Witam.
Podczas skanowania partycji starego dysku twardego komputer się resetuje. Wywala komunikat o krytycznym błędzie, który po wgraniu do dumpa wygląda następująco:
"Microsoft ® Windows Debugger Version 6.11.0001.402 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 2600.xpsp_sp3_gdr.080814-1236
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x80554040
Debug session time: Sun Apr 5 13:24:07.984 2009 (GMT+2)
System Uptime: 0 days 1:32:45.562
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9C, {4, 80546e70, b2000000, 70f0f}
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
kd> !analyze -v
MACHINE_CHECK_EXCEPTION (9c)
A fatal Machine Check Exception has occurred.
KeBugCheckEx parameters;
x86 Processors
If the processor has ONLY MCE feature available (For example Intel
Pentium), the parameters are:
1 - Low 32 bits of P5_MC_TYPE MSR
2 - Address of MCA_EXCEPTION structure
3 - High 32 bits of P5_MC_ADDR MSR
4 - Low 32 bits of P5_MC_ADDR MSR
If the processor also has MCA feature available (For example Intel
Pentium Pro), the parameters are:
1 - Bank number
3 - High 32 bits of MCi_STATUS MSR for the MCA bank that had the error
4 - Low 32 bits of MCi_STATUS MSR for the MCA bank that had the error
IA64 Processors
1 - Bugcheck Type
1 - MCA_ASSERT
2 - MCA_GET_STATEINFO
SAL returned an error for SAL_GET_STATEINFO while processing MCA.
3 - MCA_CLEAR_STATEINFO
SAL returned an error for SAL_CLEAR_STATEINFO while processing MCA.
4 - MCA_FATAL
FW reported a fatal MCA.
5 - MCA_NONFATAL
SAL reported a recoverable MCA and we don’t support currently
support recovery or SAL generated an MCA and then couldn’t
produce an error record.
0xB - INIT_ASSERT
0xC - INIT_GET_STATEINFO
SAL returned an error for SAL_GET_STATEINFO while processing INIT event.
0xD - INIT_CLEAR_STATEINFO
SAL returned an error for SAL_CLEAR_STATEINFO while processing INIT event.
0xE - INIT_FATAL
Not used.
2 - Address of log
3 - Size of log
4 - Error code in the case of x_GET_STATEINFO or x_CLEAR_STATEINFO
AMD64 Processors
1 - Bank number
Arguments:
Arg1: 00000004
Arg2: 80546e70
Arg3: b2000000
Arg4: 00070f0f
Debugging Details:
NOTE: This is a hardware error. This error was reported by the CPU
via Interrupt 18. This analysis will provide more information about
the specific error. Please contact the manufacturer for additional
information about this error and troubleshooting assistance.
This error is documented in the following publication:
- Bios and Kernel Developers Guid for AMD Athlon® 64 and AMD Opteron® Processors
Bit Mask:
MA Model Specific MCA
O ID Other Information Error Code Error Code
VV SDP ___________|____________ _______|_______ _______|______
AEUECRC| | | |
LRCNVVC| | | |
6 5 4 3 2 1
3210987654321098765432109876543210987654321098765432109876543210
1011001000000000000000000000000000000000000001110000111100001111
VAL - MCi_STATUS register is valid
Indicates that the information contained within the IA32_MCi_STATUS
register is valid. When this flag is set, the processor follows the
rules given for the OVER flag in the IA32_MCi_STATUS register when
overwriting previously valid entries. The processor sets the VAL
flag and software is responsible for clearing it.
UC - Error Uncorrected
Indicates that the processor did not or was not able to correct the
error condition. When clear, this flag indicates that the processor
was able to correct the error condition.
EN - Error Enabled
Indicates that the error was enabled by the associated EEj bit of the
IA32_MCi_CTL register.
PCC - Processor Context Corrupt
Indicates that the state of the processor might have been corrupted
by the error condition detected and that reliable restarting of the
processor may not be possible.
BUSCONNERR - Bus and Interconnect Error BUS{LL}_{PP}_{RRRR}_{II}_{T}_err
These errors match the format 0000 1PPT RRRR IILL
Concatenated Error Code:
_VAL_UC_EN_PCC_BUSCONNERR_30F
This error code can be reported back to the manufacturer.
They may be able to provide additional information based upon
this error. All questions regarding STOP 0x9C should be
directed to the hardware manufacturer.
BUGCHECK_STR: 0x9C_AuthenticAMD
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
PROCESS_NAME: GDFwSvc.exe
LAST_CONTROL_TRANSFER: from 806d58db to 804f8cc5
STACK_TEXT:
80546e48 806d58db 0000009c 00000004 80546e70 nt!KeBugCheckEx+0x1b
80546f74 806d0c2e 80042000 00000000 00000000 hal!HalpMcaExceptionHandler+0xdd
80546f74 00000000 80042000 00000000 00000000 hal!HalpMcaExceptionHandlerWrapper+0x46
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: 0x9C_AuthenticAMD_ANALYSIS_INCONCLUSIVE
Followup: MachineOwner"
Dodam, że wystarczy, że chcę wejść w którykolwiek folder na partycji o której mowa, klikając na niego, i następuje restart.
Ja nic z tego nie czaję.
Proszę o pomoc.
