Toshiba TOSHIBA 1A20-020E-0000-1349-1210-6697* Windows XP 6.0 IA32 WinAspi: File ‘Wnaspi32.dll’: Ver=?.?.?.?, size=13840 bytes, created 2007-03-30 00:44:48 ahead WinASPI: File ‘C:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 20:18:06 Wersja Nero: 6.3.1.12 (Nero Express) Nagrywarka: Wersja: RT04 - HA 0 TA 1 - 6.3.1.12 Sterownik adaptera: HA 0 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 11 Drive is autodetected - recorder class: DVD+R9 DL recorder CD-ROM: Wersja: 2.31 - HA 1 TA 0 - 6.3.1.12 Sterownik adaptera: <> HA 1 === Scsi-Device-Map === DiskPeripheral : TOSHIBA MK3252GSX iaStor Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-T50N iaStor Port 0 ID 1 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-T50N F: CDRom0 HUAWEI Mass Storage G: CDRom4 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 2047MB (2097151kB) Free physical memory: 1695MB (1736416kB) Memory in use : 44 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 24.2.2010 Kompilacja ISO 22:15:46 #1 Text 0 File Isodoc.cpp, Line 6065 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 22:15:46 #2 Text 0 File Reader.cpp, Line 118 Reader running 22:15:46 #3 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 22:15:46 #4 Text 0 File Burncd.cpp, Line 3167 Turn on Disc-At-Once, using DVD media 22:15:46 #5 Text 0 File DlgWaitCD.cpp, Line 245 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 358575 ( 79:41.00, 700MB) 22:15:46 #6 Text 0 File DlgWaitCD.cpp, Line 257 Write in overburning mode: NO (enabled: CD) 22:15:46 #7 Text 0 File DlgWaitCD.cpp, Line 2137 Recorder: HL-DT-ST DVDRAM GSA-T50N, Media type: DVD+R Disc Manufacturer ID: AML, Media Type ID: 003, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 22:15:46 #8 Text 0 File DlgWaitCD.cpp, Line 418 >>> Protocol of DlgWaitCD activities: <<< ========================================= 22:15:46 #9 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 358576 (358576) = #358576/79:41.1 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358576 blocks [HL-DT-ST DVDRAM GSA-T50N] -------------------------------------------------------------- 22:15:47 #10 Text 0 File ThreadedTransferInterface.cpp, Line 982 Prepare recorder [HL-DT-ST DVDRAM GSA-T50N] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 734363648, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 0 | lead-in | 0 | 0x00 | 0x41 0 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 358576 | lead-out | 1 | 0x00 | 0x41 22:15:47 #11 Phase 24 File dlgbrnst.cpp, Line 1836 Rozpoczęto buforowanie plików 22:15:47 #12 SCSI -500 File Cdrdrv.cpp, Line 1187 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x06D57000 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 22:15:47 #13 Text 0 File Burncd.cpp, Line 4177 Cache writing successful. 22:15:47 #14 Phase 25 File dlgbrnst.cpp, Line 1836 Zakończono buforowanie plików 22:15:47 #15 Phase 36 File dlgbrnst.cpp, Line 1836 Rozpoczęto zapis z prędkością 8x (11 080 KB/s) 22:15:47 #16 SCSI -500 File Cdrdrv.cpp, Line 1187 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x06D57000 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 22:15:47 #17 SCSI -500 File Cdrdrv.cpp, Line 1187 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x06D55E68 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x5A 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x48 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 22:15:47 #18 CDR -500 File ThreadedTransferInterface.cpp, Line 1462 Przerwano polecenie SCSI! HL-DT-ST DVDRAM GSA-T50N\H0 T1 22:15:47 #19 Phase 38 File dlgbrnst.cpp, Line 1836 Zapis z prędkością 8x (11 080 KB/s) nie powiódł się! 22:16:17 #20 SCSI -500 File Cdrdrv.cpp, Line 1187 SCSI Exec, HA 0, TA 1, LUN 0 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 22:16:17 #21 SCSI -500 File Cdrdrv.cpp, Line 1187 SCSI Exec, HA 0, TA 1, LUN 0 Status: 0x02 (0x03, SCSI_ABORTED) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x1E 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 Existing drivers: File ‘Drivers\ADPU160M.SYS’: Ver=6.4.645.100 (NT.070221-1001), size=101432 bytes, created 2008-01-21 03:23:26 File ‘Drivers\iaStor.sys’: Ver=8.5.0.1032, size=324120 bytes, created 2008-07-20 16:44:44 (Adapter driver for rec) File ‘Drivers\iaStorV.sys’: Ver=6.2.0.1019, size=235064 bytes, created 2008-01-21 03:23:23 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
