tu macie opis sciagniety ze strony producenta
Processor
* Click here for maximum CPU support
Interface
* Slot 1
Chipset Type
* Intel 440BX
Chipset Description
* Intel 82440BX two chip AGPset
Form Factor
* ATX
Memory Description
* Three 168-pin SDRAM DIMM sockets support up to 768MB
* Provides ECC (Error Checking Correction) capability
Expansion Slots
* 4 x 32 bit Bus Mastering PCI slots (v2.1 compliant)
* 3 x 16 bit ISA slots (One PCI/ISA Shard slot)
* 1 AGP slot (v1.0 compliant) AGP 1x/2x
IDE Description
* Supports two independent channels for 4 IDE devices
* Supports up to PIO mode 4 and Ultra DMA 33
* 2 PCI bus mastering ATA E-IDE ports
IO Port Description
* ITE 8671/D chip
* 2 RS-232 Serial Ports (16550 UART compatible)
* 1 Parallel Printer Port (SPP/EPP/ECP mode)
* 1 FDD port (support LS120, 3 mode, 1.2/1.44/2.88 MB FDD)
* Provides IrDA port with optional cable for transceiver
IO Connection Description
* PS/2 Mini-DIN mouse &keyboard ports
* 2 USB ports
* 2 D-Sub 9-pin male Serial ports
* 1 D-Sub 25-pin female printer port
BIOS Description
* Award PCI BIOS with green ACPI, APM, PnP, DMI functions and Year 2000 compliant
* Supports multiple-boot from E-IDE/SCSI/CD-ROM/ FDD/LS120/ZIP
* 2 Mbit Flash ROM
Dimension Description
* 4 Layer PCB, 30.5cm x 19cm(12”x 7.5”)
* ATX form factor
Certification
* FCC CLASS B AND CE EMI REGULATION COMPLIANT
Compatibilities
Win2000 / WinNT / WinME / Win98SE / Win95 / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 90 day limited warranty on this SOYO product.
Tylko ze tu pisze na stronie ze plyta jest pod PII a mi normalnie chodzi na niej PIII 450 a w bioie mam ustawienia do 650Mhz.
