Kupiłem sobie ostatnio grę Call of duty, wraz z dodtakiem united Offensive. Zainstalowałem elegancko wszystko i przy próbie uruchomienia gry wyskakuje mi taki błąd:
COD 1.0 build win-x86 Nov 13 2003
----- FS_Startup -----
Current language: english
Current search path:
D:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
D:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
D:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
D:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
D:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
D:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
D:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
D:\PROGRA~1\CALLOF~1/main
File Handles:
29647 files in pk3 files
execing default.cfg
couldn’t exec language.cfg
couldn’t exec config.cfg
couldn’t exec autoexec.cfg
========= autoconfigure
configure.csv: using configuration 800 cpu MHz 256 sys MB 64 vid MB
execing configure.cfg
cl_language will be changed upon restarting.
fs_basepath is write protected.
fs_homepath is write protected.
WARNING: No language string information available for english
Hunk_Clear: reset the hunk ok
…detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 1.10 GHz
System memory is 256 MB (capped at 1 GB)
Video card memory is 64 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘C:\WINDOWS\system32\opengl32.dll’ ): succeeded
…setting mode 4: 800 600 FS
…using colorbits of 32
…calling CDS: ok
…registered window class
…created window@0,0 (800x600)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 8 )
…35 PFDs found
…GLW_ChoosePFD failed
…GLW_ChoosePFD( 32, 24, 0 )
…35 PFDs found
…failed to find an appropriate PIXELFORMAT
…restoring display settings
…WARNING: could not set the given mode (4)
…shutting down QGL
…unloading OpenGL DLL
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
…initializing QGL
…setting mode 3: 640 480 FS
…calling CDS: ok
…created window@0,0 (640x480)
…35 PFDs found
…35 PFDs found
…WARNING: could not set the given mode (3)
…shutting down QGL
----- CL_Shutdown -----
RE_Shutdown( 1 )
Nie udało się załadować OpenGL. Upewnij się, że masz najnowsze sterowniki karty graficznej.
Proszę o pomoc. Mam kartę graficzną GeForce MX 440 a sterowniki NVIDIA wersja 5.6.7.3.
