Witam,
Oto plik dmp ktory otworzylem dzieki Debugger Windows:
BugCheck A, {82f3ced3, 2, 8, 82f3ced3}
*** WARNING: Unable to verify timestamp for Ntfs.sys
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
*** WARNING: Unable to verify timestamp for CLASSPNP.SYS
*** ERROR: Module load completed but symbols could not be loaded for CLASSPNP.SYS
*** WARNING: Unable to verify timestamp for ataport.SYS
*** ERROR: Module load completed but symbols could not be loaded for ataport.SYS
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Probably caused by : CLASSPNP.SYS ( CLASSPNP+4498 )
Dałem poczatek i koniec. Jeśli ktos moze mi to objaśnić to bardzo prosze ;p
