Witajcie, drodzy forumowicze!
Jestem tu 1 raz na tym forum i proszę o wyrozumiałość.
Otóż tak jak w temacie: mam problem z spdg.dll
Zrobiłem prawie to samo co w tym poście: http://forum.dobreprogramy.pl/problem-spdg-dll-czyli-zaden-program-exe-nie-dziala-t493837.html
To jest z OTL
All processes killed
========== OTL ==========
64bit-Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\AsioReg not found.
Registry key HKEY_USERS\S-1-5-21-1151065415-2357480172-3015735021-1000\Software\Microsoft\Windows\CurrentVersion\Run not found.
Registry key HKEY_USERS\S-1-5-21-1151065415-2357480172-3015735021-1000_Classes\.com\ not found.
Registry key HKEY_USERS\S-1-5-21-1151065415-2357480172-3015735021-1000_Classes\comfile\ not found.
HKEY_LOCAL_MACHINE\Software\Classes\.com\\|comfile /E : value set successfully!
Registry key HKEY_USERS\S-1-5-21-1151065415-2357480172-3015735021-1000_Classes\.exe\ not found.
Registry key HKEY_USERS\S-1-5-21-1151065415-2357480172-3015735021-1000_Classes\exefile\ not found.
HKEY_LOCAL_MACHINE\Software\Classes\.exe\\|exefile /E : value set successfully!
File C:\Windows\SysNative\drivers\amubgylk.sys not found.
File C:\Windows\SysNative\drivers\botxdyje.sys not found.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Public
User: UpdatusUser
User: user
->Temp folder emptied: 329565763 bytes
->Temporary Internet Files folder emptied: 20493808 bytes
->Java cache emptied: 1 bytes
->FireFox cache emptied: 96295099 bytes
->Flash cache emptied: 8866 bytes
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 8840690 bytes
RecycleBin emptied: 165376 bytes
Total Files Cleaned = 434,00 mb
OTL by OldTimer - Version 3.2.61.3 log created on 09132012_142920
Files\Folders moved on Reboot...
File move failed. C:\Windows\temp\_avast_\Webshlock.txt scheduled to be moved on reboot.
C:\Windows\temp\TMP00000001C6AC3241CE23815A moved successfully.
C:\Windows\temp\TMP000000169FD97A130497B9E4 moved successfully.
PendingFileRenameOperations files...
Registry entries deleted on Reboot...
To z SystemLook:
SystemLook 30.07.11 by jpshortstuff
Log created at 14:21 on 13/09/2012 by user
Administrator - Elevation successful
========== filefind ==========
Searching for "ws2_32.dll"
C:\Windows\System32\ws2_32.dll --a---- 206336 bytes [23] [01] DAAE8A9B8C0ACC7F858454132553C30D
C:\Windows\winsxs\x86_microsoft-windows-w..nfrastructure-ws232_31bf3856ad364e35_6.1.7600.16385_none_f28e06e62fa99b35\ws2_32.dll --a---- 206336 bytes [23] [01] DAAE8A9B8C0ACC7F858454132553C30D
-= EOF =-
Bym prosił o sprawdzenie:D
Z podziękowaniami
Soukyan
