Ok, dzięki! Częściowo pomogła metoda 1 z poradnika
. Pozostała tylko 1 aktualizacja, która juz przy finalizowaniu kończy się niepowodzeniem - to jest internet explorer 7. Daję loga ie7:
[ie7.log]
0.703: ================================================================================
0.703: 2008/08/09 13:01:23.218 (local)
0.703: d:\63c1a0e048ab56a20d0e416e\update\update.exe (version 6.2.29.0)
0.719: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.719: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.719: IECUSTOM: Scanning for proper registry permissions…
1.062: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.062: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
1.062: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
1.062: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
1.297: IECUSTOM: Scanning for proper registry permissions…
1.484: IECUSTOM: Scanning for proper registry permissions…
1.703: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.750: IECUSTOM: Backing up registry permissions…
1.750: IECUSTOM: Finished backing up registry permissions…
1.750: IECUSTOM: Setting new registry permissions…
1.750: IECUSTOM: Unable to clear DACLs HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.750: IECUSTOM: Finished setting new registry permissions…
1.750: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.750: DoInstallation: CustomizeCall Failed: 0x3f5
1.750: IECUSTOM: Restoring registry permissions…
1.750: IECUSTOM: Finished restoring registry permissions…
1.750: Nie można zapisać klucza rejestru konfiguracji.
1.750: Instalacja produktu Internet Explorer 7 nie została ukończona.
1.750: Update.exe extended error code = 0x3f5
0.188: ================================================================================
0.203: 2008/08/09 13:11:40.359 (local)
0.203: d:\b789c24f093ea99d79a1576b5dfac537\update\update.exe (version 6.2.29.0)
0.235: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.235: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.235: IECUSTOM: Scanning for proper registry permissions…
0.578: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
0.578: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
0.578: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
0.578: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
0.797: IECUSTOM: Scanning for proper registry permissions…
0.969: IECUSTOM: Scanning for proper registry permissions…
1.203: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.250: IECUSTOM: Backing up registry permissions…
1.266: IECUSTOM: Finished backing up registry permissions…
1.266: IECUSTOM: Setting new registry permissions…
1.266: IECUSTOM: Unable to clear DACLs HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.266: IECUSTOM: Finished setting new registry permissions…
1.266: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.266: DoInstallation: CustomizeCall Failed: 0x3f5
1.266: IECUSTOM: Restoring registry permissions…
1.266: IECUSTOM: Finished restoring registry permissions…
1.266: Nie można zapisać klucza rejestru konfiguracji.
1.266: Instalacja produktu Internet Explorer 7 nie została ukończona.
1.266: Update.exe extended error code = 0x3f5
0.203: ================================================================================
0.219: 2008/08/09 13:26:11.765 (local)
0.219: d:\fa8e8a72110109e3330c78\update\update.exe (version 6.2.29.0)
0.234: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.234: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.234: IECUSTOM: Scanning for proper registry permissions…
0.812: IECUSTOM: Scanning for proper registry permissions…
0.984: IECUSTOM: Scanning for proper registry permissions…
1.219: IECUSTOM: Unwriteable key HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.265: IECUSTOM: Backing up registry permissions…
1.281: IECUSTOM: Finished backing up registry permissions…
1.281: IECUSTOM: Setting new registry permissions…
1.281: IECUSTOM: Unable to clear DACLs HKCR\Interface{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.281: IECUSTOM: Finished setting new registry permissions…
1.281: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.281: DoInstallation: CustomizeCall Failed: 0x3f5
1.281: IECUSTOM: Restoring registry permissions…
1.281: IECUSTOM: Finished restoring registry permissions…
1.281: Nie można zapisać klucza rejestru konfiguracji.
1.281: Instalacja produktu Internet Explorer 7 nie została ukończona.
1.281: Update.exe extended error code = 0x3f5
Jak rozwiązać ten problem? Może ktoś wieco oznczaja te logi i co z nich wynika? Byłbym wdzięczny
