SQL=Table ‘mos_banner’ already exists: - - - - - - - - - - # $Id: mambo.sql,v 1.19 2005/02/16 15:44:24 stingrey Exp $ # Table structure for table mos_banner
CREATE TABLE mos_banner
( bid
int(11) NOT NULL auto_increment, cid
int(11) NOT NULL default ‘0’, type
varchar(10) NOT NULL default ‘banner’, name
varchar(50) NOT NULL default ‘’, imptotal
int(11) NOT NULL default ‘0’, impmade
int(11) NOT NULL default ‘0’, clicks
int(11) NOT NULL default ‘0’, imageurl
varchar(100) NOT NULL default ‘’, clickurl
varchar(200) NOT NULL default ‘’, date
datetime default NULL, showBanner
tinyint(1) NOT NULL default ‘0’, checked_out
tinyint(1) NOT NULL default ‘0’, checked_out_time
datetime NOT NULL default ‘0000-00-00 00:00:00’, editor
varchar(50) default NULL, custombannercode
text, PRIMARY KEY (bid
), KEY viewbanner
(showBanner
) ) TYPE=MyISAM AUTO_INCREMENT=1 = = = = = = = = = = SQL=Table ‘mos_bannerclient’ already exists: - - - - - - - - - - # Table structure for table mos_bannerclient
CREATE TABLE mos_bannerclient
( cid
int(11) NOT NULL auto_increment, name
varchar(60) NOT NULL default ‘’, contact
varchar(60) NOT NULL default ‘’, email
varchar(60) NOT NULL default ‘’, extrainfo
text NOT NULL, checked_out
time default NULL, editor
varchar(50) default NULL, PRIMARY KEY (cid
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_bannerfinish’ already exists: - - - - - - - - - - # Table structure for table mos_bannerfinish
CREATE TABLE mos_bannerfinish
( bid
varchar(10) NOT NULL default ‘’, name
varchar(50) NOT NULL default ‘’, impressions
varchar(50) NOT NULL default ‘’, datestart
datetime default NULL, dateend
datetime default NULL, PRIMARY KEY (bid
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_categories’ already exists: - - - - - - - - - - # Table structure for table mos_categories
CREATE TABLE mos_categories
( id
int(11) NOT NULL auto_increment, parent_id
int(11) NOT NULL default 0, title
varchar(50) NOT NULL default ‘’, name
varchar(255) NOT NULL default ‘’, image
varchar(100) NOT NULL default ‘’, section
varchar(50) NOT NULL default ‘’, image_position
varchar(10) NOT NULL default ‘’, description
text NOT NULL, published
int(11) unsigned NOT NULL default ‘0’, checked_out_time
varchar(50) default NULL, ordering
int(11) NOT NULL default ‘0’, access
tinyint(3) unsigned NOT NULL default ‘0’, count
int(11) NOT NULL default ‘0’, params
text NOT NULL, PRIMARY KEY (id
), KEY cat_idx
(section
,published
,access
), KEY idx_section
(section
), KEY idx_access
(access
), KEY idx_checkout
(checked_out
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_components’ already exists: - - - - - - - - - - # Table structure for table mos_components
CREATE TABLE mos_components
( id
varchar(50) NOT NULL default ‘’, link
varchar(255) NOT NULL default ‘’, menuid
int(11) unsigned NOT NULL default ‘0’, parent
int(11) unsigned NOT NULL default ‘0’, admin_menu_link
varchar(255) NOT NULL default ‘’, admin_menu_alt
varchar(255) NOT NULL default ‘’, option
varchar(50) NOT NULL default ‘’, ordering
int(11) NOT NULL default ‘0’, admin_menu_img
varchar(255) NOT NULL default ‘’, iscore
tinyint(4) NOT NULL default ‘0’, params
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_components
INSERT INTO mos_components
VALUES (1, ‘Bannery’, ‘’, 0, 0, ‘’, ‘Zarządzaj bannerami’, ‘com_banners’, 0, ‘js/ThemeOffice/component.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (2, ‘Wykaz bannerów’, ‘’, 0, 1, ‘option=com_banners’, ‘Aktywuj bannery, zobacz statystykę’, ‘com_banners’, 1, ‘js/ThemeOffice/edit.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (3, ‘Klienci’, ‘’, 0, 1, ‘option=com_banners&task=listclients’, ‘Zarządzaj klientami’, ‘com_banners’, 2, ‘js/ThemeOffice/categories.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (4, ‘Katalog WWW’, ‘option=com_weblinks’, 0, 0, ‘’, ‘Gromadzenie adresów witryn’, ‘com_weblinks’, 0, ‘js/ThemeOffice/globe2.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (5, ‘Odsyłacze’, ‘’, 0, 4, ‘option=com_weblinks’, ‘Przejrzyj swój zbiór adresów www’, ‘com_weblinks’, 1, ‘js/ThemeOffice/edit.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘6’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (6, ‘Kategorie www’, ‘’, 0, 4, ‘option=categories§ion=com_weblinks’, ‘Zarządzaj kategoriami odsyłaczy’, ‘’, 2, ‘js/ThemeOffice/categories.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘7’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (7, ‘Kontakty’, ‘option=com_contact’, 0, 0, ‘’, ‘Edytuj szczegóły kontaktów’, ‘com_contact’, 0, ‘js/ThemeOffice/user.png’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘8’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (8, ‘Wykaz kontaktów’, ‘’, 0, 7, ‘option=com_contact’, ‘Edytuj szczegóły kontaktów’, ‘com_contact’, 0, ‘js/ThemeOffice/edit.png’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘9’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (9, ‘Kategorie kontaktów’, ‘’, 0, 7, ‘option=categories§ion=com_contact_details’, ‘Zarządzaj kategoriami kontaktów’, ‘’, 2, ‘js/ThemeOffice/categories.png’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘10’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (10, ‘Strona główna’, ‘option=com_frontpage’, 0, 0, ‘’, ‘Dobierz pozycje na stronę startową’, ‘com_frontpage’, 0, ‘js/ThemeOffice/component.png’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘11’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (11, ‘Sondy’, ‘option=com_poll’, 0, 0, ‘option=com_poll’, ‘Zarządzaj sondami’, ‘com_poll’, 0, ‘js/ThemeOffice/component.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘12’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (12, ‘Nagłówki RSS’, ‘option=com_newsfeeds’, 0, 0, ‘’, ‘Zarządzaj nagłówkami RSS’, ‘com_newsfeeds’, 0, ‘js/ThemeOffice/component.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘13’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (13, ‘Wykaz witryn’, ‘’, 0, 12, ‘option=com_newsfeeds’, ‘Zarządzaj nagłówkami RSS’, ‘com_newsfeeds’, 1, ‘js/ThemeOffice/edit.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘14’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (14, ‘Kategorie’, ‘’, 0, 12, ‘option=com_categories§ion=com_newsfeeds’, ‘Zarządzaj kategoriami RSS’, ‘’, 2, ‘js/ThemeOffice/categories.png’, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘15’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (15, ‘Logowanie’, ‘option=com_login’, 0, 0, ‘’, ‘’, ‘com_login’, 0, ‘’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘16’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (16, ‘Wyszukiwarka’, ‘option=com_search’, 0, 0, ‘’, ‘’, ‘com_search’, 0, ‘’, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘17’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (17, ‘Syndicate’,’’,0,0,‘option=com_syndicate&hidemainmenu=1’,‘Manage Syndication Settings’,‘com_syndicate’,0,‘js/ThemeOffice/component.png’,0,’’) = = = = = = = = = = SQL=Duplicate entry ‘18’ for key 1: - - - - - - - - - - INSERT INTO mos_components
VALUES (18, ‘Korespondencja seryjna’, ‘’, 0, 0, ‘option=com_massmail&hidemainmenu=1’, ‘Roześlij poztę elektroniczną’, ‘com_massmail’, 0, ‘js/ThemeOffice/mass_email.png’, 0, ‘’) = = = = = = = = = = SQL=Table ‘mos_contact_details’ already exists: - - - - - - - - - - # Table structure for table mos_contact_details
CREATE TABLE mos_contact_details
( id
varchar(100) NOT NULL default ‘’, con_position
varchar(50) default NULL, address
text, suburb
varchar(50) default NULL, state
varchar(20) default NULL, country
varchar(50) default NULL, postcode
varchar(10) default NULL, telephone
varchar(25) default NULL, fax
varchar(25) default NULL, misc
mediumtext, image
varchar(100) default NULL, imagepos
varchar(20) default NULL, email_to
varchar(100) default NULL, default_con
tinyint(1) unsigned NOT NULL default ‘0’, published
tinyint(1) unsigned NOT NULL default ‘0’, checked_out
datetime NOT NULL default ‘0000-00-00 00:00:00’, ordering
text NOT NULL, user_id
int(11) NOT NULL default ‘0’, catid
tinyint(3) unsigned NOT NULL default ‘0’, PRIMARY KEY (id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_content’ already exists: - - - - - - - - - - # Table structure for table mos_content
CREATE TABLE mos_content
( id
int(11) unsigned NOT NULL auto_increment, title
varchar(100) NOT NULL default ‘’, title_alias
varchar(100) NOT NULL default ‘’, introtext
mediumtext NOT NULL, fulltext
mediumtext NOT NULL, state
tinyint(3) NOT NULL default ‘0’, sectionid
int(11) unsigned NOT NULL default ‘0’, mask
int(11) unsigned NOT NULL default ‘0’, catid
int(11) unsigned NOT NULL default ‘0’, created
datetime NOT NULL default ‘0000-00-00 00:00:00’, created_by
int(11) unsigned NOT NULL default ‘0’, created_by_alias
varchar(100) NOT NULL default ‘’, modified
datetime NOT NULL default ‘0000-00-00 00:00:00’, modified_by
datetime NOT NULL default ‘0000-00-00 00:00:00’, publish_up
datetime NOT NULL default ‘0000-00-00 00:00:00’, publish_down
datetime NOT NULL default ‘0000-00-00 00:00:00’, images
text NOT NULL, urls
text NOT NULL, attribs
text NOT NULL, version
int(11) unsigned NOT NULL default ‘1’, parentid
int(11) unsigned NOT NULL default ‘0’, ordering
int(11) NOT NULL default ‘0’, metakey
text NOT NULL, metadesc
text NOT NULL, access
int(11) unsigned NOT NULL default ‘0’, hits
int(11) unsigned NOT NULL default ‘0’, PRIMARY KEY (id
), KEY idx_section
(sectionid
), KEY idx_access
(access
), KEY idx_checkout
(checked_out
), KEY idx_state
(state
), KEY idx_catid
(catid
), KEY idx_mask
(mask
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_content_frontpage’ already exists: - - - - - - - - - - # Table structure for table mos_content_frontpage
CREATE TABLE mos_content_frontpage
( content_id
int(11) NOT NULL default ‘0’, ordering
int(11) NOT NULL default ‘0’, PRIMARY KEY (content_id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_content_rating’ already exists: - - - - - - - - - - # Table structure for table mos_content_rating
CREATE TABLE mos_content_rating
( content_id
int(11) NOT NULL default ‘0’, rating_sum
int(11) unsigned NOT NULL default ‘’, rating_count
int(11) unsigned NOT NULL default ‘0’, lastip
varchar(50) NOT NULL default ‘’, PRIMARY KEY (content_id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_core_log_items’ already exists: - - - - - - - - - - # Table structure for table mos_core_log_items
# To be implemented in Version 4.6 CREATE TABLE mos_core_log_items
( time_stamp
date NOT NULL default ‘0000-00-00’, item_table
varchar(50) NOT NULL default ‘’, item_id
int(11) unsigned NOT NULL default ‘0’ ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_core_log_searches’ already exists: - - - - - - - - - - # Table structure for table mos_core_log_searches
# To be implemented in Version 4.6 CREATE TABLE mos_core_log_searches
( search_term
varchar(128) NOT NULL default ‘’, hits
int(11) unsigned NOT NULL default ‘0’ ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_groups’ already exists: - - - - - - - - - - # Table structure for table mos_groups
CREATE TABLE mos_groups
( id
tinyint(3) unsigned NOT NULL default ‘0’, name
varchar(50) NOT NULL default ‘’, PRIMARY KEY (id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘0’ for key 1: - - - - - - - - - - # Dumping data for table mos_groups
INSERT INTO mos_groups
VALUES (0, ‘Public’) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - INSERT INTO mos_groups
VALUES (1, ‘Registered’) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_groups
VALUES (2, ‘Special’) = = = = = = = = = = SQL=Table ‘mos_mambots’ already exists: - - - - - - - - - - # Table structure for table mos_mambots
CREATE TABLE mos_mambots
( id
varchar(100) NOT NULL default ‘’, element
varchar(100) NOT NULL default ‘’, folder
varchar(100) NOT NULL default ‘’, access
tinyint(3) unsigned NOT NULL default ‘0’, ordering
int(11) NOT NULL default ‘0’, published
tinyint(3) NOT NULL default ‘0’, iscore
tinyint(3) NOT NULL default ‘0’, client_id
tinyint(3) NOT NULL default ‘0’, checked_out
datetime NOT NULL default ‘0000-00-00 00:00:00’, params
), KEY idx_folder
(published
,client_id
,access
,folder
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (1,‘Znacznik MOSImage {wstaw obraz]’,‘mosimage’,‘content’,0,-10000,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (2,‘Znacznik MOSPagebreak’,‘mospaging’,‘content’,0,10000,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (3,‘Akceptuj dane dodatki [Legacy Mambot Includer]’,‘legacybots’,‘content’,0,1,0,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (4,‘SEF [Przyjazne adresy URL]’,‘mossef’,‘content’,0,3,1,0,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (5,‘Ocenianie artykułów [MOS Rating]’,‘mosvote’,‘content’,0,4,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘6’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (6,‘Szukaj w artykułach’,‘content.searchbot’,‘search’,0,1,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘7’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (7,‘Szukaj w katalogu WWW’,‘weblinks.searchbot’,‘search’,0,2,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘8’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (8,‘Wstaw kod programu’,‘moscode’,‘content’,0,2,0,0,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘9’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (9,‘Bez edytora WYSIWYG’,‘none’,‘editors’,0,0,0,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘10’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (10,‘Edytor TinyMCE’,‘tinymce’,‘editors’,0,0,1,1,0,0,‘0000-00-00 00:00:00’,‘theme=advanced’) = = = = = = = = = = SQL=Duplicate entry ‘11’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (11,‘Przycisk MOSImage w edytorze’,‘mosimage.btn’,‘editors-xtd’,0,0,1,0,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘12’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (12,‘Przycisk MOSPagebreak w edytorze’,‘mospage.btn’,‘editors-xtd’,0,0,1,0,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘13’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (13,‘Szukaj w kontaktach’,‘contacts.searchbot’,‘search’,0,3,1,1,0,0,‘0000-00-00 00:00:00’,’’) = = = = = = = = = = SQL=Duplicate entry ‘14’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (14, ‘Szukaj w kategoriach’, ‘categories.searchbot’, ‘search’, 0, 4, 1, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘15’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (15, ‘Szukaj w sekcjach’, ‘sections.searchbot’, ‘search’, 0, 5, 1, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘16’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (16, ‘Ukryj Email [Email Cloaking]’, ‘mosemailcloak’, ‘content’, 0, 5, 1, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘17’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (17, ‘GeSHi - Znacznik składni kodu’, ‘geshi’, ‘content’, 0, 5, 0, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘18’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (18, ‘Szukaj w wieściach RSS’, ‘newsfeeds.searchbot’, ‘search’, 0, 6, 1, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘19’ for key 1: - - - - - - - - - - INSERT INTO mos_mambots
VALUES (19, ‘Wczytaj pozycje modułów’, ‘mosloadposition’, ‘content’, 0, 6, 1, 0, 0, 0, ‘0000-00-00 00:00:00’, ‘’) = = = = = = = = = = SQL=Table ‘mos_menu’ already exists: - - - - - - - - - - # Table structure for table mos_menu
CREATE TABLE mos_menu
( id
int(11) NOT NULL auto_increment, menutype
varchar(25) default NULL, name
varchar(100) default NULL, link
text, type
varchar(50) NOT NULL default ‘’, published
tinyint(1) NOT NULL default ‘0’, parent
int(11) unsigned NOT NULL default ‘0’, componentid
int(11) unsigned NOT NULL default ‘0’, sublevel
int(11) default ‘0’, ordering
int(11) default ‘0’, checked_out
datetime NOT NULL default ‘0000-00-00 00:00:00’, pollid
int(11) NOT NULL default ‘0’, browserNav
tinyint(4) default ‘0’, access
tinyint(3) unsigned NOT NULL default ‘0’, utaccess
tinyint(3) unsigned NOT NULL default ‘0’, params
), KEY componentid
(componentid
,menutype
,published
,access
), KEY menutype
(menutype
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - INSERT INTO mos_menu
VALUES (1, ‘mainmenu’, ‘Start’, ‘index.php?option=com_frontpage’, ‘components’, 1, 0, 10, 0, 1, 0, ‘0000-00-00 00:00:00’, 0, 0, 0, 3, ‘leading=1\r\nintro=2\r\nlink=1\r\nimage=1\r\npage_title=0\r\nheader=Welcome to the Frontpage\r\norderby_sec=front\r\nprint=0\r\npdf=0\r\nemail=0’) = = = = = = = = = = SQL=Table ‘mos_messages’ already exists: - - - - - - - - - - # Table structure for table mos_messages
CREATE TABLE mos_messages
( message_id
int(10) unsigned NOT NULL auto_increment, user_id_from
int(10) unsigned NOT NULL default ‘0’, user_id_to
int(10) unsigned NOT NULL default ‘0’, folder_id
int(10) unsigned NOT NULL default ‘0’, date_time
datetime NOT NULL default ‘0000-00-00 00:00:00’, state
int(11) NOT NULL default ‘0’, priority
int(1) unsigned NOT NULL default ‘0’, subject
varchar(230) NOT NULL default ‘’, message
text NOT NULL, PRIMARY KEY (message_id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_messages_cfg’ already exists: - - - - - - - - - - # Table structure for table mos_messages_cfg
CREATE TABLE mos_messages_cfg
( user_id
int(10) unsigned NOT NULL default ‘0’, cfg_name
varchar(100) NOT NULL default ‘’, cfg_value
varchar(255) NOT NULL default ‘’, UNIQUE idx_user_var_name
(user_id
,cfg_name
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_modules’ already exists: - - - - - - - - - - # Table structure for table mos_modules
CREATE TABLE mos_modules
( id
int(11) NOT NULL auto_increment, title
text NOT NULL, content
text NOT NULL, ordering
int(11) NOT NULL default ‘0’, position
varchar(10) default NULL, checked_out
datetime NOT NULL default ‘0000-00-00 00:00:00’, published
tinyint(1) NOT NULL default ‘0’, module
varchar(50) default NULL, numnews
tinyint(3) unsigned NOT NULL default ‘0’, showtitle
tinyint(3) unsigned NOT NULL default ‘1’, params
text NOT NULL, iscore
tinyint(4) NOT NULL default ‘0’, client_id
tinyint(4) NOT NULL default ‘0’, PRIMARY KEY (id
), KEY published
(published
,access
), KEY newsfeeds
(module
,published
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_modules
INSERT INTO mos_modules
VALUES (1, ‘Sonda’, ‘’, 1, ‘right’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_poll’, 0, 0, 1, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (2, ‘Menu użytkownika’, ‘’, 2, ‘left’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_mainmenu’, 0, 1, 1, ‘menutype=usermenu’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (3, ‘Menu główne’, ‘’, 1, ‘left’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_mainmenu’, 0, 0, 1, ‘menutype=mainmenu’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (4, ‘Logowanie’, ‘’, 3, ‘left’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_login’, 0, 0, 1, ‘’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (5, ‘Nagłówki RSS’, ‘’, 4, ‘left’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_rssfeed’, 0, 0, 1, ‘’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘6’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (6, ‘Nowości’, ‘’, 4, ‘user1’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_latestnews’, 0, 0, 1, ‘’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘7’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (7, ‘Statystyka’, ‘’, 4, ‘left’, 0, ‘0000-00-00 00:00:00’, 0, ‘mod_stats’, 0, 0, 1, ‘serverinfo=1\nsiteinfo=1\ncounter=1\nincrease=0\nmoduleclass_sfx=’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘8’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (8, ‘Gościmy’, ‘’, 1, ‘right’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_whosonline’, 0, 0, 1, ‘online=1\nusers=1\nmoduleclass_sfx=’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘9’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (9, ‘Popularne’, ‘’, 6, ‘user2’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_mostread’, 0, 0, 1, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘10’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (10, ‘Zmień szatę’,’’,6,‘left’,0,‘0000-00-00 00:00:00’,0,‘mod_templatechooser’, 0, 0, 1, ‘show_preview=1’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘11’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (11, ‘Archiwum’, ‘’, 7, ‘left’, 0, ‘0000-00-00 00:00:00’, 0, ‘mod_archive’, 0, 0, 1, ‘’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘12’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (12, ‘Sekcje’, ‘’, 8, ‘left’, 0, ‘0000-00-00 00:00:00’, 0, ‘mod_sections’, 0, 0, 1, ‘’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘13’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (13, ‘W skrócie’, ‘’, 1, ‘top’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_newsflash’, 0, 0, 1, ‘catid=3\r\nstyle=random\r\nitems=\r\nmoduleclass_sfx=’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘14’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (14, ‘Powiązane artykuły’, ‘’, 9, ‘left’, 0, ‘0000-00-00 00:00:00’, 0, ‘mod_related_items’, 0, 0, 1, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘15’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (15, ‘Wyszukiwarka’, ‘’, 1, ‘user4’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_search’, 0, 0, 0, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘16’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (16, ‘Losowy obraz’, ‘’, 9, ‘right’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_random_image’, 0, 0, 1, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘17’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (17, ‘Górne menu’, ‘’, 1, ‘user3’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_mainmenu’, 0, 0, 0, ‘menutype=topmenu\nmenu_style=list_flat\nmenu_images=n\nmenu_images_align=left\nexpand_menu=n\nclass_sfx=-nav\nmoduleclass_sfx=\nindent_image1=0\nindent_image2=0\nindent_image3=0\nindent_image4=0\nindent_image5=0\nindent_image6=0’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘18’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (18, ‘Bannery’, ‘’, 1, ‘banner’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_banners’, 0, 0, 0, ‘banner_cids=\nmoduleclass_sfx=\n’, 1, 0) = = = = = = = = = = SQL=Duplicate entry ‘31’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (31, ‘Inne menu’, ‘’, 2, ‘left’, 0, ‘0000-00-00 00:00:00’, 1, ‘mod_mainmenu’, 0, 0, 0, ‘menutype=othermenu\nmenu_style=vert_indent\ncache=0\nmenu_images=0\nmenu_images_align=0\nexpand_menu=0\nclass_sfx=\nmoduleclass_sfx=\nindent_image=0\nindent_image1=\nindent_image2=\nindent_image3=\nindent_image4=\nindent_image5=\nindent_image6=’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘33’ for key 1: - - - - - - - - - - INSERT INTO mos_modules
VALUES (33,‘Zalogowani’,’’,0,‘cpanel’,0,‘0000-00-00 00:00:00’,1,‘mod_logged’,0,99,1,’’,0,1) = = = = = = = = = = SQL=Table ‘mos_modules_menu’ already exists: - - - - - - - - - - # Table structure for table mos_modules_menu
CREATE TABLE mos_modules_menu
( moduleid
int(11) NOT NULL default ‘0’, menuid
int(11) NOT NULL default ‘0’, PRIMARY KEY (moduleid
,menuid
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘1-1’ for key 1: - - - - - - - - - - # Dumping data for table mos_modules_menu
INSERT INTO mos_modules_menu
VALUES (1,1) = = = = = = = = = = SQL=Duplicate entry ‘2-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (2,0) = = = = = = = = = = SQL=Duplicate entry ‘3-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (3,0) = = = = = = = = = = SQL=Duplicate entry ‘4-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (4,1) = = = = = = = = = = SQL=Duplicate entry ‘5-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (5,1) = = = = = = = = = = SQL=Duplicate entry ‘6-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (6,1) = = = = = = = = = = SQL=Duplicate entry ‘6-2’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (6,2) = = = = = = = = = = SQL=Duplicate entry ‘6-4’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (6,4) = = = = = = = = = = SQL=Duplicate entry ‘6-27’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (6,27) = = = = = = = = = = SQL=Duplicate entry ‘6-36’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (6,36) = = = = = = = = = = SQL=Duplicate entry ‘8-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (8,1) = = = = = = = = = = SQL=Duplicate entry ‘9-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (9,1) = = = = = = = = = = SQL=Duplicate entry ‘9-2’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (9,2) = = = = = = = = = = SQL=Duplicate entry ‘9-4’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (9,4) = = = = = = = = = = SQL=Duplicate entry ‘9-27’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (9,27) = = = = = = = = = = SQL=Duplicate entry ‘9-36’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (9,36) = = = = = = = = = = SQL=Duplicate entry ‘10-1’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (10,1) = = = = = = = = = = SQL=Duplicate entry ‘13-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (13,0) = = = = = = = = = = SQL=Duplicate entry ‘15-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (15,0) = = = = = = = = = = SQL=Duplicate entry ‘17-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (17,0) = = = = = = = = = = SQL=Duplicate entry ‘18-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (18,0) = = = = = = = = = = SQL=Duplicate entry ‘31-0’ for key 1: - - - - - - - - - - INSERT INTO mos_modules_menu
VALUES (31, 0) = = = = = = = = = = SQL=Table ‘mos_newsfeeds’ already exists: - - - - - - - - - - # Table structure for table mos_newsfeeds
CREATE TABLE mos_newsfeeds
( catid
int(11) NOT NULL default ‘0’, id
text NOT NULL, link
text NOT NULL, filename
varchar(200) default NULL, published
tinyint(1) NOT NULL default ‘0’, numarticles
int(11) unsigned NOT NULL default ‘1’, cache_time
int(11) unsigned NOT NULL default ‘3600’, checked_out
tinyint(3) unsigned NOT NULL default ‘0’, checked_out_time
int(11) NOT NULL default ‘0’, PRIMARY KEY (id
), KEY published
(published
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_poll_data’ already exists: - - - - - - - - - - # Table structure for table mos_poll_data
CREATE TABLE mos_poll_data
( id
int(11) NOT NULL auto_increment, pollid
int(4) NOT NULL default ‘0’, text
text NOT NULL default ‘’, hits
), KEY pollid
(pollid
,text
(1)) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_poll_date’ already exists: - - - - - - - - - - # Table structure for table mos_poll_date
CREATE TABLE mos_poll_date
( id
bigint(20) NOT NULL auto_increment, date
datetime NOT NULL default ‘0000-00-00 00:00:00’, vote_id
int(11) NOT NULL default ‘0’, poll_id
), KEY poll_id
(poll_id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_polls’ already exists: - - - - - - - - - - # Table structure for table mos_polls
CREATE TABLE mos_polls
( id
varchar(100) NOT NULL default ‘’, voters
int(9) NOT NULL default ‘0’, checked_out
int(11) NOT NULL default ‘0’, checked_out_time
tinyint(1) NOT NULL default ‘0’, access
int(11) NOT NULL default ‘0’, lag
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_poll_menu’ already exists: - - - - - - - - - - # Table structure for table mos_poll_menu
CREATE TABLE mos_poll_menu
( pollid
int(11) NOT NULL default ‘0’, PRIMARY KEY (pollid
,menuid
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_sections’ already exists: - - - - - - - - - - # Table structure for table mos_sections
CREATE TABLE mos_sections
( id
varchar(100) NOT NULL default ‘’, scope
), KEY idx_scope
(scope
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_session’ already exists: - - - - - - - - - - # Table structure for table mos_session
CREATE TABLE mos_session
( username
varchar(50) default ‘’, time
varchar(14) default ‘’, session_id
varchar(200) NOT NULL default ‘0’, guest
tinyint(4) default ‘1’, userid
int(11) default ‘0’, usertype
varchar(50) default ‘’, gid
tinyint(3) unsigned NOT NULL default ‘0’, PRIMARY KEY (session_id
), KEY whosonline
(guest
,usertype
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_stats_agents’ already exists: - - - - - - - - - - # Table structure for table mos_stats_agents
CREATE TABLE mos_stats_agents
( agent
varchar(255) NOT NULL default ‘’, type
tinyint(1) unsigned NOT NULL default ‘0’, hits
int(11) unsigned NOT NULL default ‘1’ ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_templates_menu’ already exists: - - - - - - - - - - # Table structure for table mos_templates_menu
CREATE TABLE mos_templates_menu
( template
varchar(50) NOT NULL default ‘’, menuid
int(11) NOT NULL default ‘0’, client_id
tinyint(4) NOT NULL default ‘0’, PRIMARY KEY (template
,menuid
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘rhuk_solarflare_ii-0’ for key 1: - - - - - - - - - - INSERT INTO mos_templates_menu
VALUES (‘rhuk_solarflare_ii’, ‘0’, ‘0’) = = = = = = = = = = SQL=Duplicate entry ‘mambo_admin_blue-0’ for key 1: - - - - - - - - - - INSERT INTO mos_templates_menu
VALUES (‘mambo_admin_blue’, ‘0’, ‘1’) = = = = = = = = = = SQL=Table ‘mos_template_positions’ already exists: - - - - - - - - - - # Table structure for table mos_template_positions
CREATE TABLE mos_template_positions
( id
int(11) NOT NULL auto_increment, position
varchar(255) NOT NULL default ‘’, PRIMARY KEY (id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_users’ already exists: - - - - - - - - - - # Table structure for table mos_users
CREATE TABLE mos_users
( id
varchar(50) NOT NULL default ‘’, username
varchar(25) NOT NULL default ‘’, email
varchar(100) NOT NULL default ‘’, password
varchar(100) NOT NULL default ‘’, usertype
varchar(25) NOT NULL default ‘’, block
tinyint(4) NOT NULL default ‘0’, sendEmail
tinyint(4) default ‘0’, gid
tinyint(3) unsigned NOT NULL default ‘1’, registerDate
datetime NOT NULL default ‘0000-00-00 00:00:00’, lastvisitDate
datetime NOT NULL default ‘0000-00-00 00:00:00’, activation
varchar(100) NOT NULL default ‘’, params
), KEY usertype
(usertype
), KEY idx_name
(name
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_usertypes’ already exists: - - - - - - - - - - # Table structure for table mos_usertypes
CREATE TABLE mos_usertypes
( id
varchar(50) NOT NULL default ‘’, mask
varchar(11) NOT NULL default ‘’, PRIMARY KEY (id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘0’ for key 1: - - - - - - - - - - # Dumping data for table mos_usertypes
INSERT INTO mos_usertypes
VALUES (0, ‘superadministrator’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (1, ‘administrator’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (2, ‘editor’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (3, ‘user’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (4, ‘author’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (5, ‘publisher’, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘6’ for key 1: - - - - - - - - - - INSERT INTO mos_usertypes
VALUES (6, ‘manager’, ‘’) = = = = = = = = = = SQL=Table ‘mos_weblinks’ already exists: - - - - - - - - - - # Table structure for table mos_weblinks
CREATE TABLE mos_weblinks
( id
int(11) unsigned NOT NULL auto_increment, catid
int(11) NOT NULL default ‘0’, sid
int(11) NOT NULL default ‘0’, title
varchar(250) NOT NULL default ‘’, url
varchar(250) NOT NULL default ‘’, description
varchar(250) NOT NULL default ‘’, date
datetime NOT NULL default ‘0000-00-00 00:00:00’, hits
int(11) NOT NULL default ‘0’, archived
tinyint(1) NOT NULL default ‘0’, approved
tinyint(1) NOT NULL default ‘1’, params
), KEY catid
(catid
,published
,archived
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_core_acl_aro’ already exists: - - - - - - - - - - # Table structure for table mos_core_acl_aro
CREATE TABLE mos_core_acl_aro
( aro_id
int(11) NOT NULL auto_increment, section_value
varchar(240) NOT NULL default ‘0’, value
varchar(240) NOT NULL default ‘’, order_value
int(11) NOT NULL default ‘0’, name
varchar(255) NOT NULL default ‘’, hidden
int(11) NOT NULL default ‘0’, PRIMARY KEY (aro_id
), UNIQUE KEY section_value_value_aro
(section_value
,value
), UNIQUE KEY mos_gacl_section_value_value_aro
(section_value
,value
), KEY hidden_aro
(hidden
), KEY mos_gacl_hidden_aro
(hidden
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_core_acl_aro_groups’ already exists: - - - - - - - - - - # Table structure for table mos_core_acl_aro_groups
CREATE TABLE mos_core_acl_aro_groups
( group_id
varchar(255) NOT NULL default ‘’, lft
int(11) NOT NULL default ‘0’, rgt
int(11) NOT NULL default ‘0’, PRIMARY KEY (group_id
), KEY parent_id_aro_groups
(parent_id
), KEY mos_gacl_parent_id_aro_groups
(parent_id
), KEY mos_gacl_lft_rgt_aro_groups
(lft
,rgt
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘17’ for key 1: - - - - - - - - - - # Dumping data for table mos_core_acl_aro_groups
INSERT INTO mos_core_acl_aro_groups
VALUES (17,0,‘ROOT’,1,22) = = = = = = = = = = SQL=Duplicate entry ‘28’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (28,17,‘USERS’,2,21) = = = = = = = = = = SQL=Duplicate entry ‘29’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (29,28,‘Public Frontend’,3,12) = = = = = = = = = = SQL=Duplicate entry ‘18’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (18,29,‘Registered’,4,11) = = = = = = = = = = SQL=Duplicate entry ‘19’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (19,18,‘Author’,5,10) = = = = = = = = = = SQL=Duplicate entry ‘20’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (20,19,‘Editor’,6,9) = = = = = = = = = = SQL=Duplicate entry ‘21’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (21,20,‘Publisher’,7,8) = = = = = = = = = = SQL=Duplicate entry ‘30’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (30,28,‘Public Backend’,13,20) = = = = = = = = = = SQL=Duplicate entry ‘23’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (23,30,‘Manager’,14,19) = = = = = = = = = = SQL=Duplicate entry ‘24’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (24,23,‘Administrator’,15,18) = = = = = = = = = = SQL=Duplicate entry ‘25’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_groups
VALUES (25,24,‘Super Administrator’,16,17) = = = = = = = = = = SQL=Table ‘mos_core_acl_groups_aro_map’ already exists: - - - - - - - - - - # Table structure for table mos_core_acl_groups_aro_map
CREATE TABLE mos_core_acl_groups_aro_map
( group_id
int(11) NOT NULL default ‘0’, section_value
varchar(240) NOT NULL default ‘’, aro_id
int(11) NOT NULL default ‘0’, UNIQUE KEY group_id_aro_id_groups_aro_map
(group_id
,section_value
,aro_id
) ) TYPE=MyISAM = = = = = = = = = = SQL=Table ‘mos_core_acl_aro_sections’ already exists: - - - - - - - - - - # Table structure for table mos_core_acl_aro_sections
CREATE TABLE mos_core_acl_aro_sections
( section_id
int(11) NOT NULL auto_increment, value
varchar(230) NOT NULL default ‘’, order_value
varchar(230) NOT NULL default ‘’, hidden
int(11) NOT NULL default ‘0’, PRIMARY KEY (section_id
), UNIQUE KEY value_aro_sections
(value
), UNIQUE KEY mos_gacl_value_aro_sections
(value
), KEY hidden_aro_sections
(hidden
), KEY mos_gacl_hidden_aro_sections
(hidden
) ) TYPE=MyISAM = = = = = = = = = = SQL=Duplicate entry ‘10’ for key 1: - - - - - - - - - - INSERT INTO mos_core_acl_aro_sections
VALUES (10,‘users’,1,‘Users’,0); = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # $Id: sample_data.sql,v 1.7 2005/02/24 11:43:00 dylek Exp $ # Dumping data for table mos_banner
INSERT INTO mos_banner
VALUES (1, 1, ‘banner’, ‘Ka-Ching’, 0, 42, 0, ‘ka-chingBanner.gif’, ‘http://www.miro.com.au’, ‘2004-07-07 15:31:29’, 1, 0, ‘2000-00-00 00:00:00’, NULL, NULL) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_banner
VALUES (2, 1, ‘banner’, ‘Oi!’, 0, 48, 0, ‘OiBanner.gif’, ‘http://www.miro.com.au’, ‘2004-07-07 15:31:29’, 1, 0, ‘2000-00-00 00:00:00’, NULL, NULL) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_bannerclient
INSERT INTO mos_bannerclient
VALUES (1, ‘Miro International Pty.’, ‘Administrator’, ‘admin@miro.com.au’, ‘’, 0, ‘00:00:00’, NULL) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_categories
INSERT INTO mos_categories
VALUES (1, 0, ‘Najnowsze’, ‘Najnowsze wiadomości’, ‘taking_notes.jpg’, ‘1’, ‘left’, ‘Najnowsze wieści z serwisu Mambo’, 1, 0, ‘0000-00-00 00:00:00’, ‘’, 0, 0, 1, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (2, 0, ‘Mambo’, ‘Mambo’, ‘clock.jpg’, ‘com_weblinks’, ‘left’, ‘Wybór linków powiązanych tematycznie z projektem Mambo.’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 0, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (3, 0, ‘W skrócie’, ‘W skrócie’, ‘’, ‘2’, ‘left’, ‘’, 1, 0, ‘0000-00-00 00:00:00’, ‘’, 0, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (4, 0, ‘Mambo’, ‘Mambo’, ‘’, ‘com_newsfeeds’, ‘left’, ‘’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 2, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (5, 0, ‘Business: ogólne’, ‘Business: ogólne’, ‘’, ‘com_newsfeeds’, ‘left’, ‘’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 1, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘7’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (7, 0, ‘Przykłady’, ‘Przykładowe FAQs’, ‘key.jpg’, ‘3’, ‘left’, ‘Tu możesz znaleźć przykładowe elementy FAQ.’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 0, 0, 2, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘9’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (9, 0, ‘Finanse’, ‘Finanse’, ‘’, ‘com_newsfeeds’, ‘left’, ‘’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 5, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘10’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (10, 0, ‘Linux’, ‘Linux’, ‘’, ‘com_newsfeeds’, ‘left’, ‘\r\n’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 6, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘11’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (11, 0, ‘Internet’, ‘Internet’, ‘’, ‘com_newsfeeds’, ‘left’, ‘’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 7, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘12’ for key 1: - - - - - - - - - - INSERT INTO mos_categories
VALUES (12, 0, ‘Kontakty’, ‘Kontakty’, ‘’, ‘com_contact_details’, ‘left’, ‘Szczegóły na temat kontaktów dla tego serwisu’, 1, 0, ‘0000-00-00 00:00:00’, NULL, 0, 0, 0, ‘’) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_contact_details
INSERT INTO mos_contact_details
VALUES (1, ‘Nazwa’, ‘Stanowisko’, ‘Ulica’, ‘Miasto’, ‘Województwo’, ‘Kraj’, ‘Kod’, ‘Telefon’, ‘Fax’, ‘Dodatkowe informacje’, ‘asterisk.png’, ‘top’, ‘email@email.com’, 1, 1, 0, ‘0000-00-00 00:00:00’, 1, ‘’, 0, 12, 0) = = = = = = = = = = SQL=Duplicate entry ‘1’ for key 1: - - - - - - - - - - # Dumping data for table mos_content
INSERT INTO mos_content
VALUES (1, ‘Witaj w Mambo’, ‘Witaj’, ‘Jeżeli cokolwiek czytałeś o portalach, prawdopodobnie już wiesz o trzech rzeczach: portale są wspaniałym środkiem dla biznesu, portal może być naprawdę, mówię naprawdę, skomplikowany i większość portali taka jest i co gorsza, często są bardzo drogie.{mosimage}Mambo jest po to aby to zmienić. MAMBO jest inny od popularnych modeli portalowych. Po pierwsze, nie jest skomplikowany. Mambo jest tworzony dla wszystkich. Jest oparty na licencji GNU, prosty do zainstalowania i administrowania oraz niezawodny. Mambo nie wymaga nawet od użytkownika i administratora znajomości HTML, gdy wszystko jest już zainstalowane i uruchomione.Kilka głównych cech Mambo:Mambo jest w pełni wspierany przez bazę danych przy pomocy PHP i MySQL.Moduł bezpieczeństwa wielopoziomowego logowania użytkowników i administratorów oraz edytorów.W pełni zarządzalny układ strony uwzględniający lewy, centralny i prawy oraz górny i dolny blok menu.Ładowanie obrazków z przeglądarki do biblioteki serwera aby móc je używać gdziekolwiek na stronie.Dynamiczne forum, galerie, ankiety i wiele innych ciekawych modułów oraz komponentów dodatkowych.Działający niemal na wszystkich platformach systemowych jak: Linux, FreeBSD, MacOSX server, Solaris, AIX, SCO, Windows…Dostępny w polskiej wersji językowej’,‘Zaawansowana administracja:Zmienianie porządku pozycji takich jak wiadomości, artykułów i innych własnych sekcji.Losowy generator informacji newsflash.Hierarchiczne pozycje - podział sekcji, działów, tematów…Biblioteka obrazków - teraz możesz ładować PNG, GIF i JPEG za pomocą interfejsu http://WWW. pobieranych wiadomości newsfeeds. Możesz wybrać z ogromnej ilości wiadomości do ładowania z całego świata.Manager kosza. Możesz przenosić stare artykuły i elementy menu do kosza zamiast je usuwać.Wyślij znajomemu, plik PDF i format dla wydruku dla każdej wiadomości i artykułu.Edytor zawartości WYSIWYG (zapomnij o HTML - What You See is What You Get).Układ graficzny, ankiety i głosowania mogą być różne na każdej stronie.Podgląd układu strony. Możesz zobaczyć jak to bedzie wyglądało zanim zostanie wystawione na świat.Manager bannerów… i mnóstwo innych atrakcyjnych i przydatnych funkcji.’, 1, 1, 0, 1, ‘2004-06-12 11:54:06’, 62, ‘Web Master’, ‘2004-06-12 12:33:27’, 62, 0, ‘0000-00-00 00:00:00’, ‘2004-01-01 00:00:00’, ‘0000-00-00 00:00:00’, ‘asterisk.png|left|Mambo Logo|1|Mambo Flower Logo|bottom|center|120’, ‘’, ‘’, 1, 0, 1, ‘’, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘2’ for key 1: - - - - - - - - - - INSERT INTO mos_content
VALUES (2, ‘W skrócie 1’, ‘’, ‘Mambo 4.5 to ‘‘Potęga w prostocie’’!. Nigdy dotąd stworzenie własnego, dynamicznego serwisu nie było takie proste. Zarządzaj zawartością swojej strony poprzez najlepszy panel administracyjny.’, ‘’, 1, 2, 1, 3, ‘2004-08-09 08:30:34’, 62, ‘’, ‘0000-00-00 00:00:00’, 0, 0, ‘0000-00-00 00:00:00’, ‘2004-08-09 00:00:00’, ‘0000-00-00 00:00:00’, ‘’, ‘’, ‘’, 1, 0, 1, ‘’, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘3’ for key 1: - - - - - - - - - - INSERT INTO mos_content
VALUES (3, ‘W skrócie 2’, ‘’, ‘Wczoraj wszystkie serwery w Stanach zaczęły strajkowac, aby dostac wiecej RAMu i lepsze CPU. Rzecznik powiedzial, że lepiej byłoby powiększyć prędkość FSB. W przyszłości FSB mają spowolnić prędkość płyt głównych.’, ‘’, 1, 2, 1, 3, ‘2004-08-09 08:30:34’, 62, ‘’, ‘0000-00-00 00:00:00’, 0, 0, ‘0000-00-00 00:00:00’, ‘2004-08-09 00:00:00’, ‘0000-00-00 00:00:00’, ‘’, ‘’, ‘’, 1, 0, 2, ‘’, ‘’, 0, 0) = = = = = = = = = = SQL=Duplicate entry ‘4’ for key 1: - - - - - - - - - - INSERT INTO mos_content
VALUES (4, ‘W skrócie 3’, ‘’, ‘Bdanaia na agnilesikm uiwnerstyecie dodowzą, iż nie ma zanczinea w jikaej kelojności znujdają się ltiery w wyazrie, wnaże jest jydenie aby pirwesza i ostitana ltiera była na włiścawym miejscu. Rszeta może być zepułnie pozemianiana ale wcąiż mżona cztyać bez żydnach preblomów. Dzeije się tak dletago, że nie czatymy kelojno letiry po letirze, ale od razu całe sołwo.’, ‘’, 1, 2, 1, 3, ‘2004-08-09 08:30:34’, 62, ‘’, ‘0000-00-00 00:00:00’, 0, 0, ‘0000-00-00 00:00:00’, ‘2004-08-09 00:00:00’, ‘0000-00-00 00:00:00’, ‘’, ‘’, ‘’, 1, 0, 3, ‘’, ‘’, 0, 1) = = = = = = = = = = SQL=Duplicate entry ‘5’ for key 1: - - - - - - - - - - INSERT INTO mos_content
VALUES (5, ‘Licencja Mambo’, ‘’, 'Mambo jest upowszechniany na zasadach GNU General Public \r\nLicense(GNU GPL). Powszechna Licencja Publiczna zapewnia swobodę upowszechniania kopii oprogramowania i - jeśli ktoś chce - pobierania za to opłat, ale nie za samo oprogramowanie, ponieważ Mambo jest wolnym oprogramowaniem, jest bezpłatne! \r\nGNU GPL zapewnia swobodę dokonywania zmian w oprogramowaniu lub wykorzystywania jego fragmentów w nowych wolnych programach.\r\nTak więc w sprawie autorskich praw własności:\r\nMOŻESZ upowszechniać to oprogramowanie i pobierać za tę usługę opłatę. MOŻESZ dokonywać dowolnych zmian w oprogramowaniu, zmieniać wygląd i zawartość i pobierać opłaty za tę pracę. \r\nNIE MOŻESZ jednak zmieniać licencji i MUSISZ udzielić nabywcy \r\nwszelkich praw do oprogramowania, jakie sam posiadałeś. \r\nNIE MUSISZ zamieszczać stopki czy bannera w stylu ‘Powered by \r\nMambo’.\r\nNIE MOŻESZ zmieniać praw własności autorskiej do Mambo. \r\nZachowujesz jednak swoje prawa własności autorskiej do wprowadzonych zmian i modyfikacji. \r\n\r\nInnymi słowy, NIE MOŻESZ informować, że Mambo jest Twoje, oraz NIE MOŻESZ pobierać opłat za samo Mambo.\r\nUżywaj Mambo aby ułatwić życie sobie i swoim klientom, \r\nodrzucając całą otoczkę “czarnej magii” która wciąż jest związana z publikacją treści w Internecie. Pobieraj opłaty za swoją pracę, a nie za wysiłek który włożyli w Mambo: Miro, zespół developerów Mambo oraz cała społeczność związana z \r\nMambo.\r\nKto ma prawa własności Mambo?Autorskie prawa własności do kodu źródłowego Mambo ma Miro International inc. Witrynę Miro znajdziesz pod adresem: http://www.miro.com.au.Co to jest Open Source?Open Source to termin opisujący część ruchu wolnego oprogramowania. Poniżej znajdują się odsyłacze do witryn organizacji, które współdziałają w rozwijaniu Open Source:Free Software Foundation (Fundacja Wolnego Oprogramowania): http://www.fsf.org/Project GNU (GNU is Not Unix - GNU to nie Unix): http://www.gnu.org/ Open Source Initiative (OSI - Inicjatywa Otwartych Źródeł): http://www.opensource.org/Słowo “wolne” [“free”] w języku angielskim używane jest w dwojakim znaczeniu: może dotyczyć swobody wykorzystania (wolne) i ceny (darmowe). Mówiąc o wolnym oprogramowaniu mamy na myśli swobodę, a nie cenę. Wolne oprogramowanie zapewnia swobodę używania, wykonywania kopii, rozpowszechniania, dostępu do kodu źródłowego, modyfikowania kodu, rozwijania programu.Precyzyjniej, wolne oprogramowanie oznacza cztery rodzaje wolności użytkowników :Wolno wykorzystywać program dla jakiegokolwiek celu (wolność 0). Wolno studiować kod programu i dostosowywać go do swoich potrzeb. Dostęp do kodu źródłowego jest niezbędnym warunkiem tej wolności (wolność 1). Wolno rozprowadzać kopie programu (wolność 2). Wolno ulepszać program i upowszechniać ulepszenia, także dla wspólnej korzyści (wolność 3). Dostęp do kodu źródłowego jest niezbędnym warunkiem tej wolności.{mospagebreak title=FAQ - Licencja Mambo} 1. Na jakiej licencji upowszechniany jest Mambo?Mambo jest upowszechniany na GNU GPL. Kopia licencji znajduje się w Twoim pakiecie dystrybucyjnym. Możesz ją również znaleźć pod adresem: http://www.fsf.org/licenses/gpl.html. Nieoficjalne tłumaczenia możesz znaleźć pod adresem http://www.fsf.org/licenses/translations.html. 2. Kto posiada prawa autorskie do Mambo?Prawa autorskie do Mambo należą do Miro International Pty Ltd. W Miro powstał oryginalny Mambo, Miro skupia autorów projektu i nadal czynnie go rozwija.3. Czy istnieją jakieś ograniczenia w wykorzystaniu Mambo?GNU GPL daje Ci swobodę wykorzystywania oprogramowania do jakiegokolwiek celu.4 . Pobieram opłaty za Mambo. Czy mogę?GPL pozwala swobodnie dysponować programem, także pobierać opłatę za rozpowszechnianie jego kopii.Jeśli rozprowadzasz kopie programu, niezależnie czy gratisowo, czy za opłatą, musisz udzielić nabywcy wszelkich tych praw, jakie Ty posiadałeś.Kiedy ludzie mają na myśli “sprzedaż oprogramowania”, z reguły wyobrażają sobie to tak, jak robi to wiekszość firm: czynią oprogramowanie raczej prawnie zatrzeżonym niż wolnym. Aby uniknąć niejasności: możesz pobierać opłaty za dystrybucję oprogramowania i inne związane z nim usługi. Mozesz nawet sprzedawać oprogramowanie dla zysku pod swoją własną nazwą. Dopóki jądro programu jest sprzedawane wraz z kodem źródłowym oraz innymi pakietami chronionymi przez GPL, to wszystko jest legalne. Nie możesz jednak pobierać opłaty za samo oprogramowanie, bo nie Ty je stworzyłeś, bo Mambo jest wolne. Co więcej - nawet jeśli ktoś zapłacił Ci za kopię oprogramowania - licencja GPL daje mu takie same prawa, jakie Ty posiadałeś: może on również rozprowadzać dalej oprogramowanie zarówno za opłatą, jak i bez. 5 . Usunąłem ze stopki notę prawną "powered by Mambo, Copyright Miro etc"Możesz tak uczynić, choć mamy nadzieję, że zachowasz tę notę, aby oddać cześć autorom.6. Chcę usunąć noty o prawach autorskich ("copyright ") z kodu źródłowego?Nie możesz! Musisz zachować wszystkie noty stwierdzające prawa autorskie oraz podziękowania dla autorów i informacje o tym, na czyich opracowaniach bazuje kod źródłowy, jeśli się w nim takie znajdują.7. Mambo objęte jest licencją GPL. Czy zawartość mojej witryny działającej na Mambo jest także objęta warunkami licencji GPL?Nie. Prawa autorskie i licencja Mambo nie obejmują zawartości, jaką tworzysz, używając Mambo. GPL nie obejmuje działań innych niż kopiowanie, rozprowadzanie i modyfikowanie - nie mieszczą się one w jej zakresie. Używanie programu nie jest poddane ograniczeniom, a produkty powstałe w wyniku używania programu są objęte licencją tylko wtedy, gdy ich treść stanowi pracę opartą na programie.8. Zmodyfikowałem kod Mambo na potrzeby swej witryny. Czy muszę oznaczyć te modyfikacje komentarzem i upowszechnić je?GPL pozwala dokonywać modyfikacji w oprogramowaniu wykorzystywanym dla własnego użytku bez obowiązku oznaczania zmodyfikowanych fragmentów i upowszechniania ich, czy np. powiadamiania autorów.9. Zmodyfikowałem kod źródłowy pakietu dystrybucyjnego Mambo. Czy muszę upowszechnić tę dystrybucję na warunkach GPL?Tak. Jeśli rozprowadzasz kopie programu, niezależnie czy gratisowo, czy za opłatą, musisz udzielić innym wszelkich praw, jakie sam miałeś, a więc na warunkach licencji GPL Musisz również zapewnić otrzymanie kodu źródłowego (lub możliwość otrzymania). Możesz, ocz
