.0007
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.11.0003.0007
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,4.11.0003.0007
PP Video Stabilizer,0x00200000,1,1,CLVideoStabilizer.ax,1.00.0000.1017
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.11.0003.0007
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,4.11.0003.0007
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
PP MPEG Video Encoder,0x00200000,1,1,ppVidEnc.ax,6.00.0001.2714
CyberLink Demux (PDVD7 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.11.0003.0007
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0007
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.11.0003.0007
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.11.0003.0007
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
CyberLink Streamming Filter (PDVD7),0x00200000,0,1,CLStream.ax,1.01.0000.2902
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
PrzeksztaMicrosoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Syntezator tablicy d0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Koder-dekoder Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Realtek HD Digital input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Syntezator SW Microsoft GS Wave,0x00200000,1,0,quartz.dll,6.05.2600.2180
UrzRealtek HD Digital input,0x00200000,1,1,,5.03.2600.2180
,0x00000000,0,0,,
UrzRealtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
UrzMicrosoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
CyberLink Audio Renderer (PDVD7),0x00200000,1,0,cladr.ax,6.00.0000.3916
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,18,1,,5.03.2600.2180
(Blind227) #2
Zainstaluj odpowiednie sterowniki i powinno być ok.
(Karasplock) #3
sterowniki pobieram i non stop nic
(Blind227) #4
Jaka masz karte graficzną ??
Ps jak bawiłeś sę w biosie płyty głownej to przywróć domyślne ustawienia
(Karasplock) #5
no ja się nie bawiłem kltos robił i popsuł.
A jak to zmienic w biosie?
-- Dodane 14.04.2009 (Wt) 19:59 --
Ge Force Gtx295 Ge Force 200Series
