Kontynuacja:
Oto log z nero:
Probowalem nagrac 2 razy cd:
1 log:
Kod:
xxx
xxxx
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-06-17 15:25:04
Nero version: 6.0.0.9
Recorder: Version: QS0E - HA 1 TA 0 - 6.0.0.9
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Version: CH11 - HA 1 TA 1 - 6.0.0.9
=== Scsi-Device-Map ===
DiskPeripheral : WDC AC24300L atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-52327S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : JLMS XJ-HD165H atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 226MB (232316kB)
Memory in use : 55 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.8.2006
CD-ROM (ISO)
21:54:51 #1 Text 0 File Isodoc.cpp, Line 5748
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:54:51 #2 Phase 90 File dlgbrnst.cpp, Line 1843
Buffer Underrun Protection activated
21:54:52 #3 Text 0 File Reader.cpp, Line 118
Reader running
21:54:52 #4 Text 0 File Writer.cpp, Line 127
Writer LITE-ON LTR-52327S running
21:54:53 #5 ISO9660GEN -11 File geniso.cpp, Line 3854
First writeable address = 0 (0x00000000)
21:54:53 #6 Text 0 File Burncd.cpp, Line 3173
Turn on Track-at-once, using CD-R/RW media
21:54:54 #7 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 323930 (72:01.05)
21:54:54 #8 Text 0 File DlgWaitCD.cpp, Line 233
Write in overburning mode: FALSE
21:54:54 #9 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: LITE-ON LTR-52327S;
CDR code: 00 97 27 58; OSJ entry from: Mitsui Chemicals, Inc.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 3A (LI 97:27.58), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
21:54:54 #10 Text 0 File ThreadedTransferInterface.cpp, Line 768
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 40113 (40113) = #40113/8:54.63
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 40111 blocks [LITE-ON LTR-52327S]
21:54:56 #11 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [LITE-ON LTR-52327S] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 82458624, ISRC ""
DAO layout:
__Start_|____ Track_|_Idx_|_RecDep_|_CtrlAdr_
283668 | lead-in | 0 | 0x00 | 0x41
283668 | 2 | 0 | 0x00 | 0x41
283818 | 2 | 1 | 0x00 | 0x41
323931 | lead-out | 1 | 0x00 | 0x41
21:54:56 #12 Text 0 File ThreadedTransferInterface.cpp, Line 964
Removed 2 run-out blocks from end of track 2.
21:54:57 #13 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
21:54:57 #14 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
21:54:57 #15 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 52x (7 800 KB/s)
21:54:58 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2130
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #283818
21:54:58 #17 Text 0 File Mmc.cpp, Line 18724
Set BUFE: supported -> ON , SMART-BURN : ON
21:55:09 #18 SCSI -1047 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03C50000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x04 0x54 0xAA 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x64 0x00
21:55:09 #19 CDR -1047 File Writer.cpp, Line 335
Illegal mode for this track
21:55:09 #20 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
21:55:09 #21 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
21:55:09 #22 CDR -201 File WriterStatus.cpp, Line 193
Invalid write state
21:55:09 #23 TRANSFER -18 File WriterStatus.cpp, Line 193
Could not perform EndTrack
21:55:09 #24 Text 0 File Mmc.cpp, Line 13731
start Close Session
21:55:09 #25 SCSI -1176 File Cdrdrv.cpp, Line 1205
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
21:55:09 #26 CDR -1176 File WriterStatus.cpp, Line 232
Session fixation error
21:55:09 #27 TRANSFER -19 File WriterStatus.cpp, Line 232
Could not perform Fixation
21:55:09 #28 Text 0 File WriterStatus.cpp, Line 241
falling back to disc fixation
21:55:10 #29 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
21:55:10 #30 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 52x (7 800 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 2001-08-17 21:51:56 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Log 2:
Kod:
xxx
xxxx
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 213MB (218416kB)
Memory in use : 58 %
Use Inquiry : 1
1.8.2006
CD-ROM (ISO)
21:56:48 #1 Text 0 File Isodoc.cpp, Line 5748
Simulate : TRUE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
21:56:48 #2 Phase 90 File dlgbrnst.cpp, Line 1843
21:56:48 #3 Text 0 File Reader.cpp, Line 118
Reader running
21:56:48 #4 Text 0 File Writer.cpp, Line 127
21:56:48 #5 ISO9660GEN -11 File geniso.cpp, Line 3854
21:56:48 #6 Text 0 File Burncd.cpp, Line 3173
21:56:49 #7 Text 0 File DlgWaitCD.cpp, Line 228
Last address to be written: 40112 ( 8:56.62)
21:56:49 #8 Text 0 File DlgWaitCD.cpp, Line 233
21:56:49 #9 Text 0 File DlgWaitCD.cpp, Line 1722
ATIP Data:
21:56:49 #10 Text 0 File ThreadedTransferInterface.cpp, Line 768
21:56:49 #11 Text 0 File ThreadedTransferInterface.cpp, Line 937
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
40113 | lead-out | 1 | 0x00 | 0x41
21:56:49 #12 Text 0 File ThreadedTransferInterface.cpp, Line 964
Removed 2 run-out blocks from end of track 1.
21:56:49 #13 Phase 24 File dlgbrnst.cpp, Line 1843
21:56:49 #14 Phase 25 File dlgbrnst.cpp, Line 1843
21:56:49 #15 Phase 32 File dlgbrnst.cpp, Line 1843
Simulation started at 16x (2 400 KB/s)
21:56:49 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2130
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:56:49 #17 Text 0 File Mmc.cpp, Line 18724
21:57:43 #18 Text 0 File ThreadedTransfer.cpp, Line 227
21:57:44 #19 Text 0 File dlgbrnst.cpp, Line 1703
21:57:48 #20 Phase 33 File dlgbrnst.cpp, Line 1843
Simulation completed successfully at 16x (2 400 KB/s)
21:57:48 #21 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 16x (2 400 KB/s)
21:57:48 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2130
21:57:48 #23 Text 0 File Mmc.cpp, Line 18724
21:58:21 #24 SCSI -1135 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03CE0000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
21:58:21 #25 CDR -1135 File Writer.cpp, Line 335
Write error
21:58:21 #26 Text 0 File ThreadedTransfer.cpp, Line 227
21:58:21 #27 Text 0 File ThreadedTransfer.cpp, Line 221
21:58:21 #28 CDR -201 File WriterStatus.cpp, Line 193
Invalid write state
21:58:21 #29 TRANSFER -18 File WriterStatus.cpp, Line 193
21:58:21 #30 Text 0 File Mmc.cpp, Line 13731
start Close Session
21:58:43 #31 SCSI -1176 File Cdrdrv.cpp, Line 1205
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x00
21:58:43 #32 CDR -1176 File WriterStatus.cpp, Line 232
21:58:43 #33 TRANSFER -19 File WriterStatus.cpp, Line 232
21:58:43 #34 Text 0 File WriterStatus.cpp, Line 241
21:58:43 #35 Text 0 File Mmc.cpp, Line 13731
start Close Session
21:58:43 #36 Text 0 File dlgbrnst.cpp, Line 1703
21:58:43 #37 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 16x (2 400 KB/s)
Existing drivers:
Registry Keys:
Wasze odpowiedzi:
MAX dobrze podłaczony ,może tu leży problem Pytajnik użyj szukajki forumowej było dużo postów z podobnym problemem =>chyba raczej dobrze podlaczony,
marek624 a wcześniej nagrywało dobrze?, jak skonfigurowana jest nagrywarka?, komp nie podkręcony?, na wszystkich płytach się tak dzieje? Z tego loga wynika, że masz włączony autorun, można spróbować go wyłączyć. Z pierwszego loga wynika mi, że była ustawiona za duza prędkość zapisu, co przy marnej jakości płyty często kończy się błędem, w drugim logu symulacja przebiegła prawidłowo, a wystąpił problem z odczytem danych. A ty przegrywasz z płyty na płytę, czy z dysku? => wczesniej nagrywało dobrze, nie wiem jak jest skonfigurowana… Procek jest chyba podkrecony bo byl athlon 2500 a jest 3000, jak wylaczyc autorun? nagrywam pliki z dysku na cd.
Podaj typ nagrywarki, może należy firmware zaaktualizować Confused => chyba już to zrobiłem, LITE-ON LTR-52327S
forceaspi18 instalowalem i chyba ten firmware…
Złączono Posta : 14.08.2006 (Pon) 11:50
R52QS0E5A => sie nazywał rar chyba z tym firmware
