Kupiłam TV BOX na USB,chciałam zgrać stare kasety VHS+filmy z kamery analogowej.Próbowałam instalować sterowniki ale i na PC i laptopie instalacja nie dochodzi do skutku powodując błąd STOP.
Proszę spojrzeć na log z debuggera i coś poradzić.
Na laptopie
Intel Celeron,procesor 1.40 GHZ+504 MB RAM
Na PC
AMD Athlon 2000+ procesor 1.67 GHz+512 MB RAM
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
Debug session time: Sat May 26 13:54:13.343 2007 (GMT+2)
System Uptime: 0 days 0:02:29.908
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image TridVid.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for TridVid.sys
*** ERROR: Module load completed but symbols could not be loaded for TridVid.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {c0000005, b1a40940, f89817c4, f89814c0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for STREAM.SYS
*** ERROR: Module load completed but symbols could not be loaded for STREAM.SYS
Probably caused by : TridVid.sys ( TridVid+c940 )
Followup: MachineOwner
