Otwórz notatnik >> wklej zawartość
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Directory]
@="Folder plików"
"AlwaysShowExt"=""
"EditFlags"=dword:000001d2
"InfoTip"="prop:DocComments"
"BrowserFlags"=dword:00000008
[HKEY_CLASSES_ROOT\Directory\DefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
j00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,\
65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,33,00,00,00
[HKEY_CLASSES_ROOT\Directory\shell]
@="none"
[HKEY_CLASSES_ROOT\Directory\shell\Wyszukaj]
"SuppressionPolicy"=dword:00000080
[HKEY_CLASSES_ROOT\Directory\shell\Wyszukaj\command]
00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,\
65,00,00,00
[HKEY_CLASSES_ROOT\Directory\shell\Wyszukaj\ddeexec]
@="[FindFolder(\"%l\", %I)]"
"NoActivateHandler"=""
[HKEY_CLASSES_ROOT\Directory\shell\Wyszukaj\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Directory\shell\Wyszukaj\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\Folder]
@="Folder"
"EditFlags"=dword:000003d2
"TileInfo"="prop:Size"
[HKEY_CLASSES_ROOT\Folder\DefaultIcon]
[HKEY_CLASSES_ROOT\Folder\shell]
@="Otwórz"
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj]
"BrowserFlags"=dword:00000022
"ExplorerFlags"=dword:00000021
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj\command]
65,00,20,00,2f,00,65,00,2c,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,\
00,25,00,49,00,2c,00,25,00,4c,00,00,00
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj\ddeexec]
@="[ExploreFolder(\"%l\", %I, %S)]"
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj\ddeexec\ifexec]
[HKEY_CLASSES_ROOT\Folder\shell\Eksploruj\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz]
"BrowserFlags"=dword:00000010
"ExplorerFlags"=dword:00000012
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz\command]
65,00,20,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,2c,\
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz\ddeexec]
@="[ViewFolder(\"%l\", %I, %S)]"
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz\ddeexec\ifexec]
[HKEY_CLASSES_ROOT\Folder\shell\Otwórz\ddeexec\topic]
@="AppProperties"
zapisz jako plik.reg >> wszystkie pliki >> scal z rejestrem >> restart
Następnie Opcje folderów >> typy plików >> sprawdź Folder i Folder plików
powinno być tak
W folderze ma być domyśna otwórz lub explore
w folderze plików nie ma być zaznaczonqa jako domyślna żadna z opcji
jeżeli miałbyś dalej problem z otwieraniem folderów zapodaj komendę
Start Uruchom regsvr32 /i shell32
