Mam problem z nagrywaniem płytki w zasadzie to płytki z Mp3-ujkami
zapsułem już 3 plyty i niewiem w czym tkwi błąd???
W nero zapisalem log( moze ktos cos z niego odczyta :P):
WWW
1A20-620E-0010-2363-8673-7062*
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 2005-12-22 14:26:54
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
(Nero Express)
Recorder: Version: DL11 - HA 1 TA 1 - 6.6.1.4
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: < ATAPI 52X CDROM >Version: 1.40 - HA 1 TA 0 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV2044D atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG WU32165A (2.1GB) atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : ATAPI 52X CDROM atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
ATAPI 52X CDROM G: CDRom0
HL-DT-ST DVDRAM GSA-4167B H: CDRom1
AXV CD/DVD-ROM J: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 32505856 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 191MB (196080kB)
Free physical memory: 60MB (61704kB)
Memory in use : 68 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
29.3.2006
CD-ROM (MP3)
21:21:22 #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
21:21:23 #2 Text 0 File Burncd.cpp, Line 3012
Włączono System ochrony zapisu
21:21:23 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 31744KB of Memory
21:21:23 #4 Text 0 File Reader.cpp, Line 124
Reader running
21:21:23 #5 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4167B running
21:21:23 #6 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
21:21:23 #7 Text 0 File Burncd.cpp, Line 3305
Turn on Track-At-Once, using CD-R/RW media
21:21:33 #8 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 356316 ( 79:12.66)
21:21:33 #9 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
21:21:33 #10 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: HL-DT-ST DVDRAM GSA-4167B
21:21:33 #11 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
21:21:33 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 356317 (356317) = #356317/79:10.67
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 356315 blocks [HL-DT-ST DVDRAM GSA-4167B]
21:21:33 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [HL-DT-ST DVDRAM GSA-4167B] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 730044416, ISRC ""
DAO layout:
__Start_|____ Track_|_Idx_|_CtrlAdr_|_RecDep __________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
356317 | lead-out | 1 | 0x41 | 0x00
21:21:33 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127
Removed 2 run-out blocks from end of track 1. Length: 356317 -> 356315.
21:21:33 #15 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
21:21:33 #16 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
21:21:33 #17 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
21:21:33 #18 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
21:21:33 #19 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
21:21:33 #20 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 40x (6 000 KB/s)
21:21:34 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:21:34 #22 Text 0 File Mmc.cpp, Line 21840
Set BUFE: Buffer underrun protection -> ON
21:22:24 #23 SPTI -1040 File SCSIPassThrough.cpp, Line 289
H: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1040)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x10
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 57 20 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 10 34 1D 04 80 10
Buffer x095d0000: Len x10000
0x53 11 FE 7F AA 41 F6 84 47 61 16 E1 CA 4E C7 C1
0xA4 CA E8 BB 8E D2 69 B5 CC CF AB 19 FF 7F BD C9
0xE1 B8 DB 34 DC 61 04 2E 38 65 6C 84 39 35 91 9D
21:22:24 #24 CDR -1040 File Writer.cpp, Line 311
Illegal block size for command
H: HL-DT-ST DVDRAM GSA-4167B
21:22:24 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:22:25 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
21:22:25 #27 SPTI -1040 File SCSIPassThrough.cpp, Line 289
Sense Code: 0x10
Sense Qual: 0x00
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 10 34 1D 04 80 10
21:22:25 #28 CDR -1040 File WriterStatus.cpp, Line 197
21:22:25 #29 TRANSFER -18 File WriterStatus.cpp, Line 197
Could not perform EndTrack
21:22:25 #30 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
21:22:25 #31 TRANSFER -18 File WriterStatus.cpp, Line 200
21:22:25 #32 Text 0 File Mmc.cpp, Line 16608
start Close Session
21:22:25 #33 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 40x (6 000 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 2005-12-22 14:26:54
File 'Drivers\InCDfs.SYS': Ver=4, 3, 18, 0, size=99584 bytes, created 2005-07-08 17:17:54 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 18, 0, size=29696 bytes, created 2005-07-08 17:17:36 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 18, 0, size=8704 bytes, created 2005-07-08 17:17:56 (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
POMOCY! ![]()
