Nagrywam różne DVD+R, zazwyczaj z obrazami płyt (np. WAIK) + jakieś dane, i przy 0 do 7 % wyskakuję błąd ‘Błąd : Zakończ w trybie DAO’
Tu jest log z nagrania:
Nero 8.2.8.0
Ahead Software
4K22-0117-1100-1M84-5915-AC7M- ****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
(Nero Express)
Recorder: Version: DL10 - HA 1 TA 0 - 8.3.2.1
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: Version: 2.0B - HA 1 TA 2 - 8.3.2.1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV0602H atapi Port 0 ID 0 DMA: On
DiskPeripheral : IC35L040AVER07-0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-52327S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : JJ2281S QTU214C 2.0B ag4nrisl Port 2 ID 0 DMA: Off
CdRomPeripheral : JJ2281S QTU214C 2.0B ag4nrisl Port 2 ID 1 DMA: Off
CdRomPeripheral : JJ2281S QTU214C 2.0B ag4nrisl Port 2 ID 2 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4167B G: CdRom0
LITE-ON LTR-52327S H: CdRom1
JJ2281S QTU214C D: CdRom2
JJ2281S QTU214C J: CdRom3
JJ2281S QTU214C K: CdRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046612kB)
Free physical memory: 577MB (590912kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.10.2008
Kompilacja UDF
12:03:15 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
12:03:15 #2 Text 0 File Isodoc.cpp, Line 6713
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Continue multisession
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
12:03:15 #3 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
12:03:17 #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
12:03:17 #5 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2149951 (477:46.01, 4199MB)
12:03:17 #6 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
12:03:17 #7 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: HL-DT-ST DVDRAM GSA-4167B, Media type: DVD+R
Disc Manufacturer ID: , Media Type ID: , Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
12:03:17 #8 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
12:03:17 #9 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2014448 (2014448) = #2014448/447:39.23
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2014448 blocks [G]
12:03:17 #10 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [G] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4125589504, ISRC ""
DAO layout:
___Start_|____ Track_|_Idx_|_CtrlAdr_| _____Size_|______ NWA_|_RecDep __________
135504 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
135504 | 2 | 0 | 0x41 | 0 | 0 | 0x00
135504 | 2 | 1 | 0x41 | 2014448 | 135504 | 0x00
2149952 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
12:03:17 #11 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
12:03:17 #12 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
12:03:17 #13 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
12:03:17 #14 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
12:03:17 #15 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
12:03:17 #16 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11 080 KB/s)
12:03:17 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #135504
12:03:17 #18 Text 0 File Cdrdrv.cpp, Line 10164
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: OPTODISC
Media type ID: OR8
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..783]:
00 00 03 4F 50 54 4F 44 - 49 53 43 4F 52 38 00 38 ...OPTODISCOR8.8
23 54 37 09 02 64 6A 02 - C8 63 18 18 0A 0A 0E 0E #T7..dj..c......
01 1B 1D 0B 0B 11 13 01 - 00 00 00 00 00 00 00 00 ................
01 00 38 38 02 2C 63 20 - 08 30 22 10 00 20 20 01 ..88.,c..0".....
00 00 02 2C 63 20 08 30 - 22 10 00 20 20 01 00 00 ...,c..0".......
02 00 54 70 02 2F 64 48 - 20 14 0C 0C 01 20 00 00 ..Tp./dH........
00 00 02 43 61 55 20 14 - 0C 0C 01 20 00 00 00 32 ...CaU.........2
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:03:17 #19 Text 0 File DVDR.cpp, Line 6678
Drive: HL-DT-ST DVDRAM GSA-4167B
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
12:03:17 #20 CDR -1207 File DVDR.cpp, Line 6605
Book Type automatically set to: DVD-ROM
12:03:17 #21 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 135504
DVD high compatibility mode: No
12:03:17 #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
12:03:47 #23 SPTI -1039 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1039)
CDB Data: 0x2A 00 00 02 15 50 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
Sense Area: 0x70 00 04 00 00 00 00 10 35 01 04 0E 09 01
Buffer x0a540840: Len x10000
0x79 0A E3 90 06 DE F5 E1 16 3C 70 6B 82 1D D9 4D
0xD7 01 D8 4C 5C 94 0E 61 C8 0C 4B ED E6 50 36 BC
0x45 29 37 B5 C7 89 9B 8E 58 DB B7 3A 1F C4 05 26
12:03:47 #24 CDR -1039 File Writer.cpp, Line 306
Focus or tracking error
G: HL-DT-ST DVDRAM GSA-4167B
12:03:47 #25 SPTI -1039 File SCSIPassThrough.cpp, Line 196
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x09
Sense Qual: 0x01
Sense Area: 0x71 00 04 00 00 00 00 10 35 01 04 0E 09 01
12:03:49 #26 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 136528
12:03:49 #27 CDR -1039 File WriterStatus.cpp, Line 292
12:03:49 #28 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
12:03:50 #29 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11 080 KB/s)
12:03:50 #30 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:03:55 #31 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
12:03:56 #32 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
