Witam.
W przeglądarce Opera nie mogę odtwarzać filmów na vod.onet.pl, a mam zainstalowany Silverlight. Jakaś rada?
Witam.
ramoses7 , tak
// ==UserScript==
// @include http://vod.onet.pl/*
// ==/UserScript==
(function ()
if (location.hostname.indexOf('onet.pl') != -1)
var myHandler = function myHandler(e) {
if( location.pathname.match(/\.(txt|text|js|css|cpp|src)$/) ) { return; }
var mystylesheet = '' +
'div[id="playerka_plugin_ew_ctnr"] {display: none !important;}' +
'div[id="playerka_plugin_ad_ctnr"] {display: none !important;}' +
'div[class="platnosci"],div[id="platnosci"] {display: none !important;}' +
'div[id="playerFoot"] {display: none !important;}' +
'body {}'
var vodonet= document.getElementById('vodonet.js');
if(vodonet== null)
var newstyle = document.createElement("style");
newstyle.setAttribute('type', 'text/css');
newstyle.setAttribute('id', 'vodonet.js');
newstyle.appendChild(document.createTextNode(mystylesheet));
document.getElementsByTagName('head')[0].appendChild(newstyle);
else
{return;}
window.opera.addEventListener('BeforeEvent.load',myHandler,true);
window.opera.addEventListener('BeforeScript', function (e)
e.element.text = e.element.text.replace('Opera','Firefox');
e.element.text = e.element.text.replace(new RegExp('{"ts":[0-9]+.[0-9]+,"type":"ad","id":"(.*)"}'),'');
e.element.text = e.element.text.replace('"ad_pre":1','"ad_pre":0');
e.element.text = e.element.text.replace('"ad_post":1','"ad_post":0');
e.element.text = e.element.text.replace('"views_left":-1','"views_left":0');
}, false);
window.opera.addEventListener('BeforeEventListener.load', function (){
var vodonet_str = document.getElementById('vodonet_str');
if(vodonet_str != null)
{return;}
else
{if(vodonet != null)
{ var newstr = document.createElement("div");
newstr.setAttribute('style', 'display: none');
newstr.setAttribute('id', 'vodonet_str');
newstr.appendChild(document.createTextNode("vodonet!"));
document.getElementsByTagName('body')[0].appendChild(newstr);}
},true);
Skopiuj i wklej do nowego tekstowego i zapisz jako vod.js
Następnie umieść go w folderze z Twoimi skryptami ,jak go jeszcze nie posiadasz to zrób folder np UserJS w C:\Documents and Settings\TwojeKonto\Dane aplikacji\Opera\Opera .Następnie w Operze otwórz Preferencje i w zakładce Zaawansowane > Zawartość > Opcje JavaScript, w polu Moje pliki JavaScript, wybierz folder ze skryptami.Restart Opery i vod.onet śmiga aż miło(przynajmniej powinien )
Dzięki bardzo. Działa! Rewelacja.
A czy przy aktualizacji opery nie będzie żadnych problemów?
Nie
