mavis1978
(Marcinkozlowski29)
17 Styczeń 2010 19:15
#1
Leon1
(Leon$)
17 Styczeń 2010 19:48
#2
Start >> uruchom >> Combofix /uninstall
OTL w oknie Custom Scans-Fixes wklej następujący skrypt:
:Processes explorer.exe :OTL PRC - [2010/01/16 18:13:42 | 00,558,592 | ---- | M] (Microsoft Corporation) – C:\Documents and Settings\xp\Local Settings\temp\winhlp64.exe PRC - [2010/01/16 18:13:26 | 00,712,704 | ---- | M] (Microsoft Corporation) – C:\Documents and Settings\xp\Local Settings\temp\cls_pack.exe O2 - BHO: (no name) - {1458C465-55BF-4972-A78F-3B3AAA6C4B33} - No CLSID value found. O2 - BHO: (no name) - {3DFB7B68-8740-41F0-94B9-E94A4BC9654D} - No CLSID value found. O2 - BHO: (no name) - {79B6BB3A-F1E4-4BB8-989A-A12AD29F24C6} - No CLSID value found. O2 - BHO: (no name) - {A52AA0CF-9EFD-4241-AC18-E187752BF0CA} - No CLSID value found. O2 - BHO: (no name) - {ACA90C04-815C-4A20-8ADF-10D0A211012F} - No CLSID value found. O2 - BHO: (no name) - {be3122c6-9cc1-4dcc-86cf-d7891d526b5c} - No CLSID value found. O2 - BHO: (no name) - {E79046EE-42BB-4DF4-960C-DE0A7BD25A31} - No CLSID value found. O4 - HKLM…\Run: [Fvaticacepep] C:\WINDOWS\unuhimuhabuc.DLL File not found O4 - HKLM…\Run: [sigmatelSysTrayApp] File not found O4 - HKCU…\Run: [cls_pack.exe] C:\Documents and Settings\xp\Local Settings\temp\cls_pack.exe (Microsoft Corporation) O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/fl … rashim.cab (Reg Error: Key error.) O21 - SSODL: benugozad - {2a50b785-aee9-42ec-a155-c64a33a48149} - CLSID or File not found. O21 - SSODL: jewewaziw - {4ce62cef-3bdd-4f69-bffb-dfe681a44cee} - CLSID or File not found. O21 - SSODL: ripokoyak - {f850bf47-f83e-41c8-b300-0939cabb37ee} - C:\WINDOWS\System32\nosewoke.dll File not found O21 - SSODL: sewefuhor - {56617fd0-785b-4dbb-9959-9fed78c298f8} - CLSID or File not found. O22 - SharedTaskScheduler: {4ce62cef-3bdd-4f69-bffb-dfe681a44cee} - mujuzedij - Reg Error: Key error. File not found O22 - SharedTaskScheduler: {56617fd0-785b-4dbb-9959-9fed78c298f8} - mujuzedij - Reg Error: Key error. File not found O22 - SharedTaskScheduler: {f850bf47-f83e-41c8-b300-0939cabb37ee} - gahurihor - C:\WINDOWS\System32\nosewoke.dll File not found O36 - AppCertDlls: dpnssfc - (C:\WINDOWS\system32\regerate.dll) - C:\WINDOWS\System32\regerate.dll File not found [2010/01/09 00:14:42 | 00,000,000 | -HSD | C] – C:\RECYCLER :Reg [-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2] :Commands [emptytemp] [start explorer] [Reboot]
Kliknij w Run Fix. Zatwierdź restart komputera.
potem nowy log OTL
mavis1978
(Marcinkozlowski29)
17 Styczeń 2010 19:57
#3
http://wklej.org/id/264628/
oto nowy log juz po przeskanowaniu…co dalej? jak narazie cos sie polepszylo =D>
Leon1
(Leon$)
17 Styczeń 2010 20:05
#4
teraz przeskanuj OTL i pokaż nowy log
mavis1978
(Marcinkozlowski29)
17 Styczeń 2010 20:15
#5
oto nowy log po przeskanowaniu…http://wklej.org/id/264638/
Leon1
(Leon$)
17 Styczeń 2010 20:25
#6
:Processes explorer.exe :OTL O16 - DPF: {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinsta … s-i586.cab (Reg Error: Key error.) [2010/01/08 23:58:19 | 00,000,000 | —D | C] – C:\ComboFix [2010/01/08 23:44:43 | 00,000,000 | —D | C] – C:\Qoobox :Commands [emptytemp] [start explorer] [Reboot]
W OTL kilknij CleanUp
Pobierz CCleaner http://www.filehippo.com/download_ccleaner/
przeskanuj nim i wyczyść rejestr.
zrób optymalizacje uruchamiania
http://cybertrash.netarteria.pl/cyber/i … 378.0.html
Wyłącz I włącz przywracanie systemu na wszystkich dyskach.http://support.microsoft.com/kb/310405/pl
przeskanuj
Dr.WEB CureIt! http://www.dobreprogramy.pl/DrWEB-CureI … 12976.html
mavis1978
(Marcinkozlowski29)
17 Styczeń 2010 21:15
#7
Leon$ dzieki wielkie nie wszystko chyba sie dalo poprawic ale przynajmniej juz nie wyskakuja te debilne reklamy i przypomnienia o aktualizacji Malware Defense. Mozna juz tam jakos pracowac na kompie :lol: Pozdrawiam i jeszcze raz wielkie dzieki…a co do tego OTL to mi zniknelo z pulpitu gdzie sciagnalem i znowu mam ponowny problem ze sciagnieciem tego programu…
– Dodane 17.01.2010 (N) 22:42 –
Moze te logi cos pomoga
Dr.Web…http://wklej.org/id/264680/
System Repair Engineer…http://wklej.org/id/264681/
– Dodane 17.01.2010 (N) 22:58 –
co moze byc przyczyna tego ze nie moge sciagnac ponownie OTL? teraz gdy wchodze na podane przez was linki to wyskakuje ze nie ma takiej strony i nie ma znaczenia czy spod Firefoxa czy Explorera
– Dodane 17.01.2010 (N) 23:08 –
hello jest tu ktos?? ktos cokolwiek odpisze??
Gutek
(Gutek)
18 Styczeń 2010 00:44
#8
Zastosuj się do tego Tematu i zmień tytuł tematu na konkretny.
Pozdrawiam Gutek
