Mam problem z instalacją Libnet 1.0.2a
Logi:
root@ubuntu:/home/lucas/Pulpit/Libnet-1.0.2a# ./configure
loading cache ./config.cache
Beginning autoconfiguration process for libnet-1.0.2a...
checking host system type... Invalid configuration `x86_64-pc-linux-gnu': machine `x86_64-pc' not recognized
checking target system type... Invalid configuration `x86_64-pc-linux-gnu': machine `x86_64-pc' not recognized
checking build system type... Invalid configuration `x86_64-pc-linux-gnu': machine `x86_64-pc' not recognized
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for working const... (cached) yes
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether make sets ${MAKE}... (cached) yes
checking for ranlib... (cached) ranlib
checking for ar... (cached) ar
checking for ln... (cached) ln
checking for strerror... (cached) yes
checking for pcap_open_live in -lpcap... (cached) no
checking low-level packet interface type... found SOCK_PACKET
configure: warning: apparently your OS is not officially supported yet
configure: warning: this may not work
you'll have to edit the makefile by hand
please send diffs to mike@infonexus.com
checking for libnet_build_ip in -lnet... (cached) no
checking machine endianess... lil
checking if unaligned accesses fail... (cached) no
checking for sys/sockio.h... (cached) no
creating ./config.status
creating Makefile
creating test/Makefile
creating test/TCP/Makefile
creating test/Ethernet/Makefile
creating test/UDP/Makefile
creating test/ICMP/Makefile
creating test/Random/Makefile
creating test/OSPF/Makefile
creating util/Makefile
creating util/Get-mac/Makefile
creating example/Makefile
creating libnet-config
creating include/config.h
include/config.h is unchanged
root@ubuntu:/home/lucas/Pulpit/Libnet-1.0.2a# make
ar -cr lib/libnet.a src/libnet_resolve.o src/libnet_socket.o src/libnet_checksum.o src/libnet_prand.o src/libnet_version.o src/libnet_write_ip.o src/libnet_insert_ipo.o src/libnet_insert_tcpo.o src/libnet_error.o src/libnet_link_sockpacket.o src/libnet_packet_mem.o src/libnet_build_ip.o src/libnet_build_tcp.o src/libnet_build_udp.o src/libnet_build_arp.o src/libnet_build_ethernet.o src/libnet_build_icmp.o src/libnet_build_igmp.o src/libnet_build_dns.o src/libnet_build_snmp.o src/libnet_build_rip.o src/libnet_build_ospf.o src/libnet_build_vrrp.o src/libnet_asn1.o src/libnet_hex_dump.o src/libnet_if_addr.o src/libnet_port_list.o
ranlib lib/libnet.a
root@ubuntu:/home/lucas/Pulpit/Libnet-1.0.2a# sudo make install
ranlib lib/libnet.a
./ensure-dir.sh /usr 755
./ensure-dir.sh /usr/lib/ 755
./ensure-dir.sh /usr/include/libnet 755
./ensure-dir.sh /usr/include/ 755
./ensure-dir.sh 755
./ensure-dir.sh /usr/bin/ 755
./install-sh lib/libnet.a /usr/lib/
rm -f /usr/lib/libpwrite.a
cd /usr/lib/; ln -f -s libnet.a libpwrite.a
./install-sh include/libnet.h /usr/include/
./install-sh include/libnet/libnet-headers.h /usr/include/libnet
./install-sh include/libnet/libnet-functions.h /usr/include/libnet
./install-sh include/libnet/libnet-structures.h /usr/include/libnet
./install-sh include/libnet/libnet-macros.h /usr/include/libnet
./install-sh include/libnet/libnet-asn1.h /usr/include/libnet
./install-sh include/libnet/libnet-ospf.h /usr/include/libnet
./install-sh doc/libnet.3
install: no destination specified
make: *** [install] Błąd 1
Co może być nie tak?
