Witam kiedy robie test czy mogę włączyć przyjazne adresy w drupalu(cms) strona przyjmuje następującą postać:
http://img61.imageshack.us/img61/4642/cleanurlvn0.jpg ,
podczas gdy normalnie drupal wygląda jak na stronie http://www.telefoniczna.ovh.org
Mam serwer plan 90 na ovh.pl wiec raczej działa tam mod rewite Chce rozpocząć tworzenie stronki, ale nie mam pojęcia co trzeba zrobic, aby przyjazne adresy dzialaly bezproblemowo.
To mój htacces:
# Apache/PHP/Drupal settings:
# Protect files and directories from prying eyes.
Order allow,deny
# Don't show directory listings for URLs which map to a directory.
Options -Indexes
# Follow symbolic links in this directory.
Options +FollowSymLinks
# Customized error messages.
ErrorDocument 404 /index.php
# Set the default handler.
DirectoryIndex index.php
# Override PHP settings. More in sites/default/settings.php
# but the following cannot be changed at runtime.
# PHP 4, Apache 1.
php_value magic_quotes_gpc 0
php_value register_globals 0
php_value session.auto_start 0
# PHP 4, Apache 2.
# PHP 5, Apache 1 and 2.
# Requires mod_expires to be enabled.
# Enable expirations.
ExpiresActive On
# Cache all files for 2 weeks after access (A).
ExpiresDefault A1209600
# Do not cache dynamically generated pages.
ExpiresByType text/html A1
# Various rewrite rules.
RewriteEngine on
# If your site can be accessed both with and without the prefix www. you
# can use one of the following settings to force user to use only one option:
# If you want the site to be accessed WITH the www. only, adapt and
# uncomment the following:
# RewriteCond %{HTTP_HOST} ^example\.com$ [NC]
# RewriteRule .* http://www.example.com/ [L,R=301]
# If you want the site to be accessed only WITHOUT the www. prefix, adapt
# and uncomment the following:
# RewriteCond %{HTTP_HOST} ^www\.example\.com$ [NC]
# RewriteRule .* http://example.com/ [L,R=301]
# Modify the RewriteBase if you are using Drupal in a subdirectory and
# the rewrite rules are not working properly.
#RewriteBase /drupal
# Rewrite old-style URLs of the form 'node.php?id=x'.
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{QUERY_STRING} ^id=([^&]+)$
#RewriteRule node.php index.php?q=node/view/%1 [L]
# Rewrite old-style URLs of the form 'module.php?mod=x'.
#RewriteCond %{QUERY_STRING} ^mod=([^&]+)$
#RewriteRule module.php index.php?q=%1 [L]
# Rewrite current-style URLs of the form 'index.php?q=x'.
RewriteRule ^(.*)$ index.php?q=$1 [L,QSA]
# $Id: .htaccess,v 1.81 2007/01/09 09:27:10 dries Exp $
Proszę o pomoc
Złączono Posta : 27.07.2007 (Pią) 11:09
juz niewazne- PROSZE O USUNIECIE tematu
