Witam.
Posiadam router ADSL Pentagram Cerberus P6331-6 i neostradę 10 Mb/s. Problem polega na tym, że wczoraj na routerze zgasła dioda PPP i nie potrafię tego naprawić. W ustawieniach routera w tym czasie nie było nic zmieniane. Z modemem internet działa normalnie.
Screeny z ustawień routera:
Edit: Po zmianie Modulatora na ADSL2+ też nie działa, ale Operationa Mode ciagle pozostaje ADSL G.DMT.
Log routera
Jan 1 00:00:06 syslog: OS (14:34:29, Apr 3 2008)
Jan 1 00:00:06 syslog: 176.94 MIPS
Jan 1 00:00:06 syslog: ============================================================
Jan 1 00:00:06 syslog: TC3162 PCI interface initialize
Jan 1 00:00:06 syslog: wdt_init ..
Jan 1 00:00:06 syslog: TC3162 watchdog initialize at Interrupt 9
Jan 1 00:00:06 syslog: init ADSL status timer
Jan 1 00:00:06 syslog: Ethernet driver for TC3162L2 version 1.0mac: 00:04:ed:a3:23:bd
Jan 1 00:00:07 syslog: on eth0 (IRQ: 21), (mac 00:04:ed:a3:23:bd)
Jan 1 00:00:07 syslog: eth0: driver installation completed.
Jan 1 00:00:07 syslog: TSARM: TC3162 ATM SAR driver 2.0.D3 init
Jan 1 00:00:07 syslog: TSARM: TC3162 ATM SAR driver 2.0.D3 done
Jan 1 00:00:07 syslog: TC3162 hardware watchdog module loaded.
Jan 1 00:00:07 syslog: tc3162 flash: probing 16-bit flash bus
Jan 1 00:00:07 syslog: TC3162 nor-flash: Probing for AMD compatible flash...
Jan 1 00:00:07 syslog: TC3162 nor-flash: Found 1 x 4MiB MXIC MX29LV320AB at 0x0
Jan 1 00:00:07 syslog: create 6 flash partitions
Jan 1 00:00:07 syslog: ADSL DMT initialization starting
Jan 1 00:00:07 syslog: Begin AdslTaskInit.....
Jan 1 00:00:07 syslog: End AdslTaskInit
Jan 1 00:00:07 syslog: Begin to request IRQ 19
Jan 1 00:00:07 syslog: DMT:Succeed to request IRQ 19
Jan 1 00:00:07 syslog: Initializing ADSL F/W 3.7.6.98 ......
Jan 1 00:00:07 syslog: Initializing ADSL F/W ........ done ^M
Jan 1 00:00:07 syslog: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 00:00:07 syslog: TCP: Hash tables configured (established 1024 bind 2048)
Jan 1 00:00:07 syslog: IP multicast router 0.06 plus PIM-SM
Jan 1 00:00:07 syslog: the ip_max_connection=3584, the udp_max_connection=1792, and tcp_large_port_max_connection=896
Jan 1 00:00:07 syslog: **********************************************
Jan 1 00:00:07 syslog: RT61AP Wireless Driver version-1.0.8.0-3
Jan 1 00:00:10 syslog: eth0: starting interface.
Jan 1 00:00:12 syslog: SETSNOOP : 0
Jan 1 00:00:29 syslog: Disable VLAN
Jan 1 00:00:31 syslog: device eth0 entered promiscuous mode
Jan 1 00:00:31 syslog: br0: port 1(eth0) entering learning state
Jan 1 00:00:31 syslog: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:31 syslog: br0: topology change detected, propagating
Jan 1 00:00:32 syslog: device ra0 entered promiscuous mode
Jan 1 00:00:32 syslog: br0: port 2(ra0) entering learning state
Jan 1 00:00:32 syslog: br0: port 2(ra0) entering forwarding state
Jan 1 00:00:32 syslog: br0: topology change detected, propagating
Jan 1 00:00:32 syslog: Set LAN MII
Jan 1 00:00:32 syslog: Switch soft-Reset
Jan 1 00:00:34 DHCP SERVER: DHCP request from f0:4d:a2:d1:d4:f1
Jan 1 00:00:34 DHCP SERVER: DHCP ack to f0:4d:a2:d1:d4:f1
Jan 1 00:00:35 syslog: ANNEXA^M
Jan 1 00:00:35 syslog: OlrOFF^M
Jan 1 00:00:36 syslog: Execute Sync symbol update! ^M
Jan 1 00:00:36 syslog: wdt_open ..
Jan 1 00:00:38 syslog: the configure tcp_large_port_timeout=120
Jan 1 00:00:38 syslog: after tcp_large_port_timeout=120
Jan 1 00:00:39 syslog: the configure wlan_ignore_interrupt=1
Jan 1 00:00:39 syslog: after wlan_ignore_interrupt=1
Jan 1 00:00:41 DHCP SERVER: DHCPINFORM from 192.168.1.100
Jan 1 00:00:44 DHCP SERVER: DHCPINFORM from 192.168.1.100
Jan 1 00:00:48 PPPoA[115]: Vc-mux encapsulation
Jan 1 00:00:48 PPPoA[115]: interface,vpi,vci:0.0.35
Jan 1 00:00:48 PPPoA[115]: pppoa module started
Jan 1 00:00:54 syslog: atm init aal5
Jan 1 00:00:55 syslog: LINK_PPPOE=1
Jan 1 00:00:55 syslog: pid=115
Jan 1 00:00:57 DNS RELAY: start.
Jan 1 00:01:00 syslog: Linesync achieved
Jan 1 00:01:00 syslog: ADSL line is up
Jan 1 00:01:00 syslog: Downstream rate: 8128 kbps
Jan 1 00:01:00 syslog: Upstream rate: 1088 kbps
Jan 1 00:01:02 syslog: UPNP start,port:2800
Jan 1 00:01:19 syslog: atm init aal5
Jan 1 00:01:43 syslog: atm init aal5
[/code]
