Problem z zainstalowaniem gimpa
(Zorroe) #1
GTK+ 2.0 runtime environment was not found on your computer. GTK+ Runtime Environment version 2.4.14 or newer is required to use The Gimp. You can download GTK+ 2.0 runtime environment from <http://gimp-win.sf.net/>.
Please install GTK+ before running the Gimp setup again.
· 1024x768 or greater resolution is recommended to run The Gimp.
Wyskakuje to przy instalacji.Co zrobić zeby działalo??
(Yole) #2
zainstaluj GTK
(Zorroe) #3
OK.Dzięki
