Witam . Podczas uruchomienia windowsa 7 gdy wszystko sie uruchomi wyskakuje mi taki komunikat C /users/darek/appdata/local/temp/sshnas21.dll próbowałem to usunąć dzięki OTL tak jak czytałem na forum ale nie pomoglo wyskakuje takie coś All processes killed
========== OTL ==========
Prefs.js: “http://search.conduit.com/ResultsExt.aspx?ctid=CT1408409&SearchSource=3&q={searchTerms}” removed from browser.search.defaulturl
Prefs.js: “http://search.conduit.com/ResultsExt.aspx?ctid=CT1408409&q=” removed from keyword.URL
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\LosAlamos not found.
File C:\Windows\SysWow64\sshnas21.DLL not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\TOY5KNQ8OC not found.
========== FILES ==========
File\Folder C:\Windows\msa.exe not found.
File\Folder C:\Windows\MEMORY.DMP not found.
File\Folder C:\Windows\SysWow64\sshnas21.DLL not found.
File\Folder C:\Windows\tasks{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job not found.
File\Folder C:\Windows\tasks{66BA574B-1E11-49b8-909C-8CC9E0E8E015}.job not found.
File\Folder C:\Users\Łukasz\AppData\Roaming\Mozilla\FireFox\Profiles\zxs1bje4.default\searchplugins\conduit.xml not found.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: AppData
User: Darek
->Temp folder emptied: 188614 bytes
->Temporary Internet Files folder emptied: 81739 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 16811823 bytes
->Google Chrome cache emptied: 0 bytes
->Flash cache emptied: 405 bytes
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
->Flash cache emptied: 0 bytes
User: Default User
User: Public
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 0 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 16.00 mb
OTL by OldTimer - Version 3.2.1.2 log created on 04182010_130955
Files\Folders moved on Reboot…
C:\Users\Darek\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
File move failed. C:\Windows\temp_avast5_\Webshlock.txt scheduled to be moved on reboot.
Registry entries deleted on Reboot…
Czy może mi ktoś pomóc z tym się uporać i czy może przez taki bład w kompie moge nie mieć internetu
