Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘C:\Program Files\Ahead\Nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34 Nero Version: 6.6.0.16 Internal Version: 6, 6, 0, 16b (Nero Express) Recorder: Version: RB00 - HA 1 TA 0 - 6.6.0.16 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: Version: RB00 - HA 1 TA 0 - 6.6.0.16 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : ST3120026A atapi Port 0 ID 0 DMA: On DiskPeripheral : ST340014A atapi Port 0 ID 1 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-H44N atapi Port 1 ID 0 DMA: On CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-H44N F: CDRom0 Generic DVD-ROM G: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 669MB (685928kB) Memory in use : 34 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 15.10.2007 Obraz CD 21:25:47 #1 Text 0 File Burncd.cpp, Line 2948 HL-DT-ST DVDRAM GSA-H44N Włączono System ochrony zapisu 21:25:47 #2 Text 0 File Reader.cpp, Line 127 Reader running 21:25:47 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366 Image was written as DAO. DAOI: MediaCatalogNumber = ‘’ TocType = 0x20 Finalized = 1 First/Last Track = 1 / 2 1: ISRC = ‘’ Blocksize = 2336 TrackMode = ‘TRM_DATA_MODE2_2336’ TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 0, Index1FilePos = 350400, NextTrackFilePos = 696128 2: ISRC = ‘’ Blocksize = 2336 TrackMode = ‘TRM_DATA_MODE2_2336’ TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 696128, Index1FilePos = 1401600, NextTrackFilePos = 705077216 CUES: 0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00 1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=954437:08.46 ( -150) RecDep=0x00 2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00 3: Ctrl=0x41 Trk= 2 (0x02) Index=00 Start=00:01.73 ( 148) RecDep=0x00 4: Ctrl=0x41 Trk= 2 (0x02) Index=01 Start=00:06.00 ( 450) RecDep=0x00 5: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=67:02.31 ( 301681) RecDep=0x00 MTYP: Mediumtype = CD (old format) (0x1) Image file name: 21:25:47 #4 Text 0 File Burncd.cpp, Line 3233 Turn on Disc-At-Once, using CD-R/RW media 21:25:48 #5 Text 0 File DlgWaitCD.cpp, Line 270 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 301680 ( 67:04.30) 21:25:48 #6 Text 0 File DlgWaitCD.cpp, Line 282 Write in overburning mode: NO 21:25:48 #7 Text 0 File DlgWaitCD.cpp, Line 2483 Recorder: HL-DT-ST DVDRAM GSA-H44N; CDRW code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical ATIP Data: Special Info [hex] 1: A3 00 CF, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 24 2C DC, 2: 14 A4 4A, 3: 04 C4 80 21:25:48 #8 Text 0 File DlgWaitCD.cpp, Line 448 >>> Protocol of DlgWaitCD activities: <<< ========================================= 21:25:48 #9 Text 0 File ThreadedTransferInterface.cpp, Line 838 Setup items (after recorder preparation) 0: TRM_DATA_MODE2_2336 (1 - CD-ROM Tryb 2/XA, ISO 9660) 2 indices, index0 (150) provided original disc pos #0 + 148 (148) = #148/0:1.73 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 148 blocks [HL-DT-ST DVDRAM GSA-H44N] 1: TRM_DATA_MODE2_2336 (2 - CD-ROM Tryb 2/XA, CD-ROM Tryb 1) 2 indices, index0 (302) provided original disc pos #450 + 301231 (301231) = #301681/67:2.31 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 301231 blocks [HL-DT-ST DVDRAM GSA-H44N] -------------------------------------------------------------- 21:25:48 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1051 Prepare recorder [HL-DT-ST DVDRAM GSA-H44N] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x20; Session Closed, disc fixated Tracks 1 to 2: 1: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 0 352800 700896, ISRC “” 2: TRM_DATA_RAW_MODE2, 2352/0x00, FilePos 700896 1411200 709906512, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 148 | 2 | 0 | 0x41 | 0x00 450 | 2 | 1 | 0x41 | 0x00 301681 | lead-out | 1 | 0x41 | 0x00 21:25:48 #11 Phase 24 File dlgbrnst.cpp, Line 1832 Caching of files started 21:25:48 #12 Text 0 File Burncd.cpp, Line 4120 Cache writing successful. 21:25:48 #13 Phase 25 File dlgbrnst.cpp, Line 1832 Caching of files completed 21:25:48 #14 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 10x (1 500 KB/s) 21:25:48 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2654 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 21:25:48 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654 Verifying disc position of item 1 (not relocatable, no disc pos, no patch infos, orig at #450): write at #450 21:25:48 #17 Text 0 File Mmc.cpp, Line 16924 StartDAO : CD-Text - Off 21:25:48 #18 Text 0 File Mmc.cpp, Line 21708 Set BUFE: Buffer underrun protection -> ON 21:25:48 #19 SCSI -1067 File Cdrdrv.cpp, Line 1180 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03F03C00 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x00 CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x30 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x5D 0x34 0x05 0x90 0x26 0x00 21:25:48 #20 Text 0 File Mmc.cpp, Line 17211 CueData, Len=48 41 00 00 34 00 00 00 00 41 01 00 21 00 00 00 00 41 01 01 21 00 00 02 00 41 02 00 21 00 00 03 49 41 02 01 21 00 00 08 00 41 aa 01 34 00 43 04 1f 21:25:48 #21 CDR -1067 File ThreadedTransferInterface.cpp, Line 1771 Invalid field in parameter 21:25:48 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1771 Could not perform start of Disc-at-once 21:25:48 #23 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 10x (1 500 KB/s) Existing drivers: File ‘Drivers\CDRALW2K.SYS’: Ver=8.0.0.212 , size=2560 bytes, created 2006-10-05 04:42:42 File ‘Drivers\PXHELP20.SYS’: Ver=3.00.41a, size=36560 bytes, created 2006-09-27 23:53:22 (Prassi/Veritas driver for win 2K) File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 22:59:44 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
