Witam
Niestety problemow ciag dalszy. Zainstalowalem Windowsa XP z wylaczonym SATA i niestety ale nie moge teraz zainstalowac prawie zadnego programu zawsze wyskakuja jakies bledy. Zainstalowalem nowego Biosa i nic dalej te same bledy glownie z karta graficzna. Czy moze to byc problem plyty glownej??
Prosze o pomoc.
O to specyfikacja mojego notebooka:
Product Name dv8339us
US Product Number EZ700UA#ABA
Microprocessor 1.73 GHz Intel® Centrino® Duo mobile technology featuring Intel® Core™ Duo processor T2250
Microprocessor Cache 2MB L2 Cache
Memory 1024MB 667MHz DDR2 System Memory (2 Dimm)
Memory Max 2048MB
Video Graphics NVIDIA GeForce Go 7400
Video Memory 128MB discrete + 128MB shared
Hard Drive 200GB 5400RPM Dual HDD (100GB x 2)
Multimedia Drive LightScribe Super Multi 8X DVD±R/RW with Double Layer Support
Display 17.0” WXGA+ High-Definition BrightView Widescreen Display (1440 x 900)
Fax/Modem High speed 56k modem
Network Card Integrated 10/100BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity Intel® PRO/Wireless 3945ABG Network Connection
Sound Altec Lansing
Keyboard Notebook keyboard with scroll bar and integrated numeric keypad
2 Quick Launch Buttons (HP Quick Play Music and DVD buttons)
Calculator Launch Button
Pointing Device Touch Pad with dedicated vertical Scroll Up/Down pad
PC Card Slots 1 ExpressCard/54 Slot (also supports ExpressCard/34)
1 Type I/II 32-bit card bus (also support 16-bit)
External Ports 6-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Sticks, Memory Stick Pro, SmartMedia or xD Picture cards
4 Universal Serial Bus (USB) 2.0
1 Headphone out w/SPDIF Digital Audio
1 microphone-in
1 VGA (15-pin)
1 TV-Out (S-video)
1 RJ-11 (modem)
1 RJ -45 (LAN)
1 Expansion Port 2, 1 IEEE 1394 Firewire (4-pin)
1 Consumer IR (Remote Receiver)
Dimensions 11.1"(L) x 15.62"(W) x 1.48"(min H)/1.82"(max H)
Weight 8.1 lbs
Security Kensington® MicroSaver lock slot
Power-on password
Accepts 3rd party security lock devices
Power 90W AC adapter
8-Cell Lithium-Ion
