Chce zainstalować superkarambe i niewiem czy to dobrze robie
[root@localhost superkaramba-0.39]# ./configure
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking target system type… i686-pc-linux-gnu
checking for a BSD-compatible install… /usr/bin/install -c
checking for -p flag to install… yes
checking whether build environment is sane… yes
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
checking for kde-config… /usr/bin/kde-config
checking where to install… /usr (as returned by kde-config)
checking for style of include used by make… GNU
checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ANSI C… none needed
checking dependency style of gcc… gcc3
checking how to run the C preprocessor… gcc -E
checking for g++… no
checking for c++… no
checking for gpp… no
checking for aCC… no
checking for CC… no
checking for cxx… no
checking for cc++… no
checking for cl… no
checking for FCC… no
checking for KCC… no
checking for RCC… no
checking for xlC_r… no
checking for xlC… no
checking whether we are using the GNU C++ compiler… no
checking whether g++ accepts -g… no
checking dependency style of g++… none
checking whether gcc is blacklisted… no
checking whether g++ supports -Wmissing-format-attribute… no
checking whether gcc supports -Wmissing-format-attribute… yes
checking whether g++ supports -Wundef… no
checking whether g++ supports -Wno-long-long… no
checking whether g++ supports -Wno-non-virtual-dtor… no
checking how to run the C++ preprocessor… /lib/cpp
configure: error: C++ preprocessor “/lib/cpp” fails sanity check
See `config.log’ for more details.
[root@localhost superkaramba-0.39]# make
make: *** Nie podano obiektów i nie znaleziono makefile. Stop.
[root@localhost superkaramba-0.39]# make install
make: *** Brak reguł do wykonania obiektu `install’. Stop.
prosze o pomoc
wszystko działa:) , dzieki za pomoc:)
