Witam wiem że wiele osób szuka na ten problem rozwiązania jestem jednym z nich. Wertując internetowe fora jeszcze nic nie znalazłem
Po kilku minutach pracy komputera blue screen
KOD MOJEGO BŁĘDU:
STOP: 0x000000FE (0x00000002, 0x897F4858,0x897EBA20, 0x888B8A20)
Proszę o pomoc! Raport z DEBUGGGERA :
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805634c0
Debug session time: Tue Nov 18 14:18:38.968 2008 (GMT+1)
System Uptime: 0 days 0:13:50.684
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image USBPORT.SYS, Win32 error 0n2
*** WARNING: Unable to verify timestamp for USBPORT.SYS
*** ERROR: Module load completed but symbols could not be loaded for USBPORT.SYS
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck FE, {2, 88a67990, 898b3008, 890fc338}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** WARNING: Unable to verify timestamp for usbhub.sys
*** ERROR: Module load completed but symbols could not be loaded for usbhub.sys
*** WARNING: Unable to verify timestamp for NetMotCM.sys
*** ERROR: Module load completed but symbols could not be loaded for NetMotCM.sys
*** work. ***
*** work. ***
Probably caused by : NetMotCM.sys ( NetMotCM+bcd )
Followup: MachineOwne
