Usunąłem z panelu sterowania ten strong signal, ale nadal sie pojawiał.
Otwórz notatnik systemowy i wklej:
HKLM\...\Run: [] = [X]
HKLM\...\Run: [Adobe ARM] = C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe [1021128 2014-11-20] (Adobe Systems Incorporated)
HKU\S-1-5-21-1687349258-2388905604-2469340140-1000\...\Run: [WMPNSCFG] = C:\Program Files\Windows Media Player\WMPNSCFG.exe [202240 2008-01-18] (Microsoft Corporation)
HKU\S-1-5-21-1687349258-2388905604-2469340140-1000\...\RunOnce: [Adobe Speed Launcher] = 1423993758
URLSearchHook: HKU\S-1-5-21-1687349258-2388905604-2469340140-1000 - (No Name) - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc} - No File
SearchScopes: HKLM - DefaultScope value is missing.
SearchScopes: HKU\.DEFAULT - {483830EE-A4CD-4b71-B0A3-3D82E62A6909} URL =
SearchScopes: HKU\S-1-5-21-1687349258-2388905604-2469340140-1000 - {231A48A9-A84E-4672-87DF-D104D717D879} URL = http://search.babylon.com/?q={searchTerms}affID=113480babsrc=SP_ssmntrId=5e9d78fc000000000000001fe263478f
SearchScopes: HKU\S-1-5-21-1687349258-2388905604-2469340140-1000 - {D35ABCCC-7154-4740-B857-D78D29ABE584} URL = http://www.daemon-search.com/search/web?q={searchTerms}
Toolbar: HKU\S-1-5-21-1687349258-2388905604-2469340140-1000 - No Name - {BF7380FA-E3B4-4DB2-AF3E-9D8783A45BFC} - No File
FF SearchPlugin: C:\Users\Adam\AppData\Roaming\Mozilla\Firefox\Profiles\gsxlqc5j.default\searchplugins\ask-search.xml
FF Extension: Strong Signal - C:\Users\Adam\AppData\Roaming\Mozilla\Firefox\Profiles\gsxlqc5j.default\Extensions\{f318d533-127c-4630-af87-2d2b706e5282}.xpi [2015-02-14]
S2 Service Mgr StrongSignal; "C:\ProgramData\0780f478-67ce-4ec3-98db-39a65f4618ce\plugincontainer.exe" [X]
U3 asji5mav; C:\Windows\system32\Drivers\asji5mav.sys [0] (Microsoft Corporation) ==== ATTENTION (zero size file/folder)
S4 blbdrive; \SystemRoot\system32\drivers\blbdrive.sys [X]
2015-02-14 16:11 - 2015-02-14 16:11 - 00000000 ____ D () C:\Users\Adam\AppData\Roaming\OpenCandy
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST w tym samym folderze.
Wszystko naprawione. Wielkie dzięki za pomoc!
Skasuj folder C:\FRST
