al-kaida bin laden 1A21-0009-9130-2159-0408-6248 Windows XP 5.1 IA32 WinAspi: File ‘Wnaspi32.dll’: Ver=5, 0, 0, 1, size=22528 bytes, created 2001-03-17 21:34:12 ahead WinASPI: File ‘C:\Program Files\Ahead\Nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 17:35:34 Wersja Nero: 6.6.0.5 (Nero Express) Nagrywarka: Wersja: 1.00 - HA 1 TA 0 - 6.6.0.5 Sterownik adaptera: HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: Wersja: 1.0 - HA 0 TA 0 - 6.6.0.5 Sterownik adaptera: HA 0 === Scsi-Device-Map === CdRomPeripheral : SCSI DVD-ROM 1.0 VClone Port 0 ID 0 DMA: Off CdRomPeripheral : HL-DT-ST DVD-RAM GSA-H22N atapi Port 1 ID 0 DMA: On DiskPeripheral : ST3250820AS iaStor Port 3 ID 0 DMA: On === CDRom-Device-Map === SCSI DVD-ROM E: CDRom1 HL-DT-ST DVD-RAM GSA-H22 D: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1023MB (1047788kB) Free physical memory: 708MB (725448kB) Memory in use : 30 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 18.2.2007 Kompilacja UDF 19:09:14 #1 Text 0 File Isodoc.cpp, Line 6168 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 19:09:14 #2 Text 0 File Reader.cpp, Line 127 Reader running 19:09:14 #3 Text 0 File Writer.cpp, Line 122 Writer HL-DT-ST DVD-RAM GSA-H22N running 19:09:14 #4 Text 0 File Burncd.cpp, Line 3155 Turn on Disc-At-Once, using DVD media 19:09:14 #5 Text 0 File DlgWaitCD.cpp, Line 257 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1310681 (291:15.56, 2559MB) 19:09:14 #6 Text 0 File DlgWaitCD.cpp, Line 269 Write in overburning mode: NO (enabled: CD DVD) 19:09:14 #7 Text 0 File DlgWaitCD.cpp, Line 2310 Recorder: HL-DT-ST DVD-RAM GSA-H22N, Media type: DVD-R Disc Manufacturer: TYG02 - Disc Application Code: 64, Disc Physical Code: 193 19:09:14 #8 Text 0 File DlgWaitCD.cpp, Line 431 >>> Protocol of DlgWaitCD activities: <<< ========================================= 19:09:14 #9 Text 0 File ThreadedTransferInterface.cpp, Line 829 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 1310832 (1310832) = #1310832/291:17.57 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1310832 blocks [HL-DT-ST DVD-RAM GSA-H22N] -------------------------------------------------------------- 19:09:14 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1042 Prepare recorder [HL-DT-ST DVD-RAM GSA-H22N] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2684583936, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1310832 | lead-out | 1 | 0x41 | 0x00 19:09:14 #11 Phase 24 File dlgbrnst.cpp, Line 1832 Rozpoczęto buforowanie plików 19:09:15 #12 Text 0 File Burncd.cpp, Line 4042 Cache writing successful. 19:09:15 #13 Phase 25 File dlgbrnst.cpp, Line 1832 Zakończono buforowanie plików 19:09:15 #14 Phase 36 File dlgbrnst.cpp, Line 1832 Rozpoczęto zapis z prędkością 4x (5 540 KB/s) 19:09:15 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2604 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 19:09:15 #16 Text 0 File DVDR.cpp, Line 2260 Recording mode: Sequential Recording Mode 19:09:15 #17 Text 0 File Mmc.cpp, Line 21060 Set BUFE: Buffer underrun protection -> ON 19:09:15 #18 Text 0 File DVDR.cpp, Line 2401 Start write address at LBA 0 DVD high compatibility mode: Yes 19:09:15 #19 Text 0 File Cdrdrv.cpp, Line 8332 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 5 Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16…63]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 … 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 19:10:51 #20 SCSI -1135 File Cdrdrv.cpp, Line 1432 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0A240000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x80 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00 0x0C 0x80 19:10:51 #21 CDR -1135 File Writer.cpp, Line 311 Błąd zapisu! 19:10:51 #22 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 19:10:51 #23 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 19:10:51 #24 Text 0 File DVDR.cpp, Line 2642 EndDAO: Last written address was -1 19:10:51 #25 Phase 38 File dlgbrnst.cpp, Line 1832 Zapis z prędkością 4x (5 540 KB/s) nie powiódł się! Existing drivers: File ‘Drivers\CDRALW2K.SYS’: Ver=8.0.0.212 , size=2560 bytes, created 2006-08-25 04:47:00 File ‘Drivers\ASPI32.SYS’: Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 2002-07-17 09:05:10 File ‘Drivers\PXHELP20.SYS’: Ver=3.00.33a, size=36528 bytes, created 2006-08-25 04:47:00 (Prassi/Veritas driver for win 2K) File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 21:59:44 (Adapter driver for rec) File ‘Drivers\VClone.sys’: Ver=5, 1, 1, 0, size=24320 bytes, created 2006-04-22 20:59:21 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
