namer
(Namer91)
22 Październik 2005 17:11
#1
Musze zainstalowac .net 1.1 posiadam IE 6 mimo tego przy instalce pisze ze musze miec minimum 5.01 lub wyzej i zebym zainstalowal i odpalil instalke jeszcze raz z reszta zobaczcie
[10/22/05,19:01:27] Starting Install.exe [10/22/05,19:01:27] Parsing switches from commandline: C:\WINDOWS\TEMP\IXP000.TMP\Install.exe [10/22/05,19:01:27] SourceDir: C:\WINDOWS\TEMP\IXP000.TMP\ [10/22/05,19:01:27] Install started [10/22/05,19:01:27] Checking system requirements [10/22/05,19:01:27] OS: Win 98 [10/22/05,19:01:27] Ver: Second Edition [10/22/05,19:01:27] SP: A [10/22/05,19:01:27] Checking Internet Explorer Version [10/22/05,19:01:27] Looking for 5.0.2919.6307 [10/22/05,19:01:27] Found Internet Explorer Version: 6.0.2800.1106 [10/22/05,19:01:27] Internet Explorer Version is OK… [10/22/05,19:01:27] System meets minimum requirements [10/22/05,19:01:27] Checking Windows Installer version… [10/22/05,19:01:27] Trying to load msi.dll [10/22/05,19:01:27] Loading: C:\WINDOWS\SYSTEM\msi.dll [10/22/05,19:01:27] msi.dll loaded ok [10/22/05,19:01:27] Looking for: 2.0.2600 [10/22/05,19:01:27] Found: 2.0.2600 [10/22/05,19:01:27] Windows Installer version ok [10/22/05,19:01:27] Finished Checking Windows Installer version. [10/22/05,19:01:27] Trying to load msi.dll [10/22/05,19:01:27] Loading: C:\WINDOWS\SYSTEM\msi.dll [10/22/05,19:01:27] Looking for mscoree.dll from PDC [10/22/05,19:01:27] mscoree.dll from PDC is not installed local [10/22/05,19:01:27] Looking for mscoree.dll from Beta [10/22/05,19:01:27] mscoree.dll is not installed local [10/22/05,19:01:27] Trying to load msi.dll [10/22/05,19:01:27] Loading: C:\WINDOWS\SYSTEM\msi.dll [10/22/05,19:01:27] Installing: C:\WINDOWS\TEMP\IXP000.TMP\netfx.msi [10/22/05,19:01:27] StopDarwinService() - Note: Win9x/Win31 machine, not necessary to stop the darwin service. Continuing with setup… [10/22/05,19:01:27] Trying to load msi.dll [10/22/05,19:01:27] Loading: C:\WINDOWS\SYSTEM\msi.dll [10/22/05,19:01:27] Full UI [10/22/05,19:01:27] Calling MsiInstallProduct() with commandline: REBOOT=ReallySuppress [10/22/05,19:01:45] MsiInstallProduct() returned 1603 [10/22/05,19:01:45] [MsiInstallProduct] ReturnCode=1603
Potem mamy bledzik
Jestem posiadaczem win 98 SE
