zasilacz jest OCZ ModXStream-Pro 600W
– Dodane 26.09.2010 (N) 8:36 –
niewiem czemu ale tamten program mi si€ nie instaluje ale zainstalowaem whocrashed i pokazuje co takiego:
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Sun 26/09/2010 6.12.58 your computer crashed
This was likely caused by the following module: ati2dvag.dll
Bugcheck code: 0x1000008E (0xC0000005, 0x805398B3, 0x9DE2F0A8, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Dump file: C:\WINDOWS\Minidump\Mini092610-01.dmp
file path: C:\WINDOWS\system32\ati2dvag.dll
product: ATI Radeon WindowsNT Display Driver
company: ATI Technologies Inc.
description: ATI Radeon WindowsNT Display Driver
On Sat 25/09/2010 20.26.23 your computer crashed
This was likely caused by the following module: ntkrnlpa.exe
Bugcheck code: 0xA (0x6688060, 0x2, 0x1, 0x806E5904)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\WINDOWS\Minidump\Mini092510-04.dmp
file path: C:\WINDOWS\system32\ntkrnlpa.exe
product: Sistema operativo Microsoft® Windows®
company: Microsoft Corporation
description: Sistema e kernel NT
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Sat 25/09/2010 19.38.47 your computer crashed
This was likely caused by the following module: avgntflt.sys
Bugcheck code: 0x1000008E (0xC0000005, 0x80578A5B, 0x9E6E361C, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092510-03.dmp
file path: C:\WINDOWS\system32\drivers\avgntflt.sys
product: AntiVir Workstation
company: Avira GmbH
description: Avira Minifilter Driver
On Sat 25/09/2010 19.29.27 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x805398B3, 0xA3D2C4A8, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092510-02.dmp
On Sat 25/09/2010 18.03.25 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x805398B3, 0xA99314A8, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092510-01.dmp
On Fri 24/09/2010 18.49.25 your computer crashed
This was likely caused by the following module: ati3duag.dll
Bugcheck code: 0x1000007E (0xC0000005, 0x3F2B6AB9, 0xBA58FB80, 0xBA58F87C)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Dump file: C:\WINDOWS\Minidump\Mini092410-06.dmp
file path: C:\WINDOWS\system32\ati3duag.dll
product: ATI Technologies Inc. Radeon DirectX Universal Driver
description: ati3duag.dll
On Fri 24/09/2010 17.10.18 your computer crashed
Bugcheck code: 0x1000000A (0x0, 0x2, 0x1, 0x80522704)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092410-05.dmp
On Fri 24/09/2010 11.45.02 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x1000008E (0xC0000005, 0x805417F4, 0xA1BD2CF0, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092410-04.dmp
On Fri 24/09/2010 11.18.07 your computer crashed
Bugcheck code: 0x10000050 (0xE3AE0564, 0x0, 0xBF3E3903, 0x1)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092410-03.dmp
On Fri 24/09/2010 10.37.28 your computer crashed
Bugcheck code: 0x1000007E (0xC0000005, 0x8052BDA6, 0x9CEC199C, 0x9CEC1698)
Dump file: C:\WINDOWS\Minidump\Mini092410-02.dmp
On Fri 24/09/2010 10.15.44 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x1000008E (0xC0000005, 0x805A3461, 0x9FD61C44, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092410-01.dmp
file path: C:\WINDOWS\system32\ntoskrnl.exe
On Thu 23/09/2010 19.54.13 your computer crashed
Bugcheck code: 0x10000050 (0xCDCDD219, 0x0, 0xBF389FA8, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092310-07.dmp
On Thu 23/09/2010 19.52.29 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x8062E8FC, 0x9C55893C, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092310-06.dmp
On Thu 23/09/2010 19.51.33 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x8054BFD2, 0xB0F1E9F0, 0x0)
Dump file: C:\WINDOWS\Minidump\Mini092310-05.dmp
On Thu 23/09/2010 19.38.48 your computer crashed
Bugcheck code: 0x1000007E (0xC0000005, 0x8052BD8A, 0x9C1D0984, 0x9C1D0680)
Dump file: C:\WINDOWS\Minidump\Mini092310-04.dmp
On Thu 23/09/2010 19.35.56 your computer crashed
Bugcheck code: 0x10000050 (0xE7490004, 0x1, 0xBF85B740, 0x1)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092310-03.dmp
On Thu 23/09/2010 18.36.56 your computer crashed
Bugcheck code: 0x1000000A (0x8B912A70, 0x2, 0x1, 0x80519058)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092310-01.dmp
On Thu 23/09/2010 18.07.47 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x10000050 (0xA8CFAB70, 0x1, 0xB9DFA627, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini092310-02.dmp
file path: C:\WINDOWS\system32\drivers\ntfs.sys
product: Microsoft® Windows® Operating System
description: NT File System Driver
