WITAM!![]()
Chcial bym sie dowiedziec co mam zrobic zeby bylo slychac Muzyke itp.
Chyba chodzi o to jaka karte muzyczna/dzwiekowa mam, nie mam pojecia.
/ POZDRAWIAM /
System Information
Time of this report: 1/13/2010, 22:49:51
Machine name: PC
Operating System: Windows XP Professional x64 Edition (5.2, Build 3790) Service Pack 2 (3790.srv03_sp2_qfe.090805-1438)
Language: English (Regional Setting: Polish)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: M52L-S3P
BIOS: Default System BIOS
Processor: AMD Phenom II X4 810 Processor (4 CPUs), ~2.6GHz
Memory: 8192MB RAM
Page File: 373MB used, 7891MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.3790.3959 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: NVIDIA
DAC type: 8 bit
Device Key: Enum\PCI\VEN_10DEDEV_0614SUBSYS_311519DAREV_A2
Display Memory: n/a
Current Mode: 1280 x 1024 (32 bit) (1Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: vga.dll
Driver Version: 5.02.3790.1830 (Polish)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 2/18/2007 13:00:00, 16384 bytes
WHQL Logo’d: n/a
WHQL Date Stamp: n/a
VDD: n/d
Mini VDD: vgapnp.sys
Mini VDD Date: 3/24/2005 17:34:48, 33792 bytes
Device Identifier: {D7B71E3E-4554-11CF-4C7D-DB1F0FC2C835}
Vendor ID: 0x10DE
Device ID: 0x0614
SubSys ID: 0x311519DA
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo’d:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\etc\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mysz
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Klawiatura
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
- USB Root Hub
| Vendor/Product ID: 0x10DE, 0x03F1
| Matching Device ID: usb\root_hub
| Service: usbhub
±+ USB Human Interface Device
| | Vendor/Product ID: 0x09DA, 0x0080
| | Matching Device ID: usb\class_03subclass_01
| | Service: HidUsb
| ±+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
Gameport Devices
PS/2 Devices
- Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
- Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
- Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.3790.3959)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.3790.3959)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.3790.3959)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.3790.3959)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Po
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk DVD/CD-ROM Drives
Drive: C:
Free Space: 472.9 GB
Total Space: 476.9 GB
File System: NTFS
Model: SAMSUNG HD502HI SCSI Disk Device
Drive: D:
Model: ATAPI DVD A DH20A4P
Driver: c:\windows\system32\drivers\cdrom.sys, , 0 bytes
System Devices
Name: Standard VGA Graphics Adapter
Device ID: PCI\VEN_10DEDEV_0614SUBSYS_311519DAREV_A2\4228469D000048
Driver: n/a
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DEDEV_03F6SUBSYS_B0021458REV_A2\32411E6FE040
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DEDEV_03F5SUBSYS_0C111458REV_A2\32411E6FE00A
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DEDEV_03F3SUBSYS_00000000REV_A1\32411E6FE020
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DEDEV_03F2SUBSYS_50041458REV_A3\32411E6FE011
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DEDEV_03F1SUBSYS_50041458REV_A3\32411E6FE010
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DEDEV_03F0SUBSYS_A0021458REV_A2\32411E6FE028
Driver: n/a
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DEDEV_03EFSUBSYS_E0001458REV_A2\32411E6FE038
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DEDEV_03ECSUBSYS_50021458REV_A2\32411E6FE030
Driver: n/a
Name: NVIDIA nForce System Management
Device ID: PCI\VEN_10DEDEV_03EBSUBSYS_0C111458REV_A2\32411E6FE009
Driver: n/a
Device ID: PCI\VEN_10DEDEV_03EASUBSYS_50011458REV_A1\32411E6FE000
Driver: n/a
Device ID: PCI\VEN_10DEDEV_03E8SUBSYS_00000000REV_A2\32411E6FE048
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DEDEV_03E0SUBSYS_00000000REV_A2\32411E6FE008
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022DEV_1204SUBSYS_00000000REV_00\32411E6FE0C4
Driver: n/a
Device ID: PCI\VEN_1022DEV_1203SUBSYS_00000000REV_00\32411E6FE0C3
Driver: n/a
Device ID: PCI\VEN_1022DEV_1202SUBSYS_00000000REV_00\32411E6FE0C2
Driver: n/a
Device ID: PCI\VEN_1022DEV_1201SUBSYS_00000000REV_00\32411E6FE0C1
Driver: n/a
Device ID: PCI\VEN_1022DEV_1200SUBSYS_00000000REV_00\32411E6FE0C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.3790.1830 English Final Retail 11/5/2009 13:43:09 283136 bytes
ddrawex.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 28160 bytes
d3d8.dll: 5.03.3790.4336 English Final Retail 11/5/2009 13:42:41 1042432 bytes
d3d8thk.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 8192 bytes
d3d9.dll: 5.03.3790.4336 English Final Retail 10/25/2009 17:24:29 1690624 bytes
d3dim.dll: 5.02.3790.3959 English Final Retail 2/18/2007 13:00:00 378880 bytes
d3dim700.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 835584 bytes
d3dramp.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 590848 bytes
d3drm.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 351744 bytes
d3dxof.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 48128 bytes
d3dpmesh.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 36864 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 2/18/2007 13:00:00 33040 bytes
dplayx.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 230400 bytes
dpmodemx.dll: 5.03.3790.1830 English Final Retail 11/5/2009 13:45:48 24064 bytes
dpwsockx.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:46:07 57344 bytes
dplaysvr.exe: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 31744 bytes
dpnsvr.exe: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 17920 bytes
dpnet.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:45:54 376320 bytes
dpnlobby.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 3584 bytes
dpnaddr.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 3584 bytes
dpvoice.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:46:00 536576 bytes
dpvsetup.exe: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 83968 bytes
dpvvox.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 116736 bytes
dpvacm.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 22016 bytes
dpnhpast.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 4096 bytes
dpnhupnp.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 60928 bytes
dinput.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:44:25 163840 bytes
dinput8.dll: 5.03.3790.1830 English Final Retail 11/5/2009 13:44:34 186368 bytes
dimap.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 42496 bytes
diactfrm.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:44:18 415744 bytes
joy.cpl: 5.03.3790.3959 English Final Retail 11/11/2009 18:51:33 207360 bytes
gcdef.dll: 5.03.3790.3959 English Final Retail 11/8/2009 11:57:52 238080 bytes
pid.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 33792 bytes
dsound.dll: 5.03.3790.3959 English Final Retail 11/5/2009 13:46:56 360960 bytes
dsound3d.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 1294848 bytes
dswave.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 19456 bytes
dsdmo.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 182272 bytes
dsdmoprp.dll: Final Retail 11/5/2009 13:46:34 28152 bytes
dmusic.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 104448 bytes
dmband.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 28672 bytes
dmcompos.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 61952 bytes
dmime.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 181760 bytes
dmloader.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 36352 bytes
dmstyle.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 105984 bytes
dmsynth.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 103424 bytes
dmscript.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 82432 bytes
dx7vb.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 621056 bytes
dx8vb.dll: 5.03.3790.3959 English Final Retail 2/18/2007 13:00:00 1225216 bytes
dxdiagn.dll: 5.03.3790.3959 Polish Final Retail 11/5/2009 13:47:32 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 2/18/2007 13:00:00 924432 bytes
mfc42.dll: 6.06.8063.0000 English Beta Retail 11/12/2009 14:19:43 1163776 bytes
wsock32.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 22528 bytes
amstream.dll: 6.05.3790.3959 English Final Retail 2/18/2007 13:00:00 72704 bytes
devenum.dll: 6.05.3790.3959 English Final Retail 11/5/2009 13:43:58 61440 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 11/5/2009 13:47:38 499766 bytes
mciqtz32.dll: 6.05.3790.3959 English Final Retail 11/12/2009 14:18:34 62464 bytes
mpg2splt.ax: 6.05.3790.3959 English Final Retail 2/18/2007 13:00:00 148992 bytes
msdmo.dll: 6.05.3790.1830 English Final Retail 2/18/2007 13:00:00 14336 bytes
encapi.dll: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/25/2009 17:35:15 211456 bytes
qcap.dll: 6.05.3790.3959 English Final Retail 11/17/2009 15:10:38 192512 bytes
qdv.dll: 6.05.3790.3959 English Final Retail 11/17/2009 15:10:52 279040 bytes
qdvd.dll: 6.05.3790.3959 English Final Retail 11/17/2009 15:11:03 386048 bytes
qedit.dll: 6.05.3790.3959 English Final Retail 11/17/2009 15:11:11 513536 bytes
qedwipes.dll: 6.05.3790.1830 English Final Retail 2/18/2007 13:00:00 733696 bytes
quartz.dll: 6.05.3790.4523 English Final Retail 11/17/2009 15:11:20 1282048 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 10/25/2009 17:25:08 247326 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 2/18/2007 13:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 2/18/2007 13:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 2/18/2007 13:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 2/18/2007 13:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 2/18/2007 13:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 2/18/2007 13:00:00 183808 bytes
mswebdvd.dll: 6.05.3790.4565 English Final Retail 11/15/2009 13:06:49 209920 bytes
ksuser.dll: 5.03.3790.1830 Polish Final Retail 2/18/2007 13:00:00 4096 bytes
mpeg2data.ax: 6.05.3790.3959 English Final Retail 2/18/2007 13:00:00 62976 bytes
msvidctl.dll: 6.05.3790.3959 English Final Retail 11/15/2009 12:57:52 1563648 bytes
vbisurf.ax: 5.03.3790.1830 English Final Retail 2/18/2007 13:00:00 30720 bytes
msyuv.dll: 5.02.3790.0000 English Final Retail 2/18/2007 13:00:00 16896 bytes
wstdecod.dll: 5.03.3790.1830 English Final Retail 11/22/2009 17:13:42 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,
WMAPro over S/PDIF DMO,0x00600800,1,1,
WMA Voice Decoder DMO,0x00600800,1,1,
Mpeg4s Decoder DMO,0x00800001,1,1,
WMV Screen decoder DMO,0x00600800,1,1,
WMVideo Decoder DMO,0x00800001,1,1,
Mpeg43 Decoder DMO,0x00800001,1,1,
Mpeg4 Decoder DMO,0x00800001,1,1,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4029.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.3790.4523
DV Muxer,0x00400000,0,0,qdv.dll,6.05.3790.3959
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.3790.4523
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.3790.4523
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.3790.4523
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.3790.3959
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.3790.3959
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.3790.4523
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4029.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.3790.4523
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.3790.4523
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.3790.3959
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.3790.4523
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.3790.4523
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4029.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.3790.3959
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.3790.4523
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.3790.4523
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.3790.4523
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.3790.3959
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.3790.3959
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.3790.4523
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.3790.1830
Video Renderer,0x00400000,1,0,quartz.dll,6.05.3790.4523
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.3790.1830
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.3790.3959
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4029.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.3790.3959
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.3790.3959
AVI Draw,0x00600064,9,1,quartz.dll,6.05.3790.4523
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.02.3790.1830
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.3790.3959
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.3790.3959
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.3790.3959
Null Renderer,0x00200000,1,0,qedit.dll,6.05.3790.3959
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4029.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.3790.3959
Smart Tee,0x00200000,1,2,qcap.dll,6.05.3790.3959
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.3790.3959
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.3790.4523
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.3790.4523
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.3790.4523
Wave Parser,0x00400000,1,1,quartz.dll,6.05.3790.4523
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.3790.4523
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.3790.4523
File stream renderer,0x00400000,1,1,quartz.dll,6.05.3790.4523
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.3790.3959
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.3790.4523
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.3790.4523
File Source (URL),0x00400000,0,1,quartz.dll,6.05.3790.4523
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4029.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.3790.3959
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.3790.4523
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.3790.4523
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,
WMVideo9 Encoder DMO,0x00600800,1,1,
MSScreen 9 encoder DMO,0x00600800,1,1,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.3790.3959
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.3790.4523
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.3790.3959
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.3790.3959
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.3790.3959
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.3790.3959
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.3790.3959
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.3790.3959
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.3790.3959
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.3790.3959
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,
WMAudio Encoder DMO,0x00600800,1,1,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.3790.4523
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.3790.4523
ACELP.net,0x00200000,1,1,quartz.dll,6.05.3790.4523
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.3790.4523
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.3790.4523
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.3790.4523
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.3790.4523
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.3790.4523
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.3790.4523
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.3790.4523
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.3790.4523
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.3790.4523
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.3790.4523
