BranT
(Patryk376)
12 Czerwiec 2014 15:54
#1
Witam.
Mam pewien problem, ponieważ od wczoraj, gdy chcę wejść na jakąś stronę(nie każdą) pojawia się komunikat; Attention required, inaczej One More Step i prosi, abym przepisywał kod z obraza, za każdym razem… Przeskanowałem komputer dwa razy, avastem i esetem(wykryło 7 zagrożeń, po ich usunięciu błąd ten sam), skan malware nic, nie dało żadnej poprawy, użyłem również AdwCleaner, który znalazł wiele “śmieci” i więc je usunąłem, jednak to też nic nie pomogło.
http://wklej.org/id/1390239/
Atis
(Atis)
12 Czerwiec 2014 16:42
#2
Do okna Własne opcje skanowania / skrypt wklej:
:OTL
DRV:64bit: - File not found [Kernel | On_Demand | Stopped] -- C:\Program Files\MSI\Live Update 5\NTIOLib_X64.sys -- (NTIOLib_1_0_4)
O4:64bit: - HKLM..\Run: [AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA] 1 File not found
O4 - HKLM..\Run: [] File not found
O4 - HKCU..\Run: [AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA] 1 File not found
[2014-06-12 12:41:51 | 000,000,000 | ---D | C] -- C:\AdwCleaner
@Alternate Data Stream - 4 bytes -> C:\Temp:rnd.dat
@Alternate Data Stream - 4 bytes -> C:\Temp:pid2
@Alternate Data Stream - 4 bytes -> C:\Temp:pid1
@Alternate Data Stream - 36 bytes -> C:\Temp:srv
@Alternate Data Stream - 1611 bytes -> C:\Temp:list3
:Files
C:\Temp
:Commands
[emptytemp]
Pobierz Farbar Recovery Scan Tool 64-Bit Version
Uruchom FRST i kliknij Scan. Pokaż raport FRST i Addition.
BranT
(Patryk376)
12 Czerwiec 2014 16:56
#3
Atis
(Atis)
12 Czerwiec 2014 17:35
#4
Wklej do systemowego notatnika i zapisz jako plik tekstowy o nazwie fixlist :
SearchScopes: HKLM-x32 - DefaultScope value is missing.
S3 MSICDSetup; \??\D:\CDriver64.sys [X]
S3 NTIOLib_1_0_C; \??\D:\NTIOLib_X64.sys [X]
Reg: reg delete "HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\LiveSupport" /f
Hosts:
Uruchom FRST i kliknij Fix. Pokaż raport z usuwania Fixlog.
Kliknij Scan i pokaż nowy raport z FRST bez Addition.
BranT
(Patryk376)
12 Czerwiec 2014 18:08
#5
Atis
(Atis)
12 Czerwiec 2014 18:26
#6
Odinstaluj jeden program antywirusowy, Avast lub Eset.
Wklej do OTL i kliknij Wykonaj skrypt:
:Files
C:\FRST
Uruchom OTL i kliknij Sprzątanie.
Usuń stare punkty przywracania: Aby usunąć wszystkie punkty przywracania
Odinstaluj Adobe Flash Player 13 ActiveX, dobe Flash Player 13 Plugin, Adobe Reader 9.5.0.
Zainstaluj Adobe Reader XI 11.0.7 i Flash Player 14.0.0.125 Internet Explorer i Plugin-based browsers
