maciej321
(Maciej Rosinski)
17 Styczeń 2010 19:36
#1
Mam wielki problem z wirusami kmj.exe i inne… oraz nie moge uzyc funkcji dodaj i ukryj pliki… prosze o szybką pomoc …
Z pliku OTL:
http://www.wklejto.pl/54402
I EXTRAS:
http://www.wklejto.pl/54403
deFco247
(deFco247)
17 Styczeń 2010 19:54
#2
W białe dolne okno Custom Scans/Fixes w OTL wklej:
:Processes Explorer.EXE :OTL O32 - AutoRun File - [2010-01-17 19:33:46 | 00,000,053 | RHS- | M] () - D:\autorun.inf – [NTFS] O33 - MountPoints2{1ec770f0-dd9b-11de-9334-0018f32b3476}\Shell\AutoRun\command - “” = G:\e9naq.exe – File not found O33 - MountPoints2{1ec770f0-dd9b-11de-9334-0018f32b3476}\Shell\open\Command - “” = G:\e9naq.exe – File not found O33 - MountPoints2{1ec770f1-dd9b-11de-9334-0018f32b3476}\Shell\AutoRun\command - “” = H:\e9naq.exe – File not found O33 - MountPoints2{1ec770f1-dd9b-11de-9334-0018f32b3476}\Shell\open\Command - “” = H:\e9naq.exe – File not found O33 - MountPoints2{a33c4e6c-ee5d-11de-9357-0018f32b3476}\Shell\AutoRun\command - “” = G:\nx.exe – File not found O33 - MountPoints2{a33c4e6c-ee5d-11de-9357-0018f32b3476}\Shell\open\Command - “” = G:\nx.exe – File not found O33 - MountPoints2{b1f0f80f-e2a7-11de-933e-0018f32b3476}\Shell\AutoRun\command - “” = H:\kmj.exe – File not found O33 - MountPoints2{b1f0f80f-e2a7-11de-933e-0018f32b3476}\Shell\open\Command - “” = H:\kmj.exe – File not found O33 - MountPoints2{bc32b32c-ed72-11de-9356-0018f32b3476}\Shell\AutoRun\command - “” = G:\nymdik.exe – File not found O33 - MountPoints2{bc32b32c-ed72-11de-9356-0018f32b3476}\Shell\open\Command - “” = G:\nymdik.exe – File not found O33 - MountPoints2{f5cd1b9c-ebf9-11de-9354-0018f32b3476}\Shell\AutoRun\command - “” = G:\f2kmj.exe – File not found O33 - MountPoints2{f5cd1b9c-ebf9-11de-9354-0018f32b3476}\Shell\open\Command - “” = G:\f2kmj.exe – File not found :Commands [emptytemp] [start explorer]
Run Fix . Restart, jeśli będzie potrzebny.
Potem log z usuwania oraz nowy log robiony opcją Run Scan .
Przed kliknięciem Run Scan wklejasz w OTL taki tekst:
Leon1
(Leon$)
17 Styczeń 2010 20:04
#3
OTL w oknie Custom Scans-Fixes wklej następujący skrypt:
:Processes explorer.exe :OTL O32 - AutoRun File - [2010-01-17 19:33:46 | 00,000,053 | RHS- | M] () - D:\autorun.inf – [NTFS] :Files C:\e9naq.exe D:\e9naq.exe C:\nx.exe D:\nx.exe C:\kmj.exe D:\kmj.exe C:\nymdik.exe D:\nymdik.exe C:\f2kmj.exe D:\f2kmj.exe :Reg [-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2] [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List] “D:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData_jamp.exe”=- “D:\Gry\Counter-Strike 1.6_hl.exe”=- “C:\Documents and Settings\Maciek\Moje dokumenty\Pobieranie\Pulpit\MuProxyS4\Proxy.exe”=- “C:\Documents and Settings\Maciek\Moje dokumenty\Pobieranie\Simple_Hack_dla_1.05d\Simple Hack dla 1.05d.exe”=- “C:\Documents and Settings\Maciek\Pulpit\Nowy folder\Catastrphe\Catastrphe\Catastrophe.exe”=- “C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe”=- :Commands [emptytemp] [start explorer] [Reboot]
Kliknij w Run Fix. Zatwierdź restart komputera.
potem nowy log OTL
Wylecz pendriva lub kartę pamięci http://www.softpedia.com/get/Security/S … Tool.shtml
Flash Disinfector http://www.searchengines.pl/index.php?s … ntry369724
lub format
Frog
(Frog)
17 Styczeń 2010 20:05
#4
maciej321 , popraw tytuł tematu, używając przycisku
maciej321
(Maciej Rosinski)
17 Styczeń 2010 20:34
#5
Ah… dziekuje wszystko pięknie dziala, poza jednym pokarz]ukryj pliki… nadal nie dziala ;//
maciej321
(Maciej Rosinski)
17 Styczeń 2010 20:40
#7
Leon1
(Leon$)
17 Styczeń 2010 20:46
#8
Log wygląda na czysty
Pobierz CCleaner http://www.filehippo.com/download_ccleaner/
przeskanuj nim i wyczyść rejestr.
zrób optymalizacje uruchamiania
http://cybertrash.netarteria.pl/cyber/i … 378.0.html
W OTL kilknij CleanUp
Wyłącz I włącz przywracanie systemu na wszystkich dyskach.http://support.microsoft.com/kb/310405/pl
przeskanuj
Dr.WEB CureIt! http://www.dobreprogramy.pl/DrWEB-CureI … 12976.html
Otwórz notatnik i wklej
zapisz jako plik.reg >> wszystkie pliki
powstanie plik o takiej ikonie
w który dwa razy klikniesz potwierdzisz chęć dodania do rejestru potem restart
Gutek
(Gutek)
18 Styczeń 2010 00:44
#9
Zastosuj się do tego Tematu i zmień tytuł tematu na konkretny.
Pozdrawiam Gutek
maciej321
(Maciej Rosinski)
18 Styczeń 2010 08:12
#10
dobra dobra … jak widzicie to moje pierwsze posty… a wracając do tematu to zastosowałem sie do wszystkich wskazówek, aby jeszcze przeskanować dr.Webem…, lecz znam ten program i skanuje nim wiec nie powinno byc problemow…
Jeszcze raz stokrotne dzieki ;]
Jeśli jeszcze bede mial takie problemy napewno dam wam nabić posty :lol: :twisted:
