Już wszystko działa bez zarzutu!
W razie czego wklejam logi po restarcie komputera:
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\WinampAgent deleted successfully.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\AdobeBridge deleted successfully.
Registry value HKEY_CURRENT_USER\SOFTWARE\Classes\exefile\shell\open\command\’’ updated successfully.
File “C:\Documents and Settings\Justyna\Local Settings\Application Data\qbk.exe” -a “%1” %* not found.
Registry key HKEY_CURRENT_USER\Software\Classes.exe\ deleted successfully.
Registry key HKEY_CURRENT_USER\Software\Classes\exefile\ deleted successfully.
HKEY_LOCAL_MACHINE\Software\Classes.exe\|exefile /E : value set successfully!
C:\WINDOWS\system32\drivers\str.sys moved successfully.
C:\WINDOWS\system32\crt.dat moved successfully.
C:\WINDOWS\system32\shimg.dll moved successfully.
========== FILES ==========
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk moved successfully.
C:\Documents and Settings\All Users\Application Data\52127crj46v8gbyx8xrk6j27r0jjxu46ym024ki11u moved successfully.
C:\Documents and Settings\Justyna\Local Settings\Application Data\52127crj46v8gbyx8xrk6j27r0jjxu46ym024ki11u moved successfully.
File\Folder C:\Documents and Settings\All Users\Application Data\52127crj46v8gbyx8xrk6j27r0jjxu46ym024ki11u not found.
C:\Documents and Settings\All Users\Application Data\i25yncrr27168783v12a5c3x328l moved successfully.
C:\Documents and Settings\Justyna\Local Settings\Application Data\i25yncrr27168783v12a5c3x328l moved successfully.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: Default User
->Temp folder emptied: 61200526 bytes
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 42016 bytes
User: Guest
->Temp folder emptied: 58056064 bytes
->Temporary Internet Files folder emptied: 861285 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 45081128 bytes
->Flash cache emptied: 1587 bytes
User: Justyna
->Temp folder emptied: 5083778898 bytes
->Temporary Internet Files folder emptied: 31344117 bytes
->Java cache emptied: 6266327 bytes
->FireFox cache emptied: 67712011 bytes
->Flash cache emptied: 1571 bytes
User: LocalService
->Temp folder emptied: 0 bytes
User: NetworkService
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 2577 bytes
%systemroot%\System32\dllcache .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 8900025 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 139352414 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33438 bytes
RecycleBin emptied: 4282642402 bytes
Total Files Cleaned = 9 332,00 mb
OTL by OldTimer - Version 3.2.27.0 log created on 09042011_113224
Files\Folders moved on Reboot…
File\Folder C:\WINDOWS\temp\Perflib_Perfdata_164.dat not found!
Registry entries deleted on Reboot…
Bardzo dziękuję za poświęcenie mi czasu oraz pomoc. Jestem naprawdę wdzięczna!
