Używam neostrady i jak komputer czasami dłużej chodzi to gdy wyłączam internet dochodzi do crashu. Jak sądzicie co jest istotą problemu?
Mam wydruki z windows debuggera:
Microsoft ® Windows Debugger Version 6.6.0007.5
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
Debug session time: Mon Sep 18 18:53:15.593 2006 (GMT+2)
System Uptime: 0 days 7:24:37.157
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {29263160, 2, 1, 88845000}
ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,214600,41108004
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for afd.sys
*** ERROR: Module load completed but symbols could not be loaded for afd.sys
Probably caused by : afd.sys ( afd+4483 )
Followup: MachineOwner
