Problem z nagrywarka HL-DT-ST DVD-RW GWA-4082N
(Boombels) #1
Witam od pewnego czasu mam problem z nagrywaniem płyt posiadam laptopa Fujitsu siemens Amilo pro 2030.. Ponizej umieszczam Raport Nero express 6. Z góry dziekuje za pomoc.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:32
Nero Version: 6.6.0.8 (Nero Express)
Recorder: Version: CW02 - HA 0 TA 0 - 6.6.0.8
Adapter driver: HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Version: CW02 - HA 0 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVD-RW GWA-4082N atapi Port 0 ID 0 DMA: On
DiskPeripheral : FUJITSU MHV2060BH 0000 viamraid Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD-RW GWA-4082 E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 66060288 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 446MB (456944kB)
Free physical memory: 74MB (76608kB)
Memory in use : 83 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.7.2009
Kompilacja ISO
17:59:40 #1 Text 0 File Isodoc.cpp, Line 6179
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
17:59:40 #2 Text 0 File Reader.cpp, Line 127
Reader running
17:59:40 #3 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVD-RW GWA-4082N running
17:59:40 #4 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
17:59:40 #5 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
17:59:41 #6 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1411535 (313:40.35, 2756MB)
17:59:41 #7 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
17:59:41 #8 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: HL-DT-ST DVD-RW GWA-4082N, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
17:59:41 #9 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
17:59:41 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1411536 (1411536) = #1411536/313:40.36
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1411536 blocks [HL-DT-ST DVD-RW GWA-4082N]
17:59:42 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HL-DT-ST DVD-RW GWA-4082N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2890825728, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1411536 | lead-out | 1 | 0x41 | 0x00
17:59:42 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
17:59:43 #13 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
17:59:43 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
17:59:43 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11 080 KB/s)
17:59:43 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17:59:43 #17 Text 0 File DVDR.cpp, Line 2246
Recording mode: Sequential Recording Mode for Multisession
17:59:43 #18 Text 0 File Mmc.cpp, Line 21327
Set BUFE: Buffer underrun protection -> ON
17:59:43 #19 Text 0 File DVDR.cpp, Line 2392
Start write address at LBA 0
DVD high compatibility mode: Yes
17:59:43 #20 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
17:59:43 #21 Text 0 File DVDR.cpp, Line 4877
Drive: HL-DT-ST DVD-RW GWA-4082N
Book Type request [LG]: Physical disc type
Book Type setting not supported for the loaded disc type
18:00:06 #22 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03C05400
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x32 0x4D 0x03 0x0C 0x0C 0x00
18:00:06 #23 SCSI -1064 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x056C0000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x10
0x2A 0x00 0x00 0x0C 0x21 0x02
18:00:06 #24 CDR -1135 File Writer.cpp, Line 311
Write error
HL-DT-ST DVD-RW GWA-4082N\H0 T0
18:00:06 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:00:06 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
18:00:06 #27 Text 0 File DVDR.cpp, Line 2655
EndDAO: Last written address was 31
18:00:08 #28 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
18:00:08 #29 Text 0 File DVDR.cpp, Line 4877
Book Type request [LG]: DVD+R
18:00:08 #30 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11 080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 2007-03-08 01:51:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-03-08 01:51:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.5512 (xpsp.080413-2108), size=96512 bytes, created 2008-04-13 20:40:30 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
(Technik Elektro) #2
a co dokładnie się dzieje ??
