oto mój problem co robić?
A problem has been detectednand windows has been shut down to prevent damage to your computer.
If this is first time you`ve seen this stop error screen,
restart your computer.If this screen appears again,follow these steps:
Check to be sure you have adequate disk space.if a driver is identifield in the stop message,
disable the driver or check with the manufacturer for driver updates.Try changing video adapters.
Check with your hardware vendor for any BIOS updates.Disable BIOS memory options such as caching or shadowing.If you need
to use Safe mode to remove or disable components, restart your computer, press F8 to select advanced Startup Options, and then select Safe Mode
technical information:
Stop: 0x0000007E ( 0x0000005, 0x859260AE, 0x86353BA0, 0x8635389C)
volsnap.sys - address 859260AE base at 85921000, datestamp 47918f92
co proponujecie w tej sytuacji czekam napomoc
