Tak, napis jest… więc dobrze się zainstalowało… gorzej, że z nagrywarką jest tak samo
Nie wiem, może by spróbować Nero zainstalować ?
Edit://
Oto co wykazał mi NERO :
1C83-746A-18E5-4A2X-400C-C1E4-E3EA
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 09:20:56
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
(Nero Express)
Recorder: Version: US06 - HA 1 TA 0 - 7.0.1.2
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: Version: 14 - HA 1 TA 1 - 7.0.1.2
=== Scsi-Device-Map ===
DiskPeripheral : HDS722580VLAT20 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-H552U atapi Port 1 ID 0 DMA: On
CdRomPeripheral : VOBID InstantDrive CD 14 VOBID Port 3 ID 0 DMA: Off
CdRomPeripheral : RT0296X AZR651H 2.0B ait8w0ar Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW TS-H552U F: CDRom0
VOBID InstantDrive CD G: CDRom1
RT0296X AZR651H H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 29MB (30212kB)
Memory in use : 94 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.1.2008
Audio CD
22:13:51 #1 CDADOC -1 File Cdadoc.cpp, Line 1507
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 03:34.46, Pause frames: 150, Filters: 0, Name: 'Alex C Feat Y-Ass - Du Hast Den Schönsten Arsch Der Welt.mp3'.
Track 02: Length: 04:53.07, Pause frames: 150, Filters: 0, Name: 'Bez cenzury - Przesiąknieci dźwiękiem.mp3'.
Track 03: Length: 02:53.59, Pause frames: 150, Filters: 0, Name: 'Dj Decibel &Peter Presents.Peter - Tak Bardzo Cie Kocham[2007].mp3'.
Track 04: Length: 03:36.20, Pause frames: 150, Filters: 0, Name: 'Dj remo - My music song.mp3'.
Track 05: Length: 03:59.64, Pause frames: 150, Filters: 0, Name: 'Evanescence- Bring me back to life.mp3'.
Track 06: Length: 03:51.11, Pause frames: 150, Filters: 0, Name: 'Fler - Neue Deutsche Welle 2005.mp3'.
Track 07: Length: 03:01.41, Pause frames: 150, Filters: 0, Name: 'Fler Feat Dj Tomekk - Jump Jump.mp3'.
Track 08: Length: 03:16.07, Pause frames: 150, Filters: 0, Name: 'Linkin park - Breaking the habbit.mp3'.
Track 09: Length: 04:09.01, Pause frames: 150, Filters: 0, Name: 'Perfekt - Niepokonani.mp3'.
Track 10: Length: 04:51.21, Pause frames: 150, Filters: 0, Name: 'Pezet - Noc i Dzień.mp3'.
Track 11: Length: 08:30.55, Pause frames: 150, Filters: 0, Name: 'Pono feat. Sokół - Uderz w Puchara.mp3'.
Track 12: Length: 03:02.72, Pause frames: 150, Filters: 0, Name: 'Rap & Rnb - Dj Tomek & Lil Kim & Trooper Da Don - Kimnotyze.mp3'.
Track 13: Length: 03:42.40, Pause frames: 150, Filters: 0, Name: 'Seryoga - King Ring.mp3'.
Track 14: Length: 08:30.55, Pause frames: 150, Filters: 0, Name: 'Sokół i Pono feat. Tede - Uderz w Puchara Remix.mp3'.
Track 15: Length: 04:40.08, Pause frames: 150, Filters: 0, Name: 'Trzeci Wymiar - Wuuuf.mp3'.
Track 16: Length: 03:53.38, Pause frames: 150, Filters: 0, Name: 'Uniting Nations - Ai No Corrida.mp3'.
Track 17: Length: 03:05.05, Pause frames: 150, Filters: 0, Name: 'WWO - Minorum Gentium.mp3'.
Total size: 74:06.25
22:13:51 #2 Text 0 File Burncd.cpp, Line 3008
Super Link activated
22:13:51 #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 72704KB of Memory
22:13:51 #4 Text 0 File Reader.cpp, Line 124
Reader running
22:13:51 #5 Text 0 File Writer.cpp, Line 113
Writer F: TSSTcorp CD/DVDW TS-H552U running
22:13:51 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
22:13:51 #7 Text 0 File Burncd.cpp, Line 3302
Turn on Disc-At-Once, using CD-R/RW media
22:13:52 #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 333324 ( 74:06.24)
22:13:52 #9 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
22:13:52 #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: TSSTcorp CD/DVDW TS-H552U
22:13:52 #11 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
22:13:52 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (Alex C Feat Y-Ass - Du Hast Den Schönsten Arsch Der Welt.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 16096 (16096) = #16096/3:34.46
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 16096 blocks [F]
1: TRM_AUDIO_NOPRE (Bez cenzury - Przesiąknieci dźwiękiem.mp3)
original disc pos #0 + 21982 (21982) = #21982/4:53.7
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 21982 blocks [F]
2: TRM_AUDIO_NOPRE (Dj Decibel &Peter Presents.Peter - Tak Bardzo Cie Kocham[2007].mp3)
original disc pos #0 + 13034 (13034) = #13034/2:53.59
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 13034 blocks [F]
3: TRM_AUDIO_NOPRE (Dj remo - My music song.mp3)
original disc pos #0 + 16220 (16220) = #16220/3:36.20
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 16220 blocks [F]
4: TRM_AUDIO_NOPRE (Evanescence- Bring me back to life.mp3)
original disc pos #0 + 17989 (17989) = #17989/3:59.64
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 17989 blocks [F]
5: TRM_AUDIO_NOPRE (Fler - Neue Deutsche Welle 2005.mp3)
original disc pos #0 + 17336 (17336) = #17336/3:51.11
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 17336 blocks [F]
6: TRM_AUDIO_NOPRE (Fler Feat Dj Tomekk - Jump Jump.mp3)
original disc pos #0 + 13616 (13616) = #13616/3:1.41
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 13616 blocks [F]
7: TRM_AUDIO_NOPRE (Linkin park - Breaking the habbit.mp3)
original disc pos #0 + 14707 (14707) = #14707/3:16.7
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 14707 blocks [F]
8: TRM_AUDIO_NOPRE (Perfekt - Niepokonani.mp3)
original disc pos #0 + 18676 (18676) = #18676/4:9.1
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 18676 blocks [F]
9: TRM_AUDIO_NOPRE (Pezet - Noc i Dzień.mp3)
original disc pos #0 + 21846 (21846) = #21846/4:51.21
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 21846 blocks [F]
10: TRM_AUDIO_NOPRE (Pono feat. Sokół - Uderz w Puchara.mp3)
original disc pos #0 + 38305 (38305) = #38305/8:30.55
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 38305 blocks [F]
11: TRM_AUDIO_NOPRE (Rap & Rnb - Dj Tomek & Lil Kim & Trooper Da Don - Kimnotyze.mp3)
original disc pos #0 + 13722 (13722) = #13722/3:2.72
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 13722 blocks [F]
12: TRM_AUDIO_NOPRE (Seryoga - King Ring.mp3)
original disc pos #0 + 16690 (16690) = #16690/3:42.40
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 16690 blocks [F]
13: TRM_AUDIO_NOPRE (Sokół i Pono feat. Tede - Uderz w Puchara Remix.mp3)
14: TRM_AUDIO_NOPRE (Trzeci Wymiar - Wuuuf.mp3)
original disc pos #0 + 21008 (21008) = #21008/4:40.8
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 21008 blocks [F]
15: TRM_AUDIO_NOPRE (Uniting Nations - Ai No Corrida.mp3)
original disc pos #0 + 17513 (17513) = #17513/3:53.38
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 17513 blocks [F]
16: TRM_AUDIO_NOPRE (WWO - Minorum Gentium.mp3)
original disc pos #0 + 13880 (13880) = #13880/3:5.5
-> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 13880 blocks [F]
22:13:52 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [F] for write in raw writing
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 17:
1: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 0 367200 39770208, ISRC ""
2: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 39770208 40137408 93949344, ISRC ""
3: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 93949344 94316544 126223776, ISRC ""
4: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 126223776 126590976 166297536, ISRC ""
5: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 166297536 166664736 210701808, ISRC ""
6: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 210701808 211069008 253507536, ISRC ""
7: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 253507536 253874736 287206704, ISRC ""
8: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 287206704 287573904 323576640, ISRC ""
9: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 323576640 323943840 369662688, ISRC ""
10: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 369662688 370029888 423508896, ISRC ""
11: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 423508896 423876096 517646736, ISRC ""
12: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 517646736 518013936 551605392, ISRC ""
13: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 551605392 551972592 592829712, ISRC ""
14: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 592829712 593196912 686967552, ISRC ""
15: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 686967552 687334752 738762336, ISRC ""
16: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 738762336 739129536 782001360, ISRC ""
17: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 782001360 782368560 816346800, ISRC ""
DAO layout:
__Start_|____ Track_|_Idx_|_CtrlAdr_|_RecDep __________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
16096 | 2 | 0 | 0x21 | 0x00
16246 | 2 | 1 | 0x21 | 0x00
38228 | 3 | 0 | 0x21 | 0x00
38378 | 3 | 1 | 0x21 | 0x00
51412 | 4 | 0 | 0x21 | 0x00
51562 | 4 | 1 | 0x21 | 0x00
67782 | 5 | 0 | 0x21 | 0x00
67932 | 5 | 1 | 0x21 | 0x00
85921 | 6 | 0 | 0x21 | 0x00
86071 | 6 | 1 | 0x21 | 0x00
103407 | 7 | 0 | 0x21 | 0x00
103557 | 7 | 1 | 0x21 | 0x00
117173 | 8 | 0 | 0x21 | 0x00
117323 | 8 | 1 | 0x21 | 0x00
132030 | 9 | 0 | 0x21 | 0x00
132180 | 9 | 1 | 0x21 | 0x00
150856 | 10 | 0 | 0x21 | 0x00
151006 | 10 | 1 | 0x21 | 0x00
172852 | 11 | 0 | 0x21 | 0x00
173002 | 11 | 1 | 0x21 | 0x00
211307 | 12 | 0 | 0x21 | 0x00
211457 | 12 | 1 | 0x21 | 0x00
225179 | 13 | 0 | 0x21 | 0x00
225329 | 13 | 1 | 0x21 | 0x00
242019 | 14 | 0 | 0x21 | 0x00
242169 | 14 | 1 | 0x21 | 0x00
280474 | 15 | 0 | 0x21 | 0x00
280624 | 15 | 1 | 0x21 | 0x00
301632 | 16 | 0 | 0x21 | 0x00
301782 | 16 | 1 | 0x21 | 0x00
319295 | 17 | 0 | 0x21 | 0x00
319445 | 17 | 1 | 0x21 | 0x00
333325 | lead-out | 1 | 0x01 | 0x00
22:13:52 #14 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
22:13:52 #15 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 40x (6 000 KB/s)
22:13:53 #16 SPTI -1189 File SCSIPassThrough.cpp, Line 323
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x07c8d000: Len x4000
22:13:53 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
22:13:53 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #16246
22:13:53 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #38378
22:13:53 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #51562
22:13:53 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #67932
22:13:53 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #86071
22:13:53 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #103557
22:13:53 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #117323
22:13:53 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #132180
22:13:53 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #151006
22:13:53 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #173002
22:13:53 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #211457
22:13:53 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #225329
22:13:53 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #242169
22:13:53 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #280624
22:13:53 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #301782
22:13:53 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #319445
22:13:53 #34 Text 0 File MMC.cpp, Line 16932
StartDAO : CD-Text - On
22:13:53 #35 Text 0 File MMC.cpp, Line 21611
Set BUFE: Super Link -> ON
22:15:42 #36 SPTI -1135 File SCSIPassThrough.cpp, Line 323
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 FF FF D8 59 00 00 1A 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x07f70000: Len xf8a0
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
22:15:42 #37 CDR -1135 File Writer.cpp, Line 302
Write error
22:15:42 #38 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
22:15:42 #39 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
22:15:42 #40 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 40x (6 000 KB/s)
22:15:42 #41 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
22:15:42 #42 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 2007-03-08 00:51:00
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 08:53:02
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-03-08 00:51:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
