mam legaalne nero6 .ostatnio nie mogę nagrać żadnej płyty niewiem czemu,mam taki raport o błędach Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‘C:\Program Files\Ahead\nero\nero\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 17:35:32
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: Version: KYS1 - HA 0 TA 0 - 6.6.0.14
Adapter driver: HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Version: KYS1 - HA 0 TA 0 - 6.6.0.14
=== Scsi-Device-Map ===
CdRomPeripheral : SONY DVD RW DW-Q28A atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1200JS-00MHB0 02.0 viamraid Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q28A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 135MB (138368kB)
Memory in use : 73 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.12.2006
Kompilacja ISO
14:21:34 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:21:34 #2 Text 0 File Reader.cpp, Line 127
Reader running
14:21:34 #3 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DW-Q28A running
14:21:34 #4 ISO9660GEN -11 File geniso.cpp, Line 3297
First writeable address = 0 (0x00000000)
14:21:34 #5 Text 0 File Burncd.cpp, Line 3230
Turn on Disc-At-Once, using DVD media
14:21:35 #6 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 717135 (159:21.60, 1400MB)
14:21:35 #7 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
14:21:35 #8 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: SONY DVD RW DW-Q28A, Media type: DVD-R
Disc Manufacturer: UME01 -
Disc Application Code: 64, Disc Physical Code: 193
14:21:35 #9 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
14:21:35 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 717136 (717136) = #717136/159:21.61
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 717136 blocks [sONY DVD RW DW-Q28A]
14:21:38 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [sONY DVD RW DW-Q28A] for write in CUE-sheet-DAO
DAO infos:
MCN: “”
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1468694528, ISRC “”
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
717136 | lead-out | 1 | 0x41 | 0x00
14:21:38 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
14:21:39 #13 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
14:21:39 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
14:21:39 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11 080 KB/s)
14:21:39 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:21:39 #17 Text 0 File DVDR.cpp, Line 2316
Recording mode: Sequential Recording Mode for Multisession
14:21:39 #18 Text 0 File Mmc.cpp, Line 21592
Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
14:21:39 #19 Text 0 File DVDR.cpp, Line 2470
Start write address at LBA 0
DVD high compatibility mode: Yes
14:21:39 #20 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16…63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …
14:24:48 #21 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03BB4E00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
14:24:48 #22 SCSI -1064 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03640000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x21 0x00
14:24:48 #23 CDR -1135 File Writer.cpp, Line 311
Write error
SONY DVD RW DW-Q28A\H0 T0
14:24:48 #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
14:24:48 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
14:24:48 #26 Text 0 File DVDR.cpp, Line 2708
EndDAO: Last written address was 31
14:24:48 #27 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
14:24:48 #28 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11 080 KB/s)
Existing drivers:
File ‘Drivers\PXHELP20.SYS’: Ver=2.03.32a, size=20640 bytes, created 2006-04-18 23:34:55 (Prassi/Veritas driver for win 2K)
File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-04 13:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
napęd DVD+/RW sonyDW-Q28A DL black bulk a w nero pokazuje SONY DVD RW DW-Q28A [DVD] proszę poraddzcie coś :evil:
