Witam
Mam problem z komputerem mianowicie przy korzystaniu z komputera co 10 min mam reset lub myszka/klawiatura mi nie działa /czarny ekran
robiłem co się dało format na xp viste nawet 98 i za każdym razem to samo a po resecie wyświetla mi błąd zmieniłem wszystkie sterowniki na nowe i nic
OTO ZAPIS Z DZIENNIKA SYSTEMU znaczy z debuggera
Microsoft ® Windows Debugger Version 6.11.0001.404 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055b1c0
Debug session time: Tue Nov 29 12:08:08.125 2011 (GMT+1)
System Uptime: 0 days 0:35:38.719
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image win32k.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, bf80257d, b7444c20, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : hardware ( win32k+257d )
Followup: MachineOwner
CO MAM ZROBIĆ JUŻ 5 LAT Z TYM WALCZĘ I NIC NA INNYCH FORACH COŚ PISZE ALE NIC Z TEGO NIE WYNIKA BŁAGAM O POMOC
MOJA KONFIGURACJA PECETA TO
Nazwa systemu operacyjnego Microsoft Windows XP Professional
Wersja 5.1.2600 Dodatek Service Pack 3 Kompilacja 2600
Producent systemu VIA
Model systemu K7VT2
Typ systemu Komputer z procesorem x86
Procesor x86 Family 6 Model 8 Stepping 1 AuthenticAMD ~1665 Mhz
Wersja/data systemu BIOS American Megatrends Inc. P1.30, 2003-03-07
Wersja SMBIOS 2.3
Ustawienia regionalne Polska
Warstwa abstrakcji sprzętu Wersja = “5.1.2600.5512 (xpsp.080413-2111)”
Całkowita pamięć fizyczna 512,00 MB
Dostępna pamięć fizyczna 119,39 MB
Całkowity rozmiar pamięci wirtualnej 2,00 GB
Dostępna pamięć wirtualna 1,95 GB
Obszar pliku strony 1,22 GB
DYSK 320GB
