Problem z windowsem
(Binder) #1
Proszę o sprawdzenie loga, mam ostatnio problemy z windowsem, myszka sama się wyłancza, wkleje też dla pewności ostatniego .dmp
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\explorer.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Java\jre1.5.0_08\bin\jusched.exe
C:\Program Files\RALINK\RT2500 Wireless LAN Card\Installer\WINXP\RaConfig2500.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\WINDOWS\system32\msiexec.exe
C:\Documents and Settings\USER\Pulpit\hi jack\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Łącza
F2 - REG:system.ini: Shell=explorer.exe
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_08\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar3.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar3.dll
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_08\bin\jusched.exe"
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\1.0.720.3640\GoogleToolbarNotifier.exe
O4 - Global Startup: RaConfig2500.lnk = C:\Program Files\RALINK\RT2500 Wireless LAN Card\Installer\WINXP\RaConfig2500.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_08\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_08\bin\ssv.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {631FF594-EC25-4CFF-B869-402DF294E1D6} (Instalator oprogramowania Onet.pl) - http://slimak.onet.pl/_m/kamerzysta/OnetInstalator012s.ocx
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1146570668745
O17 - HKLM\System\CCS\Services\Tcpip\..\{383D4F0A-A6B1-4391-A248-5B7970DF0EA2}: NameServer = 194.204.159.1,194.204.152.34
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~1\GOEC62~1.DLL
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
Debug session time: Thu Oct 19 17:43:27.875 2006 (GMT+2)
System Uptime: 0 days 0:00:24.445
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, 82b5eb90, 82b5ed04, 805f9f88}
ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,213F80,42250FF9
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : csrss.exe
Followup: MachineOwner
Proszę o pomoc.
(Monczkin) #2
Proszę zapoznać się z tematami o prawidłowym wklejaniu logów na forum i poprawić post - inaczej zostanie on usunięty.
(Binder) #3
Czy teraz jest ok ? mam nadzieje :slight_smile:
(Adarek) #4
To wskazuje na problem ze sprzętem.
Usuń
(Binder) #5
po usunięciu ...
Logfile of HijackThis v1.99.1
Scan saved at 10:44:43, on 2006-10-20
Platform: Windows XP Dodatek SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
przez jakiś czas nie działała mi jedna kość pamięci ... przywróciłem system z początku października i teraz działa ...
(Adarek) #6
Log czysty.
Ps.
Scan darmowym a-squared Free 2. Nie zapomnij uaktualnić mu bazy .
(Binder) #7
wielkie dzięki za pomoc ... :slight_smile:
