Spoko już daję
,ENU_COM.JS
* (c) Ger Versluis 2000 version 3.0, 25 november 2000 *
* You may use this script on non commercial sites if you make a public link to http://home.planet.nl/~bustamil *
* For info write to menus@burmees.nl *
* Version 2.0 Added further error checking. Some minor bug fixes. *
* Version 2.5 Improved Error checking. Added Border between elements 1/0 *
* Version 3.0 added support for DOM
* This script featured on Dynamic Drive (http://www.dynamicdrive.com), the DHTML code library
var AgntUsr=navigator.userAgent.toLowerCase();
var DomYes=(document.getElementById)?1:0; // DOM
var NavYes=(AgntUsr.indexOf('mozilla')!=-1&&AgntUsr.indexOf('compatible')==-1)?1:0; // Netscape
var ExpYes=(AgntUsr.indexOf('msie')!=-1)?1:0; // IExplorer
var Opr5=(AgntUsr.indexOf('opera 5')!=-1||AgntUsr.indexOf('opera/5')!=-1)?1:0; // Opera 5
var DomNav=(DomYes&&NavYes)?1:0; // Netscape 6 up
var DomExp=(DomYes&&ExpYes)?1:0; // IExplorer 5 up
var Nav4=(NavYes&&!DomYes&&document.layers)?1:0; // Netscape 4
var Exp4=(ExpYes&&!DomYes&&document.all)?1:0; // IExplorer 4
var PosStrt=((NavYes||ExpYes)&&!Opr5)?1:0; // Can start
if(AgntUsr.indexOf('mac')!=-1&&DomExp){DomExp=0;Exp4=1}
var FirstLocation,SecLocation,DocLocation;
var SecWindowWidth,FirstWindowWidth,FirstWindowHeight;
var SecLoadAgainWin;
var FirstColPos,SecColPos,DocColPos;
var InitRecursLevel=0,CreateRecursLevel=0,PosRecursLevel=0;
var ShowFlag=0,FirstCreate=1,Loaded=0,Created=0,InitFlag,AcrossFrames=1;
var FirstContainer=null,CurrentOver=null,CloseTimer=null;
var CenterText,TxtClose,ImgStr;
var Ztop=100;
var M_StartTop=StartTop,M_StartLeft=StartLeft;
var LeftExtra=(DomNav)?LeftPaddng:0;
var TopExtra=(DomNav)?TopPaddng:0;
var M_Hide=(Nav4)?'hide':'hidden';
var M_Show=(Nav4)?'show':'visible';
var Par=(parent.frames[0])?parent:window;
var Doc=Par.document;
var Bod=Doc.body;
var Trigger=(NavYes||Opr5)?Par:Bod;
WebMasterAlerts=["No such frame: ","Item not defined: ","Item needs height: ","Item needs width: ","Warning-Item doesn't need height: ","Warning-Item doesn't need width: ","Item Oke ","Menu tree oke"];
if(DomNav&&!Opr5)Trigger.addEventListener('load',Go,false);
else Trigger.onload=Go;
Trigger.onresize=(Nav4)?ReDoWhole:RePos;
function cancelselect(){return false}
function RePos(){
FirstWindowWidth=(ExpYes)?FirstLocation.document.body.clientWidth:FirstLocation.innerWidth;
FirstWindowHeight=(ExpYes)?FirstLocation.document.body.clientHeight:FirstLocation.innerHeight;
SecWindowWidth=(ExpYes)?SecLocation.document.body.clientWidth:SecLocation.innerWidth;
SecWindowHeight=(ExpYes)?SecLocation.document.body.clientHeight:SecLocation.innerHeight;
if(MenuCentered)CalcLeft();
if(MenuVerticalCentered)CalcTop();
PositionMenuStruct(FirstContainer,StartTop,StartLeft)}
function UnLoaded(){
if(CloseTimer)clearTimeout(CloseTimer);Loaded=0; Created=0;
var FCStyle=(Nav4)?FirstContainer:FirstContainer.style;
FCStyle.visibility=M_Hide}
function ReDoWhole(){
Doc.location.reload()}
function Check(WhichMenu,NoOf){
var i,Hg,Wd,La,Li,Nof,array,ArrayLoc=parent.frames[FirstLineFrame];
for(i=0;i
array=WhichMenu+eval(i+1);
if(!ArrayLoc[array]){WebMasterAlert(1,array); return false}
La=ArrayLoc[array][0]; Li=ArrayLoc[array][1]; Nof=ArrayLoc[array][2];
if(i==0){ if(!ArrayLoc[array][3]){WebMasterAlert(2,array); return false}
if(!ArrayLoc[array][4]){WebMasterAlert(3,array); return false}
Hg=ArrayLoc[array][3]; Wd=ArrayLoc[array][4]}
else{ if(ArrayLoc[array][3])WebMasterAlert(4,array);
if(ArrayLoc[array][4])WebMasterAlert(5,array)}
if(!WebMasterAlert(6,'\n\n'+array+'\nwidth: '+Wd+'\nheight: '+Hg+'\nLabel: '+La+'\nLink: '+Li+'\nNo of sub items: '+Nof)){WebMasterCheck=0; return true}
if(ArrayLoc[array][2])if(!Check(array+'_',ArrayLoc[array][2])) return false}
return true}
function WebMasterAlert(No,Xtra){
if(WebMasterCheck)return confirm(WebMasterAlerts[No]+Xtra+' ')}
function Go(){
if(Loaded||!PosStrt)return;
Created=0; Loaded=1;
status='Building menu';
if(FirstCreate){
if(!parent.frames[FirstLineFrame]){WebMasterAlert(0,FirstLineFrame); FirstLineFrame=SecLineFrame}
if(!parent.frames[FirstLineFrame]){WebMasterAlert(0,SecLineFrame); FirstLineFrame=SecLineFrame=DocTargetFrame}
if(!parent.frames[FirstLineFrame]){WebMasterAlert(0,DocTargetFrame); FirstLineFrame=SecLineFrame=DocTargetFrame=(parent.frames[0])?parent.frames[0].name:''}
if(!parent.frames[SecLineFrame]){WebMasterAlert(0,SecLineFrame);SecLineFrame=DocTargetFrame}
if(!parent.frames[SecLineFrame]){WebMasterAlert(0,DocTargetFrame);SecLineFrame=DocTargetFrame=FirstLineFrame}
if(!parent.frames[DocTargetFrame]){WebMasterAlert(0,DocTargetFrame);DocTargetFrame=SecLineFrame}
if(WebMasterCheck){if(!Check('Menu',NoOffFirstLineMenus))return;else WebMasterAlert(7,'')}
FirstLocation=(FirstLineFrame)?parent.frames[FirstLineFrame]:window;
SecLocation=(SecLineFrame)?parent.frames[SecLineFrame]:window;
DocLocation=(DocTargetFrame)?parent.frames[DocTargetFrame]:window;
if (FirstLocation==SecLocation) AcrossFrames=0;
if (AcrossFrames)FirstLineHorizontal=(MenuFramesVertical)?0:1;
if(MenuCentered) CalcLeft();
if(MenuVerticalCentered) CalcTop();
if(!DomYes){CenterText=(MenuTextCentered)?(NavYes)?"
“:“align=‘center’”:”"; if(NavYes)TxtClose=""+(MenuTextCentered)?"
“:”"}} FirstColPos=(Nav4)?FirstLocation.document:FirstLocation.document.body; SecColPos=(Nav4)?SecLocation.document:SecLocation.document.body; DocColPos=(Nav4)?DocLocation.document:SecLocation.document.body; if (TakeOverBgColor)FirstColPos.bgColor=(AcrossFrames)?SecColPos.bgColor:DocColPos.bgColor; if(FirstCreate){FirstContainer=CreateMenuStructure(‘Menu’,NoOffFirstLineMenus);FirstCreate=0} else CreateMenuStructureAgain(‘Menu’,NoOffFirstLineMenus); PositionMenuStruct(FirstContainer,StartTop,StartLeft); InitFlag=1; Initiate(); InitFlag=0; Created=1; SecLoadAgainWin=(ExpYes)?SecLocation.document.body:SecLocation; SecLoadAgainWin.onunload=UnLoaded; //if(ExpYes){SecLocation.document.body.onselectstart=cancelselect;FirstLocation.document.body.onselectstart=cancelselect} status=‘Menu ready for use’} function CalcLeft(){ var Size=FirstWindowWidth; if(MenuCentered!=‘left’){ StartLeft=M_StartLeft; Size-=(FirstLineHorizontal)?(NoOffFirstLineMenus*(eval(‘Menu1[4]’)+BorderWidth)+BorderWidth):(eval(‘Menu1[4]’)+BorderWidth); if(MenuCentered==‘right’)StartLeft+=Size; else StartLeft+=Size/2}} function CalcTop(){ var Size=FirstWindowHeight; if(MenuVerticalCentered!=‘top’){ StartTop=M_StartTop; Size-=(FirstLineHorizontal)?(eval(‘Menu1[3]’)+BorderWidth):(NoOffFirstLineMenus*(eval(‘Menu1[3]’)+BorderWidth)+BorderWidth); if(MenuVerticalCentered==‘bottom’)StartTop+=Size; else StartTop+=Size/2}} function PositionMenuStruct(CntnrPntr,Tp,Lt){ var Topi,Lefti,Hori; var Cntnr=CntnrPntr; var Mmbr=Cntnr.FirstMember; var CntnrStyle=(!Nav4)?Cntnr.style:Cntnr; var MmbrStyle=(!Nav4)?Mmbr.style:Mmbr; var PadLeft=(Mmbr.value.indexOf(’<’)==-1)?LeftExtra:0; var PadTop=(Mmbr.value.indexOf(’<’)==-1)?TopExtra:0; var MmbrWidth=(!Nav4)?parseInt(MmbrStyle.width)+PadLeft:MmbrStyle.clip.width; var MmbrHeight=(!Nav4)?parseInt(MmbrStyle.height)+PadTop:MmbrStyle.clip.height; var CntnrWidth=(!Nav4)?parseInt(CntnrStyle.width):CntnrStyle.clip.width; var CntnrHeight=(!Nav4)?parseInt(CntnrStyle.height):CntnrStyle.clip.height; var SubTp,SubLt; PosRecursLevel++; if (PosRecursLevel==1 && AcrossFrames)(!MenuFramesVertical)?Tp=FirstWindowHeight-CntnrHeight+((Nav4)?4:0):Lt=FirstWindowWidth-CntnrWidth; if (PosRecursLevel==2 && AcrossFrames)(!MenuFramesVertical)?Tp=0:Lt=0; if (PosRecursLevel==2 && AcrossFrames){Tp+=VerCorrect;Lt+=HorCorrect} CntnrStyle.top=Cntnr.OrgTop=Tp; CntnrStyle.left=Cntnr.OrgLeft=Lt; if (PosRecursLevel==1 && FirstLineHorizontal){Hori=1; Lefti=CntnrWidth-MmbrWidth-2*BorderWidth;Topi=0} else{Hori=Lefti=0; Topi=CntnrHeight-MmbrHeight-2*BorderWidth} while(Mmbr!=null){ PadLeft=(Mmbr.value.indexOf(’<’)==-1)?LeftExtra:0; PadTop=(Mmbr.value.indexOf(’<’)==-1)?TopExtra:0; MmbrStyle=(!Nav4)?Mmbr.style:Mmbr; MmbrWidth=(!Nav4)?parseInt(MmbrStyle.width)+PadLeft:MmbrStyle.clip.width; MmbrHeight=(!Nav4)?parseInt(MmbrStyle.height)+PadTop:MmbrStyle.clip.height; MmbrStyle=(!Nav4)?Mmbr.style:Mmbr; MmbrStyle.left=Lefti+BorderWidth; MmbrStyle.top=Topi+BorderWidth; if(Nav4)Mmbr.CmdLyr.moveTo(Lefti+BorderWidth,Topi+BorderWidth); if(Mmbr.ChildCntnr){ if(Hori){ SubTp=Tp+Topi+MmbrHeight+BorderWidth; SubLt=Lt+Lefti} else{ SubLt=Lt+Lefti+(1-ChildOverlap)*MmbrWidth+BorderWidth; SubTp=Tp+Topi+ChildVerticalOverlap*MmbrHeight} PositionMenuStruct(Mmbr.ChildCntnr,SubTp,SubLt)} (Hori)?Lefti-=(BorderBtwnElmnts)?(MmbrWidth+BorderWidth):(MmbrWidth):Topi-=(BorderBtwnElmnts)?(MmbrHeight+BorderWidth):(MmbrHeight); Mmbr=Mmbr.PrevMember} PosRecursLevel–} function Initiate(){ if(InitFlag) Init(FirstContainer)} function Init(CntnrPntr){ var MemberContainer=CntnrPntr; var Member=MemberContainer.FirstMember; var MCStyle=(Nav4)?MemberContainer:MemberContainer.style; InitRecursLevel++; MCStyle.visibility=(InitRecursLevel==1)?M_Show:M_Hide; while(Member!=null){ if(Member.ChildCntnr) Init(Member.ChildCntnr); Member=Member.PrevMember} InitRecursLevel–} function ClearAllChilds(Pntr,ChldPntr){ var CPCCStyle; while (Pntr){ if(Pntr.ChildCntnr){ CPCCStyle=(Nav4)?Pntr.ChildCntnr:Pntr.ChildCntnr.style; if(Pntr.ChildCntnr!=ChldPntr)CPCCStyle.visibility=M_Hide; ClearAllChilds(Pntr.ChildCntnr.FirstMember,ChldPntr)} Pntr=Pntr.PrevMember}} function GoTo(){ if(this.LinkTxt){ status=’’; if(Nav4){ if(this.LowLyr.value.indexOf(’ this.LowLyr.bgColor=this.LowLyr.LowBack; this.LowLyr.document.write(this.LowLyr.value); this.LowLyr.document.close()}} else{ this.style.backgroundColor=this.LowBack; this.style.color=this.LowFontColor} (this.LinkTxt.indexOf(‘javascript:’)!=-1)?eval(this.LinkTxt):DocLocation.location.href=this.LinkTxt}} function OpenMenu(){ if(!Loaded||!Created) return; var TopScrolled=(AcrossFrames)?(ExpYes)?SecLocation.document.body.scrollTop:SecLocation.pageYOffset:0; var LeftScrolled=(AcrossFrames)?(ExpYes)?SecLocation.document.body.scrollLeft:SecLocation.pageXOffset:0; var ChildCont=(Nav4)?this.LowLyr.ChildCntnr:this.ChildCntnr; var ThisHeight=(Nav4)?this.clip.height:parseInt(this.style.height); var ThisWidth=(Nav4)?this.clip.width:parseInt(this.style.width); CurrentOver=this; InitFlag=0; if(ShowFlag){ ClearAllChilds(this.Container.FirstMember,ChildCont); if(this.Level==1) ShowFlag=0} if(Nav4){ if(this.LowLyr.value.indexOf(’ this.LowLyr.bgColor=this.LowLyr.HighBack; this.LowLyr.document.write(this.LowLyr.Overvalue); this.LowLyr.document.close()}} else{ this.style.backgroundColor=this.HighBack; this.style.color=this.HighFontColor} if(ChildCont!=null) { var ChildContWidth=(Nav4)?this.LowLyr.ChildCntnr.clip.width:parseInt(this.ChildCntnr.style.width); var ChildContHeight=(Nav4)?this.LowLyr.ChildCntnr.clip.height:parseInt(this.ChildCntnr.style.height); var ChCntTL=(Nav4)?this.LowLyr.ChildCntnr:this.ChildCntnr.style; var SubLt=ChildCont.OrgLeft+LeftScrolled; var SubTp=ChildCont.OrgTop+TopScrolled; while(SubLt+ChildContWidth>SecWindowWidth+LeftScrolled){ if(this.Level==1)SubLt=SecWindowWidth+LeftScrolled-ChildContWidth; else SubLt-=ChildContWidth} while(SubTp+ChildContHeight>TopScrolled+SecWindowHeight){ if(this.Level==1)SubTp=TopScrolled+SecWindowHeight-ChildContHeight; SubTp-=ChildContHeight} ChCntTL.top=SubTp; ChCntTL.left=SubLt; ChCntTL.visibility=M_Show; ShowFlag=1} status=this.LinkTxt} function CloseMenu(){ if(!Loaded||!Created) return; if(Nav4){if(this.LowLyr.value.indexOf(’ this.LowLyr.bgColor=this.LowLyr.LowBack; this.LowLyr.document.write(this.LowLyr.value); this.LowLyr.document.close()}} else{ this.style.backgroundColor=this.LowBack; this.style.color=this.LowFontColor} status=’’; if(this==CurrentOver){ InitFlag=1; if (CloseTimer) clearTimeout(CloseTimer); CloseTimer=setTimeout(‘Initiate(CurrentOver)’,DissapearDelay)}} function ContainerSetUp(Wdth,Hght,NoOff){ this.FirstMember=null; this.OrgLeft=0; this.OrgTop=0; if (CreateRecursLevel==1&&FirstLineHorizontal){ Wdth=(BorderBtwnElmnts)?NoOff*(Wdth+BorderWidth)+BorderWidth:NoOff*Wdth+2*BorderWidth; Hght+=2*BorderWidth} else{ Hght=(BorderBtwnElmnts)?NoOff*(Hght+BorderWidth)+BorderWidth:NoOff*Hght+2*BorderWidth; Wdth+=2*BorderWidth} if(Nav4){ this.visibility=‘hide’; this.bgColor=BorderColor; this.resizeTo(Wdth,Hght)} else{ this.Level=CreateRecursLevel; this.style.backgroundColor=BorderColor; this.style.width=Wdth; this.style.height=Hght; this.style.fontFamily=FontFamily; this.style.fontWeight=(FontBold)?‘bold’:‘normal’; this.style.fontStyle=(FontItalic)?‘italic’:‘normal’; this.style.fontSize=FontSize+‘pt’; this.style.zIndex=CreateRecursLevel+Ztop}} function MemberSetUp(MmbrCntnr,PrMmbr,WhatMenu,Wdth,Hght){ var Location=(CreateRecursLevel==1)?FirstLocation:SecLocation; var MemVal=eval(WhatMenu+’[0]’); var t,T,L,W,H,S; this.value=MemVal; this.ChildCntnr=null; this.PrevMember=PrMmbr; this.Level=CreateRecursLevel; this.LinkTxt=eval(WhatMenu+’[1]’); this.Container=MmbrCntnr; this.style.cursor=‘default’; if(MemVal.indexOf(’<’)==-1){this.style.width=Wdth-LeftExtra; this.style.height=Hght-TopExtra; this.style.paddingLeft=LeftPaddng; this.style.paddingTop=TopPaddng} else{this.style.width=Wdth; this.style.height=Hght} this.style.overflow=‘hidden’ this.LowBack=LowBgColor; this.LowFontColor=FontLowColor; this.HighBack=(MemVal.indexOf(’ this.HighFontColor=(MemVal.indexOf(’ this.style.color=this.LowFontColor; this.style.backgroundColor=this.LowBack; if(MenuTextCentered)this.style.textAlign=‘center’; if(MemVal.indexOf(’<’)==-1&&DomYes){t=Location.document.createTextNode(MemVal);this.appendChild(t)} else this.innerHTML=MemVal; if(MemVal.indexOf(’ S=(CreateRecursLevel==1&&FirstLineHorizontal)?‘tridown.gif’:‘tri.gif’; W=(CreateRecursLevel==1&&FirstLineHorizontal)?10:5; H=(CreateRecursLevel==1&&FirstLineHorizontal)?5:10; T=(CreateRecursLevel==1&&FirstLineHorizontal)?Hght-7:Hght/2-5; L=(CreateRecursLevel==1&&FirstLineHorizontal)?Wdth-12:Wdth-7; if(DomYes){t=Location.document.createElement(‘img’); this.appendChild(t); t.style.position=‘absolute’; t.src=S; t.style.width=W; t.style.height=H; t.style.top=T; t.style.left=L} else{MemVal+="
“; this.innerHTML=MemVal}} if(ExpYes){this.onmouseover=OpenMenu; this.onmouseout=CloseMenu; this.onclick=GoTo} else{this.addEventListener(‘mouseover’,OpenMenu,false); this.addEventListener(‘mouseout’,CloseMenu,false); this.addEventListener(‘click’,GoTo,false)}} function NavMemberSetUp(MmbrCntnr,PrMmbr,WhatMenu,Wdth,Hght){ this.value=eval(WhatMenu+’[0]’); if(LeftPaddngthis.value.indexOf(’’)==-1!MenuTextCentered)this.value=’ ;’+this.value; if(FontBold)this.value=this.value.bold(); if(FontItalic)this.value=this.value.italics(); this.Overvalue=this.value; this.value=this.value.fontcolor(FontLowColor); this.Overvalue=this.Overvalue.fontcolor(FontHighColor); this.value=CenterText+”"+this.value+TxtClose;
this.Overvalue=CenterText+""+this.Overvalue+TxtClose;
this.HighBack=HighBgColor;
this.visibility=‘inherit’;
this.bgColor=LowBgColor;
this.resizeTo(Wdth,Hght);
this.document.write(this.value);
this.document.close();
this.CmdLyr=new Layer(Wdth,MmbrCntnr);
this.CmdLyr.visibility=‘inherit’;
this.CmdLyr.Level=CreateRecursLevel;
this.CmdLyr.LinkTxt=eval(WhatMenu+’[1]’);
this.CmdLyr.onmouseover=OpenMenu;
this.CmdLyr.onmouseout=CloseMenu;
this.CmdLyr.captureEvents(Event.MOUSEUP);
this.CmdLyr.onmouseup=GoTo;
this.CmdLyr.LowLyr=this;
this.CmdLyr.Container=MmbrCntnr;
this.CmdLyr.resizeTo(Wdth,Hght);
if(this.value.indexOf(’
this.CmdLyr.ImgLyr=new Layer(10,this.CmdLyr);
this.CmdLyr.ImgLyr.visibility=‘inherit’;
this.CmdLyr.ImgLyr.top=(CreateRecursLevel==1FirstLineHorizontal)?Hght-7:Hght/2-5;
this.CmdLyr.ImgLyr.left=(CreateRecursLevel==1FirstLineHorizontal)?Wdth-12:Wdth-7;
this.CmdLyr.ImgLyr.width=(CreateRecursLevel==1FirstLineHorizontal)?10:5;
this.CmdLyr.ImgLyr.height=(CreateRecursLevel==1FirstLineHorizontal)?5:10;
ImgStr=(CreateRecursLevel==1FirstLineHorizontal)?"
/div");
var MemberContainer=Location.document.all[WhichMenu]}
MemberContainer.SetUp=ContainerSetUp;
MemberContainer.SetUp(MenuWidth,MenuHeight,NumberOf);
if(Exp4){ MemberContainer.InnerString=’’;
for(i=1;i
WhichMenu=MenuName+eval(i);
NoOffSubs=eval(WhichMenu+’[2]’);
MemberContainer.InnerString+="
/div"}
MemberContainer.innerHTML=MemberContainer.InnerString}
for(i=1;i
if(DomYes){
Member=Location.document.createElement(“div”);
Member.style.position=‘absolute’;
Member.style.visibility=‘inherit’;
MemberContainer.appendChild(Member);
Member.SetUp=MemberSetUp}
else if(Nav4){Member=new Layer(MenuWidth,MemberContainer);
Member.SetUp=NavMemberSetUp}
else{ Member=Location.document.all[WhichMenu];
Member.SetUp(MemberContainer,PreviousMember,WhichMenu,MenuWidth,MenuHeight);
if(NoOffSubs) Member.ChildCntnr=CreateMenuStructure(WhichMenu+’_’,NoOffSubs);
PreviousMember=Member}
MemberContainer.FirstMember=Member;
CreateRecursLevel–;
return(MemberContainer)}
function CreateMenuStructureAgain(MenuName,NumberOf){
var i,WhichMenu,NoOffSubs;
var PreviousMember,Member=FirstContainer.FirstMember;
CreateRecursLevel++;
for(i=NumberOf;i0;i–){
PreviousMember=Member;
if(NoOffSubs)Member.ChildCntnr=CreateMenuStructure(WhichMenu+’_’,NoOffSubs);
CreateRecursLevel–}
MENU_VAR.JS
//(c) Ger Versluis 2000 version 1.0, 1 november 2000
var NoOffFirstLineMenus=5; //set number of main menu items
var LowBgColor=’#F2F2F2’;
var HighBgColor=’#D1D1E9’;
var FontLowColor=‘black’;
var FontHighColor=‘black’;
var BorderColor=‘black’;
var BorderWidth=1;
var BorderBtwnElmnts=1;
var FontFamily=“comic sans ms,technical,arial”
var FontSize=9;
var FontBold=1;
var FontItalic=0;
var MenuTextCentered=0;
var MenuCentered=‘left’;
var MenuVerticalCentered=‘top’;
var ChildOverlap=.1;
var ChildVerticalOverlap=.1;
var StartTop=0; //set vertical offset
var StartLeft=0; //set horizontal offset
var VerCorrect=0;
var HorCorrect=0;
var LeftPaddng=3;
var TopPaddng=2;
var FirstLineHorizontal=1; //set menu layout (1=horizontal, 0=vertical)
var MenuFramesVertical=1;
var DissapearDelay=500;
var TakeOverBgColor=1;
var FirstLineFrame=‘navig’;
var SecLineFrame=‘space’;
var DocTargetFrame=‘space’;
var WebMasterCheck=0;
//Menux=new Array(“text to show”,“Link”,No of sub elements,element height,element width);
//see accompanying “config.htm” file for more information on structure of menus
Menu1=new Array(“Home”,“http://www.dynamicdrive.com”,0,20,138);
Menu2=new Array(“News”,“blank.htm”,2);
Menu2_1=new Array(“General”,“blank.htm”,5,20,150);
Menu2_1_1=new Array(“CNN”,“http://www.cnn.com”,0,20,150);
Menu2_1_2=new Array(“ABCNews”,“http://www.abcnews.com”,0);
Menu2_1_3=new Array(“MSNBC”,“http://www.msnbc.com”,0);
Menu2_1_4=new Array("CBSNews","http://www.cbsnews.com",0);
Menu2_1_5=new Array("Canadian News","http://news.bbc.co.uk",2);
Menu2_1_5_1=new Array("Vancouver Sun","http://www.vancouversun.com",0,20,150);
Menu2_1_5_2=new Array("CTV News","http://www.ctvnews.com",0);
Menu2_2=new Array(“Technology”,“blank.htm”,3);
Menu2_2_1=new Array(“TechWeb”,“http://www.techweb.com”,0,20,200);
Menu2_2_2=new Array(“News.com”,“http://www.news.com”,0);
Menu2_2_3=new Array(“Wired News”,“http://www.wired.com”,0);
Menu3=new Array(“Search Engines”,“blank.htm”,3);
Menu3_1=new Array(“Altavista”,“http://www.altavista.com”,0,20,150);
Menu3_2=new Array(“Google”,“http://www.google.com”,0);
Menu3_3=new Array(“Yahoo”,“http://www.yahoo.com”,0);
Menu4=new Array(“Webmaster”,“blank.htm”,4);
Menu4_1=new Array(“Dynamic Drive”,“http://www.dynamicdrive.com”,0,20,180);
Menu4_2=new Array(“Website Abstraction”,“http://www.google.com”,0);
Menu4_3=new Array(“Freewarejava”,“http://www.freewarejava.com”,0);
Menu4_4=new Array(“Web Review”,“http://www.webreview.com”,0);
Menu5=new Array(“Other”,“javascript:top.location.href=‘blank.htm’”,1);
Menu5_1=new Array(“Author’s Site”,“http://www.burmees.nl/”,0,20,140);
