Witam tak jak w temacie podczas próby nagrania płyty DVD wyskakuje taki błąd.w czym tkwi problem?
Windows XP 5.1
IA32
WinAspi: File ‘Wnaspi32.dll’: Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56
ahead WinASPI: File ‘C:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:31
NT-SPTI used
Nero Version: 6.6.1.6
Internal Version: 6, 6, 1, 6
(Nero Express)
Recorder: Version: HL09 - HA 1 TA 0 - 6.6.1.6
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: Version: HL09 - HA 1 TA 0 - 6.6.1.6
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW LH-18A1H atapi Port 0 ID 0 DMA: Off
DiskPeripheral : ST3160811AS atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-18A1H F: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523632kB)
Free physical memory: 140MB (143512kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.12.2008
Kompilacja ISO
12:33:24 #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:33:24 #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 72704KB of Memory
12:33:24 #3 Text 0 File Reader.cpp, Line 124
Reader running
12:33:24 #4 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW LH-18A1H running
12:33:24 #5 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
12:33:24 #6 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using DVD media
12:33:24 #7 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 52783 ( 11:43.58, 103MB)
12:33:24 #8 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
12:33:24 #9 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: LITE-ON DVDRW LH-18A1H, Media type: DVD+R
Disc Manufacturer ID: MJC, Media Type ID: 003, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
12:33:24 #10 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
12:33:24 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 52784 (52784) = #52784/11:43.59
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 52784 blocks [LITE-ON DVDRW LH-18A1H]
12:33:24 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [LITE-ON DVDRW LH-18A1H] for write in CUE-sheet-DAO
DAO infos:
MCN: “”
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 108101632, ISRC “”
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
52784 | lead-out | 1 | 0x41 | 0x00
12:33:24 #13 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:33:24 #14 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:33:24 #15 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
12:33:24 #16 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
12:33:24 #17 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
12:33:24 #18 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 4x (5 540 KB/s)
12:33:24 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:33:24 #20 Text 0 File Cdrdrv.cpp, Line 8648
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: MJC…
Media type ID: 003
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16…63]:
00 00 03 4D 4A 43 00 00 - 00 00 00 30 30 33 00 38 …MJC…003.8
23 54 37 12 02 3C 6C 02 - A0 69 15 15 0B 0B 08 08 #T7…
01 19 1B 0C 0C 0B 0C 00 - 00 00 00 00 00 00 00 00 …
12:33:24 #21 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: No
12:33:42 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 289
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x07f60000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
12:33:42 #23 CDR -1106 File Writer.cpp, Line 311
Power calibration error
F: LITE-ON DVDRW LH-18A1H
12:33:42 #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:33:42 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:33:42 #26 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File ‘Drivers\CDRALW2K.SYS’: Ver=8.0.0.212 , size=9464 bytes, created 2007-03-08 00:51:00
File ‘Drivers\ASPI32.SYS’: Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02
File ‘Drivers\PXHELP20.SYS’: Ver=3.00.56a, size=43528 bytes, created 2007-03-08 00:51:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
