Dzieki.
Mimo wszystko postanowiłem zrobić format C:, stwierdziełem ze moze to cos ulatwi. Pos sformatowaniu plik related.htm mimo wszystko znajdował się na dysku.
Usunalem go. A oto log z Silent Runners:
"Silent Runners.vbs", revision R50, http://www.silentrunners.org/
Operating System: Windows XP
Output limited to non-default values, except where indicated by "{++}"
Startup items buried in registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
"CTFMON.EXE" = "C:\WINDOWS\System32\ctfmon.exe" [MS]
"MSMSGS" = ""C:\Program Files\Messenger\msmsgs.exe" /background" [MS]
HKLM\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
"{42071714-76d4-11d1-8b24-00a0c9068ff3}" = "Rozszerzenie CPL kadrowania wyświetlania"
-> {HKLM...CLSID} = "Rozszerzenie CPL kadrowania wyświetlania"
\InProcServer32\(Default) = "deskpan.dll" [file not found]
"{88895560-9AA2-1069-930E-00AA0030EBC8}" = "Rozszerzenie ikony HyperTerminalu"
-> {HKLM...CLSID} = "HyperTerminal Icon Ext"
\InProcServer32\(Default) = "C:\WINDOWS\System32\hticons.dll" ["Hilgraeve, Inc."]
Group Policies {GPedit.msc branch and setting}:
Note: detected settings may not have any effect.
HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System\
"shutdownwithoutlogon" = (REG_DWORD) hex:0x00000001
{Computer Configuration|Windows Settings|Security Settings|Local Policies|Security Options|
Shutdown: Allow system to be shut down without having to log on}
"undockwithoutlogon" = (REG_DWORD) hex:0x00000001
Devices: Allow undock without having to log on}
Active Desktop and Wallpaper:
Active Desktop may be disabled at this entry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
Displayed if Active Desktop enabled and wallpaper not set by Group Policy:
HKCU\Software\Microsoft\Internet Explorer\Desktop\General\
"Wallpaper" = "C:\WINDOWS\web\wallpaper\Idylla.bmp"
Displayed if Active Desktop disabled and wallpaper not set by Group Policy:
HKCU\Control Panel\Desktop\
Enabled Screen Saver:
"SCRNSAVE.EXE" = "C:\WINDOWS\System32\logon.scr" [MS]
Startup items in "Koliberek" & "All Users" startup folders:
C:\Documents and Settings\All Users\Menu Start\Programy\Autostart
"Program sieciowy dla SAGEM Wi-Fi 11g USB adapter" -> shortcut to: "C:\Program Files\SAGEM WiFi manager\WLANUTL.exe" [" "]
Winsock2 Service Provider DLLs:
Namespace Service Providers
HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
000000000001\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
000000000002\LibraryPath = "%SystemRoot%\System32\winrnr.dll" [MS]
000000000003\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
Transport Service Providers
HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
%SystemRoot%\system32\mswsock.dll [MS], 01 - 03, 06 - 13
%SystemRoot%\system32\rsvpsp.dll [MS], 04 - 05
+ This report excludes default entries except where indicated.
+ To see *everywhere* the script checks and *everything* it finds,
launch it from a command prompt or a shortcut with the -all parameter.
+ To search all directories of local fixed drives for DESKTOP.INI
DLL launch points, use the -supp parameter or answer "No" at the
first message box and "Yes" at the second message box.
---------- (total run time: 149 seconds, including 36 seconds for message boxes)
Tylko teraz troche boje sie sciagac nawet inna przegladarke niz IE, poniewaz ostatbnim razem przed sciagnieciem niby wszystko bylo w porzadku. A jak tylko zona sciagnela Firefox i Opere problem znow sie pojawil.
Pozniej korzystanie z internetu bylo wrecz niemozliwe poniewaz wybierane strony nie dzialaly, cos podmienialo adresy wiec nawet nie moglem polaczyc sie z zadnym antywirusem. UZywalem tych z CD.
Naprawde chialbym sie tego pozbyc , straciłem kilka długich dni probujac sie tego pozbyc. Nie zycze tego Wam.
A tak swoja droga dlaczego formatowanie nie pomogło? Gdzie tego rodzaju spyware jest przechowywane, skoro nawet formatowanie nie pomaga.
W tym momencie licze na Wasza pomoc. Wielkie dzieki, z góry.
Złączono Posta : 01.07.2007 (Nie) 16:02
Mozliwe, że to wina komputera? Bo znow w świeżym systemie zaczynają sie “kwiatki”
