chce zainstalowac phpfusion i wywoluje adres install.php i takie cos mi sie pokazuje!
Warning: require(fusion_themes/Prometheus/theme.php) [function.require]: failed to open stream: No such file or directory in /home/g/u/l/guldog/www/install/install.php on line 13
Fatal error: require() [function.require]: Failed opening required ‘fusion_themes/Prometheus/theme.php’ (include_path=’.:/usr/local/php5/lib/php’) in /home/g/u/l/guldog/www/install/install.php on line 13
